Home » Eclipse Projects » SWTBot » "No tests found"
"No tests found" [message #19594] Wed, 04 February 2009 15:56 Go to next message
David Pochet is currently offline David PochetFriend
Hi all,
I previously used SWTBOT 1.x version, downloaded from SF update site.
I migrated today to 2.0.0.140 version, downloaded from Eclipse.org update
site.
Since that, I'm unable to run SWTBot test cases...
I restarted from the begining, writing a simple test plug-in, with 2
JUnit3 tests cases:
* one simple test case
* one SWTBOT eclipse test case
At runtime (as a SWTBOT run config):
* simple test case runs correctly
* SWTBOT test case is not found:
junit.framework.AssertionFailedError: No tests found in my.DummyBotTest
at junit.framework.Assert.fail(Assert.java:47)
at junit.framework.TestSuite$1.runTest(TestSuite.java:90)
at junit.framework.TestCase.runBare(TestCase.java:130)
at junit.framework.TestResult$1.protect(TestResult.java:106)
at junit.framework.TestResult.runProtected(TestResult.java:124)
at junit.framework.TestResult.run(TestResult.java:109)
at junit.framework.TestCase.run(TestCase.java:120)
at junit.framework.TestSuite.runTest(TestSuite.java:230)
at junit.framework.TestSuite.run(TestSuite.java:225)
at
org.eclipse.jdt.internal.junit.runner.junit3.JUnit3TestRefer ence.run(JUnit3TestReference.java:130)
at
org.eclipse.jdt.internal.junit.runner.TestExecution.run(Test Execution.java:38)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:460)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTe sts(RemoteTestRunner.java:673)
at
org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(R emoteTestRunner.java:386)
at
org.eclipse.swtbot.eclipse.core.RemotePluginTestRunner.main( RemotePluginTestRunner.java:63)
at
org.eclipse.swtbot.eclipse.core.UITestApplication.runTests(U ITestApplication.java:122)
at
org.eclipse.ui.internal.testing.WorkbenchTestable$1.run(Work benchTestable.java:68)
Here is my test case code:
package my;
import org.eclipse.swtbot.eclipse.finder.SWTBotEclipseTestCase;
public class DummyBotTest extends SWTBotEclipseTestCase
public void test_Dummy() throws Exception
bot.shell ( "Dummy Shell Test" ).activate ();
bot.button ();
bot.view ( "Dummy" );
Maybe I missed something?
Thx for your help...
Re: "No tests found" [message #19639 is a reply to message #19594] Wed, 04 February 2009 21:18 Go to previous messageGo to next message
Karen is currently offline KarenFriend
I see the same symptom. Very interested in a response...
Re: "No tests found" [message #19684 is a reply to message #19594] Thu, 05 February 2009 03:59 Go to previous messageGo to next message
Ketan Padegaonkar is currently offline Ketan PadegaonkarFriend
Please hold on. The eclipse CVS/SVN servers are having hiccups after an
uptime of about 1.5 years, and the webmasters are looking into it.
In the meanwhile I'd recommend using the update site at
http://download.eclipse.org/technology/swtbot/dev-build/upda te-site/ and
use revision 2.0.0.133.
There's no api change, so there's probably some configuration missing
between the revisions, that's causing this issue.
-- Ketan
On 4/2/09 21:26, David Pochet wrote:
> Hi all,
> update site.
> JUnit3 tests cases:
> at
> at
> at
> at
> at
> at
> at
> at
> package my;
> bot.button ();
Re: "No tests found" [message #19729 is a reply to message #19684] Thu, 05 February 2009 07:05 Go to previous messageGo to next message
Since yesterday I tried on another computer, with 2.0.0.dev-133
--> same symptoms
After investigations, I found that my test case is considered as if it was
not implementing the Test interface:
* that's why no test methods are found, since the test "while
(Test.class.isAssignableFrom(superClass)) {" (JUnit TestSuite class) is
always failling
* if I try to manually instantiate my class, and force cast to Test
interface, I get a Cast Exception...
Don't understand anymore...
If this is a regression (and not a config error on my side), is it
possible to retrieve an older functionnal SWTBOT build from somewhere?
Re: "No tests found" [message #19750 is a reply to message #19684] Thu, 05 February 2009 08:31 Go to previous messageGo to next message
hugulas chen is currently offline hugulas chenFriend
I still have this problem although I installed the swtbot from dev-build
update site.
