Home » Eclipse Projects » GEF » how to move an anchor by user
how to move an anchor by user [message #203850] Mon, 28 November 2005 11:11 Go to next message
I want to make it possible to let the use move an anchor. I tried to add a
XYLaoutPolicy to the Connection, hoping I get an request fo a
moveChangedCommand, but I get no one.
My question is, how can I get the new coordinates, if the user moves the
anchor?
thangs in advance
Hannes
Re: how to move an anchor by user [message #203867 is a reply to message #203850] Mon, 28 November 2005 12:00 Go to previous messageGo to next message
Originally posted by: ingo.koch[nospam].sap.com
I suppose you have to create an editpart with a little figure, which hosts
your anchor to receive move-requests.
Regards, Ingo
<el_bosso@gmx.de> wrote in message news:dmfa7e$a1d$1@news.eclipse.org...
> anchor?
> thangs in advance
> Hannes
Re: how to move an anchor by user [message #203871 is a reply to message #203867] Mon, 28 November 2005 13:35 Go to previous messageGo to next message
No, you don't. There are already endpoint handles (EndpointEditPolicy),
which send "reconnect" requests to the target node. All you have to do is
interpret those requests as moves, and create commands that move the anchors
in the model. Then, when you refresh your figure, set the appropriate
connection anchor on the connection based on the model's properties. You
will have to write a simple anchor implementation for this.
"Ingo Koch" <ingo.koch[nospam]@sap.com> wrote in message
news:dmfd39$f02$1@news.eclipse.org...
> Regards, Ingo
>> Hi,
>> a
>> anchor?
>> thangs in advance
>> Hannes
Re: how to move an anchor by user [message #203879 is a reply to message #203871] Mon, 28 November 2005 15:22 Go to previous messageGo to next message
Thank you. I'll try this.
> anchors in the model. Then, when you refresh your figure, set the
> appropriate connection anchor on the connection based on the model's
> properties. You will have to write a simple anchor implementation for
> this.
Re: how to move an anchor by user [message #203911 is a reply to message #203871] Tue, 29 November 2005 03:40 Go to previous message
Well, that
Previous Topic:SWTGraphics - wrong behaviour
Next Topic:L&F : Focus Rectangle
Current Time: Sun Nov 02 20:49:17 EST 2025
Powered by FUDForum. Page generated in 0.04426 seconds
