Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #166 is a reply to message #156] |
Tue, 29 August 2006 08:16 |
Shigeki Moride Messages: 26 Registered: July 2009 |
Dear Peter,
I must apologize for the delay.
So,
For Linux building, please read the install section in the
README-en_US.8859-1.txt. as attached.
You can find it on download page.
http://www.eclipse.org/dsdp/nab/downloads.php
I am happy if I can help you.
Sincerely,
7.2 Linux Installation
Please install the Linux(GTK) version according to the following
procedure.
(1) JDK (JavaTM 2 SDK, Standard Edition Version 1.4.2) installation
http://java.sun.com/j2se/1.4.2/download.html
(2) WideStudio/MWT installation
Unzip ws-v3.94.1-src.tar.gz and execute the following commands on
the
console to install it.
It is offered by http://www.widestudio.org/EE/download.html.
$ cd <any directory>
$ tar -zxvf ws-v3.94.1-src.tar.gz
$ cd ws-v3.94-1/src
$ ./configure
$ make runtime
$ make mwt_java
$ su
# make install
At the end, please add the "/usr/local/lib" path to
LD_LIBRARY_PATH
environment variable.
(3) Eclipse 3.2.X (Linux version) installation
Unzip eclipse-SDK-3.2.X-linux-gtk.zip and install it. It is
distributed
from www.eclipse.org.
(4) CDT plug-in installation
Unzip org.eclipse.cdt.sdk-3.1.X-linux.x86.zip to the folder that
Eclipse
was installed. It is distributed from www.eclipse.org
(5) NAB plug-in installation
Unzip the following files to the folder that Eclipse was installed.
nab-mwt.linux-gtk.0.9.5.zip
nab-mwt.doc.0.9.5.zip
On Aug 08 2006 01:40:49
From peter.fodrek@xxxxxxxxxxxx (peter fodrek) wrote:
> Dear conference,
> I would like to use NAB as GUI producer, but project can not produce
makefile, Can anyone help me,pleas?
> Thank you for any help
> I look forward hearing from you
> Yours Faithfully
> Peter
Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #213 is a reply to message #206] |
Tue, 13 February 2007 20:14 |
Originally posted by: rxmoi.home.se
Thanks for your response.
I have just (a few weeks ago) downloaded the WideStudio ver 3.96-1 and I
don't find a match for the directory structure you refered to. The make
file candidates (make.win) referes to mkfiles and a build results in
+17300 errors ;). There is a large number of make_xx files to chose among
(dll, nsp, exe, ...).
Pleeeese help a confused beginner who realy want to get going with nab.
Is the compleate GUI Hello world source code package includng make files
available for download somewhare?
/Mike
Re: NAB compiling problem no makeflie in linux - help is just for Windows [message #568652 is a reply to message #156] |
Dear Peter,
So,
Sincerely,
procedure.
the
$ cd ws-v3.94-1/src
$ ./configure
$ make runtime
$ make mwt_java
$ su
# make install
LD_LIBRARY_PATH
distributed
Eclipse
> Dear conference,
> Yours Faithfully
> Peter
FUDForum. Page generated in 0.05214 seconds