Re: "No tests found" [message #19791 is a reply to message #19750] Thu, 05 February 2009 09:25 Go to previous messageGo to next message
I get a workaround:
if I make my class extending JUnit TestCase, and no more
SWTBotEclipseTestCase, and I add the bot instance to my class ("protected
SWTEclipseBot bot = new SWTEclipseBot();"), it just works!
Obviously, I loose the assert & other methods brought by SWTBotTestCase,
but personnaly I don't use them.
However, I'm interresed in knowing the root cause of the issue...
Re: "No tests found" [message #19835 is a reply to message #19791] Thu, 05 February 2009 10:26 Go to previous messageGo to next message
I remove junit 4.5 and remove the bundle=4.5.0 in all manifest.mf.
It works.
The junit 4.5 is broken.
Re: "No tests found" [message #19880 is a reply to message #19791] Thu, 05 February 2009 10:38 Go to previous messageGo to next message
Thanks that's a good feedback for me start with, I appreciate your
investigation. I'll update the build once things are fixed.
-- Ketan
On 5/2/09 14:55, David Pochet wrote:
> I get a workaround:
> ("protected SWTEclipseBot bot = new SWTEclipseBot();"), it just works!
Re: "No tests found" [message #20009 is a reply to message #19880] Thu, 05 February 2009 22:00 Go to previous messageGo to next message
Please make sure the samples swtbot code in the SVN repository works. I
noticed one note in this chain says the code works if you do not use junit
4.5. When I first encountered this error, I was trying to get the
org.rcpmail.test sample code to work so I could get familiar with coding
using swtbot.
Although when I checked it out of CVS, the dependency in the manifest file
said junit 4, there were no annotations in the code, so I changed the
dependency back to junit 3 in my project explorer.
Also, fyi, my results were consistent with David's. If I remove
SWTBotEclipseTestCase and extend junit.framework.TestCase, I do not see
the error. But that doesn't help getting the sample code to run!
Re: "No tests found" [message #20524 is a reply to message #19791] Mon, 09 February 2009 09:34 Go to previous messageGo to next message
Csaba Koncz is currently offline Csaba KonczFriend
Member
The reason for your test cases not implementing junit.framework.Test is
that there are two such interfaces: one in org.junit (which is version 3
and referenced by your test plugin) and one in org.junit4 (used by
SWTBot).
org.junit4 does not require org.junit, it simply duplicates the
junit.framework.* classes, so the two interfaces are not considered the
same.
So when you explicitly implement Test in your test case you get the one
from junit 3.8 (I do not know why) and that's why it works.
Clarification: I have org.junit4_4.3 as, similarly to others, I am unable
to get junit4_4.5 from the update site.
David Pochet wrote:
> I get a workaround:
Re: "No tests found" [message #20540 is a reply to message #20524] Mon, 09 February 2009 16:48 Go to previous messageGo to next message
It is true that junit4 tests do not extend from junit.framework. However,
I looked in the SVN repository and found that the swtbot class
SWTBotTestCase does extend from junit.framework.TestCase. Plus, the
sample code does not contain annotations for junit4. I am not sure how
junit works, but if it finds junit.framework in the heirarchy, does it
automatically enforce junit3 requirements on the test case?
Re: "No tests found" [message #20558 is a reply to message #20540] Tue, 10 February 2009 09:17 Go to previous messageGo to next message
Marc is currently offline MarcFriend
Member
@Karen
If you want the sample code to run, you should try the net.sf version
(see http://swtbot.sourceforge.net/index.html)
At least you'll be able to run the example.
@all
Same problem for me, the workarround mentioned worked for me.
Marc
Re: "No tests found" [message #20567 is a reply to message #20558] Wed, 11 February 2009 09:27 Go to previous messageGo to next message
My workround is
remove org.junit4.5.0 from plugins dir and
replace "org.junit4;bundle-version="4.5.0" to "org.junit4" in all swtbotf
plugin MANIFEST.MF.
Re: "No tests found" [message #20576 is a reply to message #20558] Wed, 11 February 2009 09:51 Go to previous messageGo to next message
I think I've fixed most issues in revision 160 available on the dev
site. What problem and work around are you referring to ?
-- Ketan
On 10/2/09 14:47, Marc wrote:
> @Karen
> @all
> Marc
Re: "No tests found" [message #20584 is a reply to message #20576] Wed, 11 February 2009 10:14 Go to previous messageGo to next message
Member
Unfortunately it seems not.
