How can I reverse the direction of the Y axis? [message #208925] |
Thu, 09 February 2006 15:59  |
Originally posted by: geoff_crowther.uk.ibm.com
BlankIn the GEF examples (e.g. Logic) the origin (0, 0) is at the top right
of the editor window. Positive Y values are below this origin, and negative
Y values are above. Is there any way to change this direction, so that
positive Y is upwards, preferably also changing the default location of the
origin to be the bottom left of the editor window? This would allow the
editor to match the conventional representation of an X,Y coordinate system.
Many thanks for your help.
Geoff Crowther
Re: How can I reverse the direction of the Y axis? [message #210329 is a reply to message #209045] |
Sat, 25 February 2006 04:50  |
Randy
Many thanks for your suggestion. Unfortunately I am new to GEF, and cannot
see where to hook this in to my application which is currently loosly based
on the "Logic" example application. Could you provide a few pointers for
me.
Thanks again
Geoff
"Randy Hudson" <none@us.ibm.com> wrote in message
news:dsicl5$5ei$1@utils.eclipse.org...
> Rectangle rect = canvas.getClientArea();
> Transform t = new Transform(Display.getCurrent());
> t.translate(0f, (float)(rect.height - rect.y));
> t.scale( 0f, -1f);
> gc.setTransform(t);
> "geoffc" <geoff_crowther@uk.ibm.com> wrote in message
> news:dsga83$pko$1@utils.eclipse.org...
> > right
> > negative
> > the
> > system.
> > Geoff Crowther
FUDForum. Page generated in 0.04364 seconds
