Home » Eclipse Projects » Eclipse Platform » Deploying RCP
Deploying RCP [message #201560] |
Wed, 25 February 2004 11:27  |
Has anyone figured out how to determine the entire list of required plugins
that are required by an RCP application.
I have painfully tried to do this by hand but still get the following error
when attempting to launch the application as a standalone app.
Note that all the plugins that are listed are in the plugins directory so I
must be missing a plugin or plugins that these require.
Is there a tool that will determine the complete plugin list?
Mark
!SESSION Feb 25, 2004
11:10:09.93 ----------------------------------------------
java.version=1.4.1_03
Command-line arguments: -application com.ibm.rational.test.mt.MtApp
!ENTRY org.eclipse.osgi Feb 25, 2004 11:10:09.93
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/com.ibm.rational.tes t.mt_1.0.0 [5]
was not resolved
!MESSAGE Bundle reference:file:c:/MTAStandalone/plugins/com.ibm.rte_1.0.0
[6] was not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.jface.te xt_3.0.0 [24]
was not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.jface_3. 0.0 [25] was not
resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.swt.brow ser.dom_3.0.0
[27] was not resolved
!ENTRY org.eclipse.osgi Feb 25, 2004 11:10:09.109
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.swt.brow ser.w3cdom_3.0.0
[28] was not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.swt.win3 2_3.0.0 [29] was
not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.ui.conso le_3.0.0 [31]
was not resolved
!ENTRY org.eclipse.osgi Feb 25, 2004 11:10:09.125
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.ui.edito rs_3.0.0 [32]
was not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.ui.ide_3 .0.0 [33] was
not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.ui.views _3.0.0 [34] was
not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.ui.workb ench.texteditor_
3.0.0 [35] was not resolved
!MESSAGE Bundle
reference:file:c:/MTAStandalone/plugins/org.eclipse.ui.workb ench_3.0.0 [36]
was not resolved
!ENTRY org.eclipse.osgi Feb 25, 2004 11:10:09.140
!MESSAGE Bundle reference:file:c:/MTAStandalone/plugins/org.eclipse.ui_3.0.0
[37] was not resolved
!ENTRY org.eclipse.core.runtime 4 13 Feb 25, 2004 11:10:09.140
!MESSAGE Unable to locate application extension:
!STACK 0
java.lang.RuntimeException: Unable to locate application extension:
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.
java:236)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
Re: Deploying RCP [message #201627 is a reply to message #201560] |
Wed, 25 February 2004 12:28   |
Originally posted by: manahan.NOSPAM.ca.ibm.com
There is an initial list of required plugins in the RCP tutorials Ed
Burnette wrote (thanks Ed :-)listed here.
http://dev.eclipse.org/viewcvs/index.cgi/~checkout~/platform -ui-home/rcp-proposal/rich_client_platform_facilities.html
Depending on what you add above and beyond the minimal listed you'll
have to add those as well. You should be able to specify the plugins to
load when running it via a runtime workbench and then use that same list
when deploying the application.
Peter
> Mark
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> resolved
> !MESSAGE Bundle
> !MESSAGE Bundle
> !MESSAGE Bundle
> not resolved
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> not resolved
> !MESSAGE Bundle
> not resolved
> !MESSAGE Bundle
> !MESSAGE Bundle
> was not resolved
> !STACK 0
> at
> java:236)
> at
Re: Deploying RCP [message #201664 is a reply to message #201627] |
Wed, 25 February 2004 13:30   |
Thanks Peter,
I started with Ed's tutorial (Thanks Ed).
The problem is that some of the plugins that I require, themselves require
plugins.
I do not have to explicitly specify those plugins. My RCP based app just
works when I run from the IDE because those plugins exist. However when I
deploy my RCP app, I need to know the entire plugin dependency tree. I am
surprised that a tool that enumerates the plugin dependency tree does not
exist. If I get the time, I will write one.
Mark
"Peter Manahan" <manahan@NOSPAM.ca.ibm.com> wrote in message
news:c1ilp2$5el$1@eclipse.org...
> Peter
plugins
error
so I
> > Thanks,
> > Mark
> > !MESSAGE Bundle
[5]
> > was not resolved
> > !MESSAGE Bundle
> > !MESSAGE Bundle
[24]
> > was not resolved
> > !MESSAGE Bundle
not
> > resolved
> > !MESSAGE Bundle
> > !MESSAGE Bundle
> > !MESSAGE Bundle
was
> > not resolved
> > !MESSAGE Bundle
[31]
> > was not resolved
> > !MESSAGE Bundle
[32]
> > was not resolved
> > !MESSAGE Bundle
was
> > not resolved
> > !MESSAGE Bundle
was
> > not resolved
> > !MESSAGE Bundle
> > !MESSAGE Bundle
[36]
> > was not resolved
> > !MESSAGE Bundle
> > !STACK 0
> > at
> > java:236)
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: Deploying RCP [message #201672 is a reply to message #201664] |
Wed, 25 February 2004 13:38   |
The PDE does this. Select the project Context Menu. PDE Tools->Open
Dependencies.
You also can just open the view and use it Window->Show View. You want
the "Plug-in Dependencies" View.
Peter
Mark Victory wrote:
> Thanks Peter,
> plugins.
