Home » Eclipse Projects » GEF » How to get the correct zoomManger when using a MultiPageEditorPart
How to get the correct zoomManger when using a MultiPageEditorPart [message #197089] Thu, 29 September 2005 15:22 Go to next message
drew frantz is currently offline drew frantzFriend
I have added a ZoomComboContributionItem to the ActionBarContributor for the
MultiPageEditorPart. The ZoomComboContributionItem uses a partListener to
call setZoomManager based on the partActivated call. Unfortuneatly
partActivated does not get called when page activation chnages in the
MultiPageEditorPart. So i get the last active zoomManager .
I dropped a selectListener off the ZoomComboContributionItem and this seems
to work , but seem a bit heavy for this purpose. Any other lighter ideas?
IWorkbenchPage wp = getPage();
final ZoomComboContributionItem zitem = new ZoomComboContributionItem(wp);
toolBarManager.add(zitem);
wp.addSelectionListener( new ISelectionListener()
// a selection listsner seems a bit heavy
// for this purpose, but it is one way to
// get the correct zoomManager after the active page
// chnages in the MultiPageEditorPart
public void selectionChanged(IWorkbenchPart part, ISelection selection)
zitem.setZoomManager((ZoomManager) part.getAdapter(ZoomManager.class));
Re: How to get the correct zoomManger when using a MultiPageEditorPart [message #197126 is a reply to message #197089] Thu, 29 September 2005 18:41 Go to previous messageGo to next message
Create your own MultiPageZoomManager, and call setPage(ZoomManager delegate)
when you switch pages. Then fire zoom level property changed event and the
combo should update.
"Drew" <drew@acm.org> wrote in message news:dhh0sb$2a4$1@news.eclipse.org...
>the
> seems
Re: How to get the correct zoomManger when using a MultiPageEditorPart [message #197139 is a reply to message #197089] Thu, 29 September 2005 19:30 Go to previous messageGo to next message
Your ActionBarContributor should be a
MultiPageEditorActionBarContribitor. Then you will get notified whenever
the active page changes (setActivePage() will be called). As far as I
know, this is the simplest solution.
Martijn.
Re: How to get the correct zoomManger when using a MultiPageEditorPart [message #197273 is a reply to message #197139] Fri, 30 September 2005 15:31 Go to previous messageGo to next message
This works perfectly for the ZoomComboContributionItem , but then the other
things that the GEF ActionBarContributor provides like addGlobalActionKey &
addRetargetAction no longer work since there is a bunch of action plumbing
that ActionBarContributor adds.
"Martijn van Steenbergen" <mvsteenbergen@eljakim.scratch-this.nl> wrote in
message news:dhhfcm$oed$1@news.eclipse.org...
the
to
> Regards,
> Martijn.
Re: How to get the correct zoomManger when using a MultiPageEditorPart [message #197289 is a reply to message #197273] Fri, 30 September 2005 16:25 Go to previous message
I worked around by using the orignl impl of ActionBarContributor and setting
setting a reference to the ZoomComboContributionItem in
public void setActiveEditor(IEditorPart part) {
super.setActiveEditor(part);
if (part instanceof NotationMultiPageEditor)
NotationMultiPageEditor p = (NotationMultiPageEditor) part;
p.setZoomComboContributionItem(zitem);
// Then in the MPE.
protected void pageChange(int newPageIndex)
super.pageChange(newPageIndex);
if(myItemHack != null)
myItemHack.setZoomManager((ZoomManager)
this.getActiveEditor().getAdapter(ZoomManager.class));
"Drew" <drew@acm.org> wrote in message news:dhjlo4$kh2$1@news.eclipse.org...
other
for
> the
> to
> > Regards,
> > Martijn.
Previous Topic:GEF in ViewPart, TableWrapLayout
Next Topic:Draw2d FigureCanvas scrollbar visibility issue
Current Time: Wed Feb 05 06:47:26 GMT 2025
Powered by FUDForum. Page generated in 0.03102 seconds
