Re: Set Node Visible when initialized [message #198614 is a reply to message #198528] |
Wed, 23 July 2008 14:12 |
Guillaume Gauffre Messages: 65 Registered: July 2009 |
Member |
I have another problem concerning these parts of my editor :
I also need to set visible node B and its link to the connection X when
the connection X is selected, and set unvisible the others.
To do that I extend the SelectionEditPolicy class and override the
showPrimarySelection() :
I find the Edge and Node elements that I need to set visible or not but
when I try to use setVisible(), I have an exception like this :
java.lang.IllegalStateException: Cannot modify resource set without a
write transaction
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:338)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:300)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:282)
at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:238)
at
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify (BasicNotifierImpl.java:247)
at
org.eclipse.gmf.runtime.notation.impl.ViewImpl.setVisible(Vi ewImpl.java:228)
Does anybody know why ?
Many thanks !
Guillaume a écrit :
> I have one connection of type X between two nodes of type A.
> When I create such a link, I initialize a reference of this connection
> which refers to a node of type B.
> The resulted figure is a connection X between the 2 nodes of type A and
> another connection between the link X previsouly created and the node of
> type B. So the 2nd connection doesn't map an EClass of my ecore model,
> just a reference between classes X and B.
> My problem is that when I create my connection X, the connection appears
> but the figure B doesn't, except if I create a node or if I reopen the
> diagram.
> And if I delete the connection X, the node B is always displayed, except
> if I reopen the diagram or create a new node.
> How could I resolve this problem, what kind of action is realized during
> the creation of a node which make my node B visible ?
> Thanks.
> Guillaume
Re: Set Node Visible when initialized [message #198750 is a reply to message #198614] |
Thu, 24 July 2008 07:42 |
Originally posted by: eclipse.[REMOVE]stefan-kuhn.eu
use a AbstractTransactionalCommand to do changes to the domain or
notation model.
-stefan
> write transaction
> at
> at
> at
> at
> at
> at
> Many thanks !
> Guillaume a écrit :
>> Hi,
>> connection which refers to a node of type B.
>> and another connection between the link X previsouly created and the
>> node of type B. So the 2nd connection doesn't map an EClass of my
>> ecore model, just a reference between classes X and B.
>> appears but the figure B doesn't, except if I create a node or if I
>> reopen the diagram.
>> except if I reopen the diagram or create a new node.
>> during the creation of a node which make my node B visible ?
>> Thanks.
>> Guillaume
Re: Set Node Visible when initialized [message #198784 is a reply to message #198750] |
Thu, 24 July 2008 09:32 |
Member |
I've just found the trick !
Another quick question : is it possible to get the View object
corresponding to a model element ?
> notation model.
> -stefan
>> when the connection X is selected, and set unvisible the others.
>> but when I try to use setVisible(), I have an exception like this :
>> write transaction
>> at
>> at
>> at
>> at
>> at
>> at
>> Many thanks !
>> Guillaume a écrit :
>>> Hi,
>>> reopen the diagram.
>>> Thanks.
>>> Guillaume
Re: Set Node Visible when initialized [message #198879 is a reply to message #198784] |
Fri, 25 July 2008 05:57 |
you can use the CrossReferenceAdapter (or GMFCrossRef... or similar).
But I wouldn't do that.
-stefan
Guillaume schrieb:
>> notation model.
>> -stefan
>>> write transaction
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Many thanks !
>>> Guillaume a écrit :
>>>> Hi,
>>>> reopen the diagram.
>>>> Thanks.
>>>> Guillaume
FUDForum. Page generated in 0.04106 seconds