> Mark
>>Peter
> plugins
> error
> so I
>>>Thanks,
>>>Mark
>>>!MESSAGE Bundle
> [5]
>>>was not resolved
>>>!MESSAGE Bundle
>>>!MESSAGE Bundle
> [24]
>>>was not resolved
>>>!MESSAGE Bundle
> not
>>>resolved
>>>!MESSAGE Bundle
>>>!MESSAGE Bundle
>>>!MESSAGE Bundle
> was
>>>not resolved
>>>!MESSAGE Bundle
> [31]
>>>was not resolved
>>>!MESSAGE Bundle
> [32]
>>>was not resolved
>>>!MESSAGE Bundle
> was
>>>not resolved
>>>!MESSAGE Bundle
> was
>>>not resolved
>>>!MESSAGE Bundle
>>>!MESSAGE Bundle
> [36]
>>>was not resolved
>>>!MESSAGE Bundle
>>>!STACK 0
>>> at
>>>java:236)
>>> at
Re: Deploying RCP [message #201689 is a reply to message #201664] |
Wed, 25 February 2004 13:46   |
I expected this functionality to be the result of pressing the "add
required-plug-ins" buttons in the run menu, however this seems to add
plug-ins that are not required based on the manifest of the plug-ins being
run. Unfortunately I also have to resort to drawing a dependency graph
(using paper and pen!).
James
Mark Victory wrote:
> Thanks Peter,
> plugins.
> Mark
> > Peter
> plugins
> error
> so I
> > > Thanks,
> > > Mark
> > > !MESSAGE Bundle
> [5]
> > > was not resolved
> > > !MESSAGE Bundle
> > > !MESSAGE Bundle
> [24]
> > > was not resolved
> > > !MESSAGE Bundle
> not
> > > resolved
> > > !MESSAGE Bundle
> > > !MESSAGE Bundle
> > > !MESSAGE Bundle
> was
> > > not resolved
> > > !MESSAGE Bundle
> [31]
> > > was not resolved
> > > !MESSAGE Bundle
> [32]
> > > was not resolved
> > > !MESSAGE Bundle
> was
> > > not resolved
> > > !MESSAGE Bundle
> was
> > > not resolved
> > > !MESSAGE Bundle
> > > !MESSAGE Bundle
> [36]
> > > was not resolved
> > > !MESSAGE Bundle
> > > !STACK 0
> > > at
> > > java:236)
> > > at
Re: Deploying RCP [message #201705 is a reply to message #201672] |
Wed, 25 February 2004 14:30   |
I tried the Plug-in Dependencies. While it is certainly helpful, it is
painful to search through the set of plugins drilling down through all the
levels. What I would like is a simple list of all the plugins on which my
app (plugin) depends.
news:c1ips6$b4e$1@eclipse.org...
> Dependencies.
> Peter
> Mark Victory wrote:
> > Thanks Peter,
require
> > plugins.
just
I
am
not
> > Thanks,
> > Mark
> >>Peter
> > plugins
> > error
> > so I
> >>>Thanks,
> >>>Mark
> >>>!MESSAGE Bundle
> > [5]
> >>>was not resolved
> >>>!MESSAGE Bundle
> >>>!MESSAGE Bundle
> > [24]
> >>>was not resolved
> >>>!MESSAGE Bundle
was
> > not
> >>>resolved
> >>>!MESSAGE Bundle
> >>>!MESSAGE Bundle
> >>>!MESSAGE Bundle
[29]
> > was
> >>>not resolved
> >>>!MESSAGE Bundle
> > [31]
> >>>was not resolved
> >>>!MESSAGE Bundle
> > [32]
> >>>was not resolved
> >>>!MESSAGE Bundle
> > was
> >>>not resolved
> >>>!MESSAGE Bundle
> > was
> >>>not resolved
> >>>!MESSAGE Bundle
> >>>!MESSAGE Bundle
> > [36]
> >>>was not resolved
> >>>!MESSAGE Bundle
> >>>!STACK 0
> >>> at
> >>>java:236)
> >>> at
Re: Deploying RCP [message #202769 is a reply to message #201560] |
Thu, 26 February 2004 23:42   |
Originally posted by: jeff_mcaffer.REMOVE.ca.ibm.com
In recent builds you should be able to go to the Plugins tab in the launch
config and click on "choose plugins from list". In there pick your plugins
and click "Add Required".
IMHO this support is not complete (you and (de)select all, and the same
thing on the Target Platform preferenece page).
I find the PDE folks particularly receptive to bug reports on matters like
this. They really want to make PDE useful.
Jeff
"Mark Victory" <MVictory@us.ibm.com> wrote in message
news:c1ihsj$vch$1@eclipse.org...
plugins
error
I
> Mark
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
not
> resolved
> !MESSAGE Bundle
> !MESSAGE Bundle
> !MESSAGE Bundle
was
> not resolved
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> was not resolved
> !MESSAGE Bundle
> not resolved
> !MESSAGE Bundle
was
> not resolved
> !MESSAGE Bundle
> !MESSAGE Bundle
[36]
> was not resolved
> !MESSAGE Bundle
> !STACK 0
> at
> java:236)
> at
Current Time: Sun Oct 19 12:53:07 EDT 2025
Powered by FUDForum. Page generated in 0.05321 seconds
