Eclipse 3.0 crashes on startup with JRE 1.3.1_10 [message #199656] |
Mon, 23 February 2004 10:40 |
Originally posted by: pfaendung.web.de
Hi Folks,
I'm having some problems starting eclipse 3.0 M[3-7] on Windows XP Prof
with JRE 1.3.1_10. I always get the error screen
JVM terminated. Exit code=1
C:\windows\system32\javaw.exe
-cp C:\programme\eclipse-3.0_M6\startup.jar org.eclipse.core.launcher.Main
-os win32
-ws win32
-arch x86
-showsplash [...]
If I start eclipse manually via
java -cp startup.jar org.eclipse.core.launcher.Main from the eclipde dir I
get the following error
Exception in thread "main" java.lang.IllegalAccessError: try to access
method java.io.FileOutputStream.<init>(Ljava/io/File;Z)V from class
at org.eclipse.core.launcher.Main.isAlreadyRunning(Main.java:14 43)
at org.eclipse.core.launcher.Main.main(Main.java:577)
With eclipse 2.1.2 evrything is fine.
Please don't suggest using jre 1.4.x, it is not possible in my case.
Any ideas?
Frank
Re: Eclipse 3.0 crashes on startup with JRE 1.3.1_10 [message #199683 is a reply to message #199656] |
Mon, 23 February 2004 10:13 |
Originally posted by: dyroro.netscape.net
You will need a 1.4.1 level or higher Java runtime or Java development
kit (JDK) installed on your machine in order to run EclipseFrank wrote:
> Hi Folks,
> -os win32
> -ws win32
> -arch x86
> -showsplash [...]
> Any ideas?
> Regards
> Frank
Re: Eclipse 3.0 crashes on startup with JRE 1.3.1_10 [message #199832 is a reply to message #199698] |
Mon, 23 February 2004 15:24 |
Originally posted by: Lamont_Gilbert.rigidsoftware.com
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enigCBB7DAF13D2454F8857E32C3
Content-Type: text/plain; charset=us-ascii; format=flowed
Interesting replies. Perhaps 3.0 should check for the proper runtime
before it dies? Is this bug/enhancement already filed and just not
implemented yet?
Peter Manahan wrote:
> Eclipse 3.0 requires JDK 1.4.x. if you need to use JDK 1.3 you'll have
> use an eclipse 2.1.x version.
> Peter
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber." John 10:1
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFAOhsqVbJM14DSCi0RAsoiAJ9cW1lbrCFfvNXPx5gqMj2YDGH95wCe O56H
lhilxWA+t7qa5ZWLyxfcXS8=
=ZCp+
-----END PGP SIGNATURE-----
--------------enigCBB7DAF13D2454F8857E32C3--
Re: Eclipse 3.0 crashes on startup with JRE 1.3.1_10 [message #199854 is a reply to message #199832] |
Mon, 23 February 2004 16:02 |
Originally posted by: muelleimer.usenet.katzien.de
Hallo!
> implemented yet?
Please not!
kaffe is getting ready to run eclipse and I don't want to do a patch
to work around this.
I know that eclipse.org states, that it is 1.4 only, but as long as
SUNs JVMs are considered non-free, debian (and other distros) will try
to get eclipse running on free replacements. Any 'check', which ensures
that it is a sun-derived 1.4 JVM running eclipse will srew this effort.
I don't mind a 'post error' check, but please not before trying.
Thanks!
Jan, debian eclipse maintainer
Re: Eclipse 3.0 crashes on startup with JRE 1.3.1_10 [message #199934 is a reply to message #199854] |
Mon, 23 February 2004 16:42 |
Originally posted by: dj_houghton.nospam.ca.ibm.com
Follow bug 44814 for more information.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=44814
We don't do specific VM implementation checks, only checks against
version numbers. Do you see problems doing this against the free VMs
that you mention?
Also, there is code that essentially says "if we can't figure out what
version the VM is, then try and run and let it fail later if it is not
what we need".
Jan Schulz wrote:
> Hallo!
>>implemented yet?
> Please not!
> Thanks!
FUDForum. Page generated in 0.04338 seconds
