Home » Eclipse Projects » GEF » Crash with empty Labels on Linux
Crash with empty Labels on Linux [message #198469] Wed, 12 October 2005 03:00 Go to next message
instantiating Labels (from draw2D) with no initial text the application
crashes with following error (only on linux, on windows the application
works fine):
------------------------------------------------------ The
program 'SWT' received an X Window System error. This probably reflects a
bug in the program. The error was 'BadAlloc (insufficient resources for
operation)'.
(Details: serial 4345 error_code 11 request_code 53 minor_code 0) (Note
to programmers: normally, X errors are reported asynchronously;
that is, you will receive the error a while after causing it. To debug
your program, run it with the --sync command line option to change this
behavior. You can then get a meaningful backtrace from your debugger if
you break on the gdk_x_error() function.)
----------------------------------------------------- Trying to find a
workaround I set a MarginBorder(1) on the Label the problem seems to be
resolved.
regards
Re: Crash with empty Labels on Linux [message #198657 is a reply to message #198469] Wed, 12 October 2005 11:53 Go to previous messageGo to next message
This sounds like a nasty bug. Can you please provide us with a snippet that
reproduces it?
"Max" <mbrigl@gmx.net> wrote in message
news:pan.2005.10.12.07.00.57.225057@gmx.net...
> works fine):
> operation)'.
> resolved.
> regards
Re: Crash with empty Labels on Linux [message #198723 is a reply to message #198657] Wed, 12 October 2005 13:03 Go to previous messageGo to next message
Originally posted by: bbiggs.ca.ibm.com
A snippet would be very helpful. X is asynchronous, but in SWT there is
a way to put it in synchronous mode so you can get a stack trace of
where the failure occurs. When creating the display:
Device.DEBUG = true;
DeviceData data = new DeviceData();
data.debug = true;
Display display = new Display (data);
The X request which is failing here is an XCreatePixmap, so this might
have to do with an icon somewhere failing...
> reproduces it?
>>works fine):
>>operation)'.
>>resolved.
>>regards
Re: Crash with empty Labels on Linux [message #198931 is a reply to message #198723] Thu, 13 October 2005 09:48 Go to previous messageGo to next message
I will provide a snippet as soon as possible. Unfortunately I can
reproduce the problem only on our application, but not in a simple
standalone.
> data.debug = true;
>> reproduces it?
>>>works fine):
>>>operation)'.
>>>resolved.
>>>regards
Re: Crash with empty Labels on Linux [message #198939 is a reply to message #198723] Thu, 13 October 2005 10:06 Go to previous messageGo to next message
"Billy Biggs" <bbiggs@ca.ibm.com> wrote in message
news:dijflh$a39$1@news.eclipse.org...
> data.debug = true;
Billy, can this be done by using the PDE launcher's Tracing Tab?
Re: Crash with empty Labels on Linux [message #199138 is a reply to message #198939] Thu, 13 October 2005 16:24 Go to previous message
>> data.debug = true;
Good call. If you enable tracing for org.eclipse.ui, one of
the options is "debug/swtdebug". This _should_ enable both Device.DEBUG
and data.debug, but it may only do the latter which would be less useful
in this case.
Try swtdebug, and if you don't get a stack trace, file a bug against
Platform > UI asking for more tracing options :)
-Billy
Previous Topic:Drag & Drop in GEF
Next Topic:How to programmatically close the editor?
Current Time: Sat Oct 18 15:16:54 EDT 2025
Powered by FUDForum. Page generated in 0.10950 seconds
