Home » Eclipse Projects » GEF » replacing editpart figure
replacing editpart figure [message #199237] Fri, 14 October 2005 12:50 Go to next message
Originally posted by: christian.sell.netcologne.de
in my application I have the requirement of replacing a figure at
runtime. This is caused by a preference change that causes a change to
the representation of certain edit parts that cannot be achieved by
simply setting properties on the current figure.
After much debugging and investigation, I came up with the following
sequence:
deactivateFigure();
unregisterVisuals();
setFigure(createFigure());
activateFigure();
registerVisuals();
Because the above was so non-obvious (e.g., did not know that figures
were "registered"), I wonder if this is the right way to go, or whether
there is a better way that I missed.
thanks,
Christian
Re: replacing editpart figure [message #199253 is a reply to message #199237] Fri, 14 October 2005 14:02 Go to previous messageGo to next message
Felix L J Mayer is currently offline Felix L J MayerFriend
I was able to achieve basically the same by not changing the main figure,
but only its children. The main figure had no graphical representation, and
in refreshVisuals() I would first remove all children and then add new ones.
"Christian Sell" <christian.sell@netcologne.de> wrote in message
news:dio9j3$4op$1@news.eclipse.org...
> Hello,
> in my application I have the requirement of replacing a figure at runtime.
> This is caused by a preference change that causes a change to the
> representation of certain edit parts that cannot be achieved by simply
> sequence:
> deactivateFigure();
> activateFigure();
> registerVisuals();
> Because the above was so non-obvious (e.g., did not know that figures were
> "registered"), I wonder if this is the right way to go, or whether there
> thanks,
> Christian
Re: replacing editpart figure [message #199318 is a reply to message #199237] Fri, 14 October 2005 14:39 Go to previous messageGo to next message
What you are doing should (almost) work for connections that have no
children.
You'll probably also need to call refresh() so that the anchors and any
attributes get set on the new Connection.
> Hello,
> sequence:
> deactivateFigure();
> activateFigure();
> registerVisuals();
> thanks,
> Christian
Re: replacing editpart figure [message #199333 is a reply to message #199318] Fri, 14 October 2005 14:44 Go to previous messageGo to next message
yes, I have calls to "refreshSourceAnchor(); refreshTargetAnchor();" in
there as well.
However, what about non-connection figures? As I now realize,
deactivateFigure() is specific to connections.
christian
> children.
>>Hello,
>>sequence:
>> deactivateFigure();
>> activateFigure();
>> registerVisuals();
>>thanks,
>>Christian
Re: replacing editpart figure [message #199362 is a reply to message #199333] Fri, 14 October 2005 15:09 Go to previous message
For normal GEP's it gets trickier. You need to remove the figure yourself
and preserve the layout constraint.
If you have children, you need to add then to the new contents pane, again
preserving the layout manager and the constraints.
But, the case is rarer since borders and layoutmanagers can already be
changed without changing the figure. Also, you can compose normal figures a
lot easier than wrapping a connection inside a "fake" connection.
news:diog96$ejf$1@news.eclipse.org...
> there as well.
> christian
>> children.
>>>Hello,
>>>sequence:
>>> deactivateFigure();
>>> activateFigure();
>>> registerVisuals();
>>>thanks,
>>>Christian
Previous Topic:thanx for GEF and Draw2d Developer's Guide in 3.1.1 doc
Next Topic:who can i catch an addRequest on a Connection?
Current Time: Mon Jan 13 15:50:46 GMT 2025
Powered by FUDForum. Page generated in 0.02698 seconds
