Home » Archived » Riena » Software caused connection abort: socket write error
Software caused connection abort: socket write error [message #20480] Mon, 02 February 2009 09:05 Go to next message
Xingxiao Lu is currently offline Xingxiao LuFriend
Member
Hi Rienaers,
Can somebody help me?
I get exceptions when I use Riena.
WARNING: EXCEPTION
javax.servlet.ServletException: EOFException(java.net.SocketException:
Software caused connection abort: socket write error)
at
org.eclipse.riena.communication.publisher.hessian.RienaHessi anDispatcherServlet.service(RienaHessianDispatcherServlet.ja va:155)
at
org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180)
at
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:111)
at
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:67)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:269)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
at
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
at
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Caused by: EOFException(java.net.SocketException: Software caused connection
at
org.mortbay.http.BufferedOutputStream.flush(BufferedOutputSt ream.java:209)
at
org.mortbay.util.ByteBufferOutputStream.ensureSpareCapacity( ByteBufferOutputStream.java:371)
at
org.mortbay.util.ByteBufferOutputStream.write(ByteBufferOutp utStream.java:197)
at
org.mortbay.http.BufferedOutputStream.write(BufferedOutputSt ream.java:149)
at org.mortbay.http.HttpOutputStream.write(HttpOutputStream.jav a:423)
at org.mortbay.jetty.servlet.ServletOut.write(ServletOut.java:5 4)
at com.caucho.hessian.io.Hessian2Output.flush(Hessian2Output.ja va:1537)
at
com.caucho.hessian.io.Hessian2Output.writeMapBegin(Hessian2O utput.java:568)
at com.caucho.hessian.io.MapSerializer.writeObject(MapSerialize r.java:70)
at
com.caucho.hessian.io.Hessian2Output.writeObject(Hessian2Out put.java:490)
at
com.caucho.hessian.io.JavaSerializer$FieldSerializer.seriali ze(JavaSerializer.java:251)
at
com.caucho.hessian.io.JavaSerializer.writeInstance(JavaSeria lizer.java:208)
at
com.caucho.hessian.io.JavaSerializer.writeObject(JavaSeriali zer.java:172)
at
at
at
at
at
at com.caucho.hessian.io.MapSerializer.writeObject(MapSerialize r.java:79)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
com.caucho.hessian.server.HessianSkeleton.invoke(HessianSkel eton.java:174)
at
org.eclipse.riena.communication.publisher.hessian.RienaHessi anDispatcherServlet.service(RienaHessianDispatcherServlet.ja va:147)
... 18 more
Re: Software caused connection abort: socket write error [message #20505 is a reply to message #20480] Tue, 03 February 2009 12:07 Go to previous message
Christian Campo is currently offline Christian CampoFriend
Hi xxlu,
does that happen all the time. The Socket write error seems to indicate that the socket was interrupted. The exception
trace you are showing is on the Riena server. What happens on the client ?
Is the object you are returning in any way special, large, complicated anything ?
christian
xxlu schrieb:
> Hi Rienaers,
> WARNING: EXCEPTION
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
Re: Software caused connection abort: socket write error [message #578531 is a reply to message #20480] Tue, 03 February 2009 12:07 Go to previous message
Hi xxlu,
christian
xxlu schrieb:
> Hi Rienaers,
> WARNING: EXCEPTION
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 18 more
Previous Topic:How to use Attachment?
Next Topic:Riena BOF at Eclipse Con 2009
Current Time: Sat Dec 21 13:41:42 GMT 2024
Powered by FUDForum. Page generated in 0.03428 seconds