I've got the 2.0.0.160 update and still faces the "no test found" problem.
org.rcpmail.MyTests_clean
Changing SWTBotEclipseTestCase to TestCase
and adding "protected SWTEclipseBot bot = new SWTEclipseBot();"
is the work around I'm refering to.
Bye
nb: I'll be more explicit next time ;)
> -- Ketan
>> Hi,
>> @Karen
>> @all
>> Marc
Re: "No tests found" [message #24337 is a reply to message #20584] Wed, 25 February 2009 18:08 Go to previous messageGo to next message
If I go back to the net.sf code, I have to change the package names and
apis back to the old ones, yes? I am investigating using swtbot in
creating test cases for our product and developers/testers will not be
happy if they have to learn one api and then port their test cases over to
the new packages/apis.
BTW, I had problems with the junit 4.5 .jar file shipped with swtbot. I
could not get regular junit4 (not swtbot) tests to run and noticed that it
was using the junit 4.5 .jar file shipped with swtbot. When I removed
swtbot from my environment altogether and used the junit .jar file shipped
with Data Studio, then everything was fine and my life was happy again.
IAre these issues going to be fixed anytime soon? I've temporarily
abandoned our swtbot effort because of these problems.
Re: "No tests found" [message #26745 is a reply to message #24337] Fri, 06 March 2009 12:05 Go to previous messageGo to next message
Marko Tomljenovic is currently offline Marko TomljenovicFriend
Member
Hello all,
because of that reason (somehow the test runner assumes that the test is a
JUnit4 test but it is a JUnit 3 test) I have created two base test classes
that contain basically (without taking the screenshot) the same
functionality as the original swtbot testcase classes.
In addition I have reimplemented the runBare() method so that the test
runs in a separate thread to be able to use it in a pde build (not yet
tested).
Maybe some of you could use these classes. Since I have not tested them
with many tests any feedback is appreciated.
PS I am using the dev release 2.0.0 build 187
Here the first class:
import java.util.concurrent.ExecutorService;
import java.util.concurrent.Executors;
import junit.framework.AssertionFailedError;
import junit.framework.TestCase;
import org.eclipse.swt.widgets.Widget;
import org.eclipse.swtbot.swt.finder.SWTBot;
import org.eclipse.swtbot.swt.finder.SWTBotAssert;
import org.eclipse.swtbot.swt.finder.SWTBotTestCase;
import org.eclipse.swtbot.swt.finder.widgets.AbstractSWTBot;
* Class that is more or less a copy from the original {@link
SWTBotTestCase}.
* <p>
* The copy is done because when using the original class the tests are
not running because of
* "AssertionFailedError: No tests found in ...". The reason of that is:
Because of some JUnit4 dependencies in the
* swtbot plugins JUnit4 tests are searched for and not JUnit3 "test.."
methods.
* @author Marko Tomljenovic
public abstract class MySWTBotTestCase extends TestCase {
* Test timeout in milli seconds
protected long timeout = 1800000;
* Overides the runBare method to TestCase to add the ability to capture
a screen shot when an error is thrown. The
* screenshot is saved to a file in the current run directory inside a
folder called {@code screenshots} that gets
* created if it does not already exist. The screenshot will be saved
with the file {@code
* screenshots/screenshot-<classname>.<testname>.png}
* @see junit.framework.TestCase#runBare()
* @throws Throwable Thrown if an error occurs during running.
public void runBare() throws Throwable {
final Throwable[] testThrowables = new Throwable[1];
Runnable test = new Runnable() {
@SuppressWarnings("synthetic-access")
public void run() {
try {
MySWTBotTestCase.super.runBare();
catch (Throwable e) {
testThrowables[0] = e;
final ExecutorService executor = Executors.newSingleThreadExecutor();
final long testStartTime = System.currentTimeMillis();
executor.execute(test);
executor.shutdown();
final Display display = getCurrentDisplay();
if (display != null) {
final Throwable[] uiDispatchThrowable = new Throwable[1];
display.syncExec(new Runnable() {
public void run() {
boolean testFinished = executor.isTerminated();
long testDuration = System.currentTimeMillis() - testStartTime;
// Loop until test is finished
while (!testFinished && (testDuration <
MySWTBotTestCase.this.timeout)) {
// synchronize the ui thread so that the ui events created by
the tests can be processed
int dispatchCtr = 0;
final int maxDispatchBeforeContinueLoop = 100;
try {
while (display.readAndDispatch() && (dispatchCtr <
maxDispatchBeforeContinueLoop)) {
dispatchCtr++;
catch (Exception e) {
uiDispatchThrowable[0] = e;
if (!testFinished) {
throw new AssertionFailedError("The test \"" +
this.getClass().getSimpleName() + "." + getName() +
"\" has not finished in " + MySWTBotTestCase.this.timeout
/ 1000 +
" seconds! Therefore it is assumed that the test has
failed!");
if (uiDispatchThrowable[0] != null) {
throw uiDispatchThrowable[0];
if (testThrowables[0] != null) {
throw testThrowables[0];
* @return the swt display for the currently active swt based
application.
