Home » Language IDEs » Java Development Tools (JDT) » Difficulty Getting Ant to Run in Eclipse 3.0.1
Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195250] Wed, 09 February 2005 16:50 Go to next message
I am finally moving from Eclipse 2.1.2 to 3.0.1. I've had some ant scripts
in 2.1.2 that compliled java code and ran junit tests. I have been unable
to get them to run in 3.0.1. When I right click on build.xml and do a Run
-> Ant Build, there is no output to the console and no entry in the
<workspace>/.metadata/.log. I also tried to run the "Hello World" script
from the help doc, but had the same results. I can run the Junit tests
from within eclipse so my project has all the proper libraries in the
build path. Is there some basic setup of classpath or properties in the
external tools dialog required in 3.0.1 to run a basic ant script?
Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195264 is a reply to message #195250] Wed, 09 February 2005 17:20 Go to previous messageGo to next message
When you do Run-->Ant Build... are any problems reported?
Darins
"Joe Gliniecki" <jgliniecki@yahoo.com> wrote in message
news:cue0ip$fiu$1@www.eclipse.org...
> Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195272 is a reply to message #195264] Wed, 09 February 2005 17:29 Go to previous messageGo to next message
Nope, no problems, so doesn't appear to be an XML parsing error or
anything like that. When I do Run-->Ant Build, its as if I didn't click on
anything. No change in any of the windows, no dialogs, and nothing in the
log.
> Darins
>> Thanks,
>> Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195277 is a reply to message #195272] Wed, 09 February 2005 17:43 Go to previous messageGo to next message
In the debug view is any launch created?
Do you have the builds set to capture output on the Main tab of the launch
configuration?
If you create a new buildfile and attempt to run it any better success? That
is, is this a migration issue with 2.1.2 create launch configurations?
HTH
Darins
news:cue2t4$p6f$1@www.eclipse.org...
> log.
> > Darins
scripts
unable
Run
script
> >> Thanks,
> >> Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195285 is a reply to message #195277] Wed, 09 February 2005 17:54 Go to previous messageGo to next message
Yes, I forgot to mention that. I did check the debug view, but there
wasn't anything running. Also the capture output checkbox is checked on
the main tab of the config window.
I did create a new project and a new build file with the "Hello World" ant
script from the helpdoc that basically just does an echo, but get the same
results.
Is there any kind of general environment variable that needs to be set or
jar from Apache that needs to be installed? I've been assuming that
eclipse would have everything it needed to run a trivial "Hello World" ant
script, but maybe I'm missing something.
Joe
> configuration?
> HTH
> Darins
>> log.
>> > Darins
> scripts
> unable
> Run
> script
>> >> Thanks,
>> >> Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195293 is a reply to message #195285] Wed, 09 February 2005 18:04 Go to previous messageGo to next message
I am puzzled.
Out of the box Eclipse 3.0.1 has all that is needed to run your basic Ant
buildfiles.
Go to the Ant Runtime classpath preference page. Please list what is
included there?
Window>Preferences>Ant>Runtime>Classpath
Try hitting "Restore Defaults"
Can you please explain exactly how you installed and migrated to 3.0.1?
out on your disk where Eclipse is installed can you verify that the
following JARs exist:
.../plugins/org.eclipse.ant.core_3.0.0/lib/antsupportlib.jar
.../plugins/org.eclipse.ant.ui_3.0.1/lib/antrunner.jar
.../plugins/org.eclipse.ant.ui_3.0.1/lib/remoteAnt.jar
If all this fails can you try Eclipse 3.0.1 with a new workspace and see if
you have success?
Darins
news:cue4as$v2m$1@www.eclipse.org...
> results.
> Joe
launch
> > configuration?
That
> > HTH
> > Darins
on
the
> >> log.
> >> > Darins
> > scripts
> > unable
a
> > Run
> > script
tests
the
the
> >> >> Thanks,
> >> >> Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195301 is a reply to message #195293] Wed, 09 February 2005 18:24 Go to previous messageGo to next message
Darwin,
The jars were all there in the plugins directory. I did try starting
eclipse where I pointed to a new workspace and the trivial ant script
worked! So aparently something is corrupted in the original workspace.
Surprising though, since I've been pointing the 3.0.1 install to its own
workspace from the start (didn't reuse the 2.1 workspace). Also surprising
in how it failed (no error messages, nothting output to the console).
Anyhow, I should be on my way now. I'll just delete the old workspace.
Thanks for all your help!!
-Joe
> I am puzzled.
> buildfiles.
> included there?
> you have success?
> Darins
>> results.
>> Thanks,
>> Joe
> launch
>> > configuration?
> That
>> > HTH
>> > Darins
> on
> the
>> >> log.
>> >> > Darins
>> > scripts
>> > unable
> a
>> > Run
>> > script
> tests
> the
> the
>> >> >> Thanks,
>> >> >> Joe
Re: Difficulty Getting Ant to Run in Eclipse 3.0.1 [message #195308 is a reply to message #195301] Wed, 09 February 2005 18:30 Go to previous message
I agree this is way less than optimal but you are the first case that I am
aware of and I have no way to know what happened nor how to fix for better
error reporting??
If it happens again and you have a notion on how it happened please log a
bug report so I can fix the problem.
> -Joe
Thanks for sticking with us.
Previous Topic:Custom Problem Marker Attributes?
Next Topic:Make nested class to "normal" class
Current Time: Tue Nov 04 04:23:02 EST 2025
Powered by FUDForum. Page generated in 0.34348 seconds
