Recursive Debugging [message #202859] |
Mon, 02 April 2007 16:02  |
I have some code in a project that has a recursive method. The method
calls itself repetitively until it processes all the data and then backs
out of each call of the method. When I go to debug the class that has
this recursive method (the call is within the class) I get a "Source not
found" message. If I comment out the recursive call within the class then
I don't get this message. The method has to be recursive, does anyone
have any recommendations?
Ben
Re: Recursive Debugging [message #202895 is a reply to message #202859] |
Mon, 02 April 2007 18:43  |
Originally posted by: dtoland.email.uophx.edu
My guess, from the behavior you are describing, is that the recursion is
taking place before the breakpoint you are setting, and some exception, such as an
out of memory error, is taking place before you reach your breakpoint. That
exception may be caught in some method outside your source code, resulting in
the "source not found".
If this is the case, you should be able to put a breakpoint in the first statement of
your recursive method. If that succeeds, make sure the exit condition for your
recursion will be met. Either the exit condition must be a caught exception in the
recursive method, or must be tested for before the recursive call within the method.
Dave Toland
dave.toland@verizon.net
"Ben" <bsisson@simventions.com> wrote in message news:0f744b471378ef66cc2d101e99b6ffb2$1@www.eclipse.org...
| Thanks,
| Ben
FUDForum. Page generated in 0.07728 seconds