protected Display getCurrentDisplay() {
return Display.getCurrent();
* An instance of SWTBot that may be used
protected SWTBot bot = new SWTBot();
* Asserts that two widgets do not refer to the same object.
* @see #assertNotSame(String, Object, Object)
* @param expected the object you don't expect
* @param actual the object to compare to unexpected
public static void assertNotSameWidget(final Widget expected, final
Widget actual) {
SWTBotAssert.assertNotSameWidget(expected, actual);
* Asserts the two widgets do not refer to the same object. The message
will be used if the test fails.
* @param message the identifying message or null for the AssertionError
public static void assertNotSameWidget(final String message, final
Widget expected, final Widget actual) {
SWTBotAssert.assertNotSameWidget(message, expected, actual);
* Asserts that the <code>needle</code> is contained within the
<code>hayStack</code>.
* @param needle the text to search in the <code>hayStack</code>.
* @param hayStack the text to look within.
public static void assertContains(final String needle, final String
hayStack) {
SWTBotAssert.assertContains(needle, hayStack);
* Asserts that the <code>needle</code> is not present in the
public static void assertDoesNotContain(final String needle, final
String hayStack) {
SWTBotAssert.assertDoesNotContain(needle, hayStack);
* Asserts that two widgets refer to the same widget.
* @param expected the expected widget
* @param actual the widget to compare to expected
public static void assertSameWidget(final Widget expected, final Widget
actual) {
SWTBotAssert.assertSameWidget(expected, actual);
* Asserts that two widgets refer to the same widgets.
* @param message the identifying message or <code>null</code> for the
AssertionError
public static void assertSameWidget(final String message, final Widget
SWTBotAssert.assertSameWidget(message, expected, actual);
* Assert that the given string is the same as the widgets text.
* @param expected the expected text
* @param widget the widget to get the text from to compare.
public static void assertText(final String expected, final Widget
widget) {
SWTBotAssert.assertText(expected, widget);
AbstractSWTBot<? extends Widget> widget) {
* Assert that the text on the widget contains the expected text.
* @param expected the expected text.
public static void assertTextContains(final String expected, final
Widget widget) {
SWTBotAssert.assertTextContains(expected, widget);
* Assert that the text on the widget does not contain the expected text.
public static void assertTextDoesNotContain(final String expected, final
Widget widget) {
SWTBotAssert.assertTextDoesNotContain(expected, widget);
* Asserts that the widget is enabled.
* @param widget the widget.
public static void assertEnabled(final AbstractSWTBot<? extends Widget>
widget) {
SWTBotAssert.assertEnabled(widget);
* Asserts that the widget is not enabled.
public static void assertNotEnabled(final AbstractSWTBot<? extends
Widget> widget) {
SWTBotAssert.assertNotEnabled(widget);
* Asserts that the widget is visible.
public static void assertVisible(final AbstractSWTBot<? extends Widget>
widget) {
SWTBotAssert.assertVisible(widget);
* Asserts that the widget is not visible.
public static void assertNotVisible(final AbstractSWTBot<? extends
Widget> widget) {
SWTBotAssert.assertNotVisible(widget);
And the second one as well:
import org.eclipse.swtbot.eclipse.finder.SWTEclipseBot;
import org.eclipse.ui.PlatformUI;
* This is a wrapper test case to the {@link MySWTBotTestCase} that adds
an eclipse bot instead of the standard bot.
public abstract class MySWTBotEclipseTestCase extends MySWTBotTestCase {
* {@inheritDoc}
return PlatformUI.getWorkbench().getDisplay();
* An instance of SWTEclipseBot.
Re: "No tests found" [message #26784 is a reply to message #26745] Fri, 06 March 2009 12:28 Go to previous messageGo to next message
Member
There is a small bug in the first class.
Add the following line:
after this line:
Sorry for that :)
Re: "No tests found" [message #26825 is a reply to message #26745] Fri, 06 March 2009 13:03 Go to previous messageGo to next message
Hi Marko,
Thanks for this input. I think I understand what the problem has been
all along.
