Home » Modeling » GMF (Graphical Modeling Framework) » Layout: How to modify TopDownProvider?
Layout: How to modify TopDownProvider? [message #200239] Mon, 04 August 2008 22:40 Go to next message
Originally posted by: rolfes.daniel.web.de
i am trying to change the Layout of my diagram.
I want to achieve the following result:
I have two different connection types. If two nodes are connected with
the first type, there should be a top-down behavior. If they are
connected with the second type, there should be a left-right or
right-left behavior.
I tried to modify the TopDownProvider (DefaultProvider) but there is
some fancy stuff going on, involving the GMFDirectedGraphLayout.
Is this the right way to do this? Or does anyone know a better approach?
Daniel
Re: Layout: How to modify TopDownProvider? [message #200788 is a reply to message #200239] Wed, 06 August 2008 12:14 Go to previous messageGo to next message
i would be really glad, if you could give me some hints on this one. How
do i start?
D. Rolfes schrieb:
> Daniel
Re: Layout: How to modify TopDownProvider? [message #200805 is a reply to message #200788] Wed, 06 August 2008 12:20 Go to previous messageGo to next message
i should probably add that the user should be able to layout the
diagramm manually. The described behavior should be invoked by the
Arrange-all-button.
Daniel
D. Rolfes schrieb:
> do i start?
> D. Rolfes schrieb:
>> Hi,
>> Thanks,
>> Daniel
Re: Layout: How to modify TopDownProvider? [message #201259 is a reply to message #200805] Fri, 08 August 2008 17:38 Go to previous message
any help would be greatly appreciated!
Daniel
D. Rolfes schrieb:
> Arrange-all-button.
> Daniel
> D. Rolfes schrieb:
>> Hi,
>> How do i start?
>> D. Rolfes schrieb:
>>> Hi,
>>> with the first type, there should be a top-down behavior. If they are
>>> Thanks,
>>> Daniel
Previous Topic:how to swap positions of two nodes handled by XYLayout?
Next Topic:Translate Text's of the menus/tooltips etc
Current Time: Sat Nov 02 22:11:06 GMT 2024
Powered by FUDForum. Page generated in 0.03095 seconds
