ScalableFreeformRootEditPart [message #195304] |
Fri, 09 September 2005 12:39 |
Originally posted by: greg.gigon.tugulu.com
It looks like ScalableFreeformRootEditPart has GridLayer() in it but it
doesn't display.
How to make it work? Do I need to override some methods?
Greg
Re: ScalableFreeformRootEditPart [message #195319 is a reply to message #195304] |
Fri, 09 September 2005 13:46 |
Originally posted by: mvsteenbergen.eljakim.scratch-this.nl
Take a look at how ToggleGridAction does it.
> doesn't display.
> Greg
Re: ScalableFreeformRootEditPart [message #195332 is a reply to message #195319] |
Fri, 09 September 2005 14:00 |
Is it enought to initiate class in order to make Grid visible?
What should be the moment to do that?
Greg
>> it doesn't display.
>> Greg
Re: ScalableFreeformRootEditPart [message #195364 is a reply to message #195332] |
Fri, 09 September 2005 15:52 |
Originally posted by: none.unknown.com
Greg, as Martijn suggested, look at ToggleGridAction to see how to turn the
grid on and off. You can see how the logic example uses this. You can set
the grid enablement properties on the viewer in your editor's
configureGraphicalViewer() method. If the grid's still not visible you
probably have an opaque layer (such as your primary layer) above the grid
layer that's preventing it from being seen. If that is the case, snapping
to grid should still work (although the grid itself won't be visible). Just
ensure that you're not invoking setOpaque(true) on any of the layers.
"Greg" <greg.gigon@tugulu.com> wrote in message
news:dfs4ic$eh2$1@news.eclipse.org...
> Greg
> >> it doesn't display.
> >> Greg
Re: ScalableFreeformRootEditPart [message #195598 is a reply to message #195364] |
Mon, 12 September 2005 08:49 |
I'm adding these two lines to my Editor:
ToggleGridAction grid = new ToggleGridAction(graphicalViewer);
getActionRegistry().registerAction(grid);
and I'm not setting any of layers by myself. I'm using
ScalableFreeformRootEditPart which seems to be seting Layers by itself.
Grid is still not visible. Do I need to use this registered action
somewhere in order to turn the GRID on??
Gregory
Ps. Sorry that my questions are so LAME :)
>>Greg
>>>>it doesn't display.
>>>>Greg
Re: ScalableFreeformRootEditPart [message #195653 is a reply to message #195598] |
Mon, 12 September 2005 16:04 |
news:dg3fe3$8mr$1@news.eclipse.org...
The action is to turn the grid on or off. Creating that action doesn't turn
the grid on. You need to set the grid properties for that. The logic
editor does that in its loadProperties() method. The ToggleGridAction
toggles those properties in its run method. So you should look at either
one of those to see what properties you need to set.
> Gregory
the
set
grid
snapping
Just
> >>Greg
> >>>>it doesn't display.
> >>>>Greg
Re: ScalableFreeformRootEditPart [message #195723 is a reply to message #195653] |
Tue, 13 September 2005 08:37 |
Well that was good enought :)
Thank You Pratik.
It's shame there's no book that will say in order to provide "this" with
GEF do "that" :)
Java DOC doesn't explain a lot of simple actions in order to provide
simple functionality.
Greg
>>Gregory
> the
> set
> grid
> snapping
> Just
>>>>Greg
>>>>>>it doesn't display.
>>>>>>Greg
FUDForum. Page generated in 0.02958 seconds
