Home » Language IDEs » Java Development Tools (JDT) » Content assist fails with "Error Executing Command"
Content assist fails with "Error Executing Command" [message #202719] Fri, 06 May 2005 02:13 Go to next message
Originally posted by: rotvel.bolignet-aarhus.dk
I have a class where I define a number of Pattern constants similar to
this:
// GET <type> <path>| <offset> <length> |<playerid>|
private static final Pattern GET = Pattern
.compile("(GET) (\\p{Upper}*) (.*)\\| (\\d+) (\\d+) .*", Pattern.DOTALL);
This causes content assist (Ctrl-Space) to fail with an "Error Executing
Command" dialog. The reason given in the dialog is "The command for the
key you pressed failed" :-)
If I comment out all the definitions content assist works properly again.
Max - rotvel AT bolignet-aarhus DOT dk
Re: Content assist fails with "Error Executing Command" [message #202728 is a reply to message #202719] Fri, 06 May 2005 02:55 Go to previous messageGo to next message
On Fri, 06 May 2005 08:13:59 +0200, Max Rotvel <rotvel@bolignet-aarhus.dk>
> this:
> Pattern.DOTALL);
> Regards
Forgot to say. This is 3.1M7.
Re: Content assist fails with "Error Executing Command" [message #202743 is a reply to message #202728] Fri, 06 May 2005 03:09 Go to previous messageGo to next message
Max, please file a bug report against jdt-text and include the exception
you find in the error log (Window>Show View>Error Log).
Interesting... M7 is only coming out next week ;-)
-tom
Re: Content assist fails with "Error Executing Command" [message #202759 is a reply to message #202743] Fri, 06 May 2005 04:03 Go to previous messageGo to next message
On Fri, 06 May 2005 09:09:36 +0200, Tom Eicher <eclipse@tom.eicher.name>
Done. https://bugs.eclipse.org/bugs/show_bug.cgi?id=93877
Erm... :-)
Re: Content assist fails with "Error Executing Command" [message #202818 is a reply to message #202759] Fri, 06 May 2005 10:37 Go to previous message
On Fri, 06 May 2005 10:03:08 +0200, Max Rotvel <rotvel@bolignet-aarhus.dk>
>> exception you find in the error log (Window>Show View>Error Log).
Well, it turned out to be a duplicate (one of several) of the already
fixed https://bugs.eclipse.org/bugs/show_bug.cgi?id=90414. I should have
been more dilligent in my Bugzilla search, I suppose.
Anyway, good to know it's fixed.
Previous Topic:what's wrong with this?
Next Topic:When JDT will support features from JDK 1.5/5.0?
Current Time: Sat Nov 01 20:10:43 EDT 2025
Powered by FUDForum. Page generated in 0.42038 seconds
