Home » Eclipse Projects » GEF » Splitting a GEF editor in two
Splitting a GEF editor in two [message #207331] Fri, 13 January 2006 15:55 Go to next message
Originally posted by: awm_abu.yahoo.com
Hi all,
I have implemented a textual language using the RCP.
One thing I have been asked to do with this is to provide a variable editor
which is attached to the main editor and
is seperated using only something like a split pane.
I am now working on a number of graphical editors using the GEF and I have
been asked if I could this feature here also.
So what I want is to have an area at the top of the editor that takes text
Then I have an area below this which is a GEF editor area
They are seperated by some kind of split but are still attached so if you
drag tab they move together.
Any idea if/how I can do this ?
Thanks in advance.
Re: Splitting a GEF editor in two [message #207455 is a reply to message #207331] Mon, 16 January 2006 16:41 Go to previous message
You can use GEF anywhere in eclipse.
"Frank Abercorn" <awm_abu@yahoo.com> wrote in message
news:dq8ihd$hgo$1@utils.eclipse.org...
> Hi all,
> editor which is attached to the main editor and
> Thanks in advance.
Previous Topic:add different anchor
Next Topic:Does GEF support adding shortcut keys to palette items?
Current Time: Wed Feb 05 04:53:08 GMT 2025
Powered by FUDForum. Page generated in 0.04021 seconds
