Home » Newcomers » Newcomers » Welcome to eclipse.newcomer
Re: Problem with Enum [message #215087 is a reply to message #215079] |
Mon, 11 June 2007 19:33   |
Mark Priest wrote:
> I am having a problem getting Eclipse to allow me to create enums.
> Every time I create an enum in my project I get the following error:
> The type Comparable is not generic; it cannot be parameterized with
> arguments <E>
> The enum I am trying to create is:
> public enum TestEnum {
> Val1,
> Val2;
> I am running Eclipse version 3.2.2 on Ubuntu Linux (Build id:
> M20070212-1330 (Ubuntu version: 3.2.2-0ubuntu3)
> I am running the following 1.5 JDK:
> java version "1.5.0_11"
> Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_11-b03)
> Java HotSpot(TM) Client VM (build 1.5.0_11-b03, mixed mode, sharing)
> In my project settings I have set the compiler compliance set to 5.0
> with default compliance settings.
> Any ideas why this is happening?
> Mark
Hi. I just tried it here. Is your outer class also called TestEnum? If
so, perhaps that is the problem. Try changing the name of your enum, e.g.,
public class TestEnum {
public enum Day {
SUNDAY, MONDAY, TUESDAY, WEDNESDAY,
THURSDAY, FRIDAY, SATURDAY
public enum Test {
VALUE1, VALUE2
Hope this helps. Mark Dexter
Re: Problem with Enum [message #215096 is a reply to message #215087] |
Mon, 11 June 2007 19:45   |
Originally posted by: mark.priest.computer.org
On Mon, 2007-06-11 at 16:33 -0700, Mark Dexter wrote:
> Mark Priest wrote:
> > Hi,
> > arguments <E>
> > Val1,
> > Val2;
> > Thanks,
> > Mark
> public enum Day {
> public enum Test {
> VALUE1, VALUE2
Mark,
In my example there is no outer class. I am trying to create a
free-standing(?) enum. In any case your example gives me the same error
message.
It seems like some sort of JDK 1.5 compliance issue. Maybe I am not
setting my Eclipse settings correctly. I just don't see the problem.
Mark
Re: Problem with Enum [message #215103 is a reply to message #215096] |
Mon, 11 June 2007 20:10   |
> > Mark Priest wrote:
> > > Hi,
> > > arguments <E>
> > > Val1,
> > > Val2;
> > > Thanks,
> > > Mark
> > public enum Day {
> > public enum Test {
> > VALUE1, VALUE2
> Mark,
> message.
> Mark
Ok this is user error. It turns out I had a jar file with core JDK
lasses from JDK 1.4 in the classpath. Sorry about that! Now my problem
is gone.
Mark
Re: Welcome to eclipse.newcomer [message #646524 is a reply to message #2132] |
Tue, 28 December 2010 01:35  |
On 1/14/2005 3:02 AM, WebMaster wrote:
> New to Eclipse? Ask questions regarding downloading, installing and
> getting started with Eclipse in this newsgroup.
Hi There,
I am Sandeep Motwani from India.
I have started using EPF for process authoring and have a doubt I would
like to clarify with you guys.
Don't know whom I should write this mail, but would request you to help
me with it or guide me to the correct person.
The situation is as follows-
I want to move plug-in 1 from library A to Library B.
1. Is it possible to do such a movement?
2. If yes, how do I do it?
Thank you very much in advance.
Sandeep
Current Time: Wed Jul 02 10:34:29 EDT 2025
Powered by FUDForum. Page generated in 0.14535 seconds