I'd like to clarify that SWTBot does work with junit3 style tests, but
you need to depend on the junit4 plugin in order to do this.
The reason for this is the fact that the SWTBot launcher is compiled
against JUnit 4.x and gets confused when it sees your tests are running
against junit 3.x.
Could you please verify this behavior ? I'll update the user guide and
documentation about this particular case, the documentation is quite out
of date, and has not been updated in a while after the move to junit4.
-- Ketan
On 6/3/09 17:35, Marko Tomljenovic wrote:
> Hello all,
> a JUnit4 test but it is a JUnit 3 test) I have created two base test
> classes that contain basically (without taking the screenshot) the same
> tested).
> import org.eclipse.swt.widgets.Display;
> SWTBotTestCase}.
> * <p>
> methods.
> * * @author Marko Tomljenovic
> * * @see junit.framework.TestCase#runBare()
> @Override
> @Override
> public void run() {
> try {
> @Override
> public void run() {
> while (!testFinished && (testDuration < MySWTBotTestCase.this.timeout)) {
> // synchronize the ui thread so that the ui events created by the tests
> can be processed
> try {
> dispatchCtr++;
> "\" has not finished in " + MySWTBotTestCase.this.timeout / 1000 +
> " seconds! Therefore it is assumed that the test has failed!");
> * @return the swt display for the currently active swt based application.
> * * @see #assertNotSame(String, Object, Object)
> Widget actual) {
> * * @param message the identifying message or null for the AssertionError
> * * @param needle the text to search in the <code>hayStack</code>.
> hayStack) {
> String hayStack) {
> * * @param expected the expected widget
> actual) {
> * * @param message the identifying message or <code>null</code> for the
> AssertionError
> * * @param expected the expected text
> public static void assertText(final String expected, final Widget widget) {
> * * @param expected the expected text.
> Widget widget) {
> Widget widget) {
> * * @param widget the widget.
> widget) {
> Widget> widget) {
> widget) {
> Widget> widget) {
> * {@inheritDoc}
> @Override
Re: "No tests found" [message #26865 is a reply to message #26825] Fri, 06 March 2009 14:05 Go to previous messageGo to next message
Member
if you tell me how I can verifiy that I will do it!
What I can tell you is that if my test is subclassing from SWTBotTestCase
and I run it using the swtbot launcher I always get the message: No tests
found...
Greets Marko
Re: "No tests found" [message #27103 is a reply to message #26825] Tue, 10 March 2009 16:45 Go to previous messageGo to next message
Madhu Samuel is currently offline Madhu SamuelFriend
Hello Ketan,
I have updated the section "Getting started with SWTBot for Eclipse
Plugins" in the User Guide.
Madhu
Re: "No tests found" [message #27142 is a reply to message #27103] Wed, 11 March 2009 10:32 Go to previous message
Kay-Uwe Graw is currently offline Kay-Uwe GrawFriend
I also have the no tests found error. My context in detail:
I have a plugin MyExtendedSWTBot with some additional functionality to
swtbot which depends on org.eclipse.swtbot.eclipse.finder,
org.eclipse.swtbot.swt.finder and org.junit (3.8.2) which are also
re-exported. I've written tests for my rcp application MyApplication which
are in an extra plugin MyApplicationTest. This plugin depends on
MyExtendedSWTBot.
Everything works fine with the last developer version from the old update
site swtbot 2.0.167. When I move to swtbot 2.0.187 I get the "No tests
found" - error. When I make MyExtendedSWTBot depending on org.junit4
(4.3.1) I get the exception:
No Classloader found for plug-in MyApplicationTest.
Based on Marko's idea I use the following solution:
I simply copy the classes SWTBotTestCase and SWTBotEclipseTestCase into
MyExtendedSWTBot and make SWTBotEclipseTestCase extend from the local
version of SWTBotTestCase instead from the original SWTBotTestCase class.
If I now extend my Tests from the "new" SWTBotEclipseTestCase class
erverything works fine again if MyExtendedSWTBot depends on org.junit
(3.8.2). With dependency to org.junit4 (4.3.1) I get the Classloader
exception as well.
It looks, there are still some unresolved org.junit 3<>4 issues. Anyway, I
can live with this solution but hopefully this will be solved properly.
Previous Topic:Improvement for captureScreenshot
Next Topic:Getting menu from chevron (drop down arrow)
Current Time: Mon Jan 13 20:13:29 GMT 2025
Powered by FUDForum. Page generated in 0.06120 seconds
