Home » Eclipse Projects » GEF » Custom view and ... ??
Custom view and ... ?? [message #198503] Wed, 12 October 2005 12:02 Go to next message
Originally posted by: greg.gigon.tugulu.com
This is more Eclipse not GEF problem, but maybe some of you guys have
faced this kind of issue.
I've created a custom view for my Graphical Plugin Editor in Eclipse.
Then I've added a my Custom Viwer to it. It creates a form using SWT for
element properties. Using SelectionListener nicely it hookes in
GraphicalEditor and getProperties from element and display this in a
View. My problem is ... how to make it work other way around??????
When I type new things in my Form Text Boxes HOW TO REFLECT CHANGES IN A
MODEL.
Is there some kind of a mechanizm for that?
Cheers, Greg
Re: Custom view and ... ?? [message #198770 is a reply to message #198503] Wed, 12 October 2005 17:16 Go to previous messageGo to next message
> MODEL.
Well, you just change your model (model.setXxx(), or whatever kind of
model you're using). If you're doing it the preferred way, your model
has a notification mechanism so the GraphicalEditor will notice the
model's changes and update its appearance. It's really very specific to
your model. Take a look at the Model-View-Controller design pattern if
this doesn't make much sense to you.
Good luck,
Martijn.
Re: Custom view and ... ?? [message #198869 is a reply to message #198770] Thu, 13 October 2005 08:13 Go to previous messageGo to next message
That's the whole problem. You can't have direct reference to a model in
View. When element in Editor was selected SelectionListener call
selectionChange() in View object. Then using a IAdaptable (EditPart
implements IAdaptable) i retrive data from EditPart as an Object of
IMyProperties. Then I'm passing this object to the Viewer and I have
this data displeyed in a View.
How to do this other way around, how to set data??
Cheers, Greg
>> for element properties. Using SelectionListener nicely it hookes in
>> A MODEL.
> Good luck,
> Martijn.
Re: Custom view and ... ?? [message #198900 is a reply to message #198869] Thu, 13 October 2005 11:56 Go to previous messageGo to next message
I'm afraid I don't know what you mean. Perhaps someone else has a clue?
M.
Re: Custom view and ... ?? [message #198971 is a reply to message #198900] Thu, 13 October 2005 16:10 Go to previous messageGo to next message
Thank's Martijn for afford.
I just figured it out :)
Greg
> M.
>> in View. When element in Editor was selected SelectionListener call
Re: Custom view and ... ?? [message #198986 is a reply to message #198971] Thu, 13 October 2005 16:32 Go to previous messageGo to next message
Care to share? :)
Re: Custom view and ... ?? [message #199008 is a reply to message #198986] Thu, 13 October 2005 16:48 Go to previous message
Well, no probs, maybe U can answer my D&D question then :)
When I select element on my Editor selectionChanged() is called in View.
This method is called because I've registered selection listener for my
Custom View. Now I need data from selected object. Because I can't get
data directly I'm using IAdaptable to do that. My EditPart implements
IAdapatble and method getAdapter().
public Object getAdapter(Class adapter)
if (adapter.equals(IGeneralProperties.class))
element = ((CallflowElement) getModel());
return new GeneralProperties();
else
return null;
MyEditPart{ ...
private CallflowElement element = (CallflowElement) getModel();
private class GeneralProperties implements IGeneralProperties
//private CallflowElement element;
public void setName(String name)
element.setName(name);
public String getName()
return element.getName();
I'm pasing object of GeneralProperties to a View, and it has
implementation of getProp and setProp methods.
protected void pageSelectionChanged(IWorkbenchPart part,
ISelection selection)
StructuredSelection sel = (StructuredSelection) selection;
if (sel.getFirstElement() instanceof IAdaptable)
if (sel.getFirstElement() instanceof CallflowEditPart)
IGeneralProperties prop = (IGeneralProperties)
((IAdaptable) sel
..getFirstElement()).getAdapter(IGeneralProperties.class);
_viewer.setGeneralProperties(prop);
So in Viewer when somethings changed I can update Model properties.
That's it:)
Greg
> Care to share? :)
Previous Topic:combine two gef plugins via drag&drop
Next Topic:Drag & Drop in GEF
Current Time: Thu Jan 02 20:17:37 GMT 2025
Powered by FUDForum. Page generated in 0.03617 seconds
