Question about a ZoomManager method [message #194853] |
Tue, 06 September 2005 14:18 |
Originally posted by: harsh.ti.com
Partik/Randy,
Just wondering about the following function in ZoomManager
* Currently does nothing.
* @param rect a rectangle
public void zoomTo(Rectangle rect) { }
Are there any plans to implement this in a future release? If so, how
would it work? I am working on something similar right now. Thank you,
Harsh
Re: Question about a ZoomManager method [message #194883 is a reply to message #194853] |
Tue, 06 September 2005 14:52 |
Originally posted by: none.unknown.com
I believe no implementation's provided because nobody has asked for it,
until now. The expected behaviour would be to animate zooming in (or out)
to the given rectangle. Any contributions are always welcome. ZoomManager
has a commented-out method, performAnimatedZoom(), that will give you an
idea about how to do this. It's probably got some bugs though; I don't
think it was ever tested thoroughly.
"Harsh" <harsh@ti.com> wrote in message
news:b092d14d20df1c8bcd2b4f901adc44cb$1@www.eclipse.org...
> Partik/Randy,
> Harsh
Re: Question about a ZoomManager method [message #194912 is a reply to message #194890] |
Tue, 06 September 2005 17:10 |
I looked at the performAnimatedZoom() method but found a few issues with
it. First of all, shouldn't it zoom to the dimensions of the rectangle
and not the next zoom level? Secondly, because it zooms to a predefined
zoom level, it doesn't calculate to see if the rectangle we are zooming
into is still visible.
Keeping those two issues in mind, I went ahead and started to code my
"custom" zoom but it is not working properly. Here is the code snippet...
LogicEditPart leditPart = (LogicEditPart)focusEditPart;
Dimension desired = leditPart.getFigure().getSize();
Dimension available = getViewport().getClientArea().getSize();
//The figure
Rectangle rectFig = leditPart.getFigure().getBounds();
IFigure fig = leditPart.getFigure();
double scaleX = available.width * getZoom() / desired.width;
double scaleY = available.height * getZoom() / desired.height;
double desiredZoom = Math.min(scaleX, scaleY);
//primSetZoom is defined in the ZoomManager class
primSetZoom(desiredZoom);
getScalableFigure().translateToRelative(rectFig);
getViewport().setViewLocation(rectFig.x, rectFig.y);
getViewport().getUpdateManager().performUpdate();
Basically, what I am trying to do is take the bounds of the figure divide
it by what's available to figure out the zoom in ratio. Zoom in to that
ratio, translate the figure so it's coordinates are relative to the
parent. Then set the view location to be where the figure is and update.
Did I miss something?
Thank you,
Harsh
Re: Question about a ZoomManager method [message #194920 is a reply to message #194912] |
Tue, 06 September 2005 17:55 |
I believe that the commented out code worked for the click-to-zoom case. So,
it was centered about the point where you clicked. The method takes a
rectangle since it would also work with a dragged zoom rect. But, the code
never handled that case. It's also not clear how you would zoom out to a
rectangle.
news:d7a937cdda24119516a60271b7b2513d$1@www.eclipse.org...
>it. First of all, shouldn't it zoom to the dimensions of the rectangle and
>not the next zoom level? Secondly, because it zooms to a predefined zoom
>level, it doesn't calculate to see if the rectangle we are zooming into is
>still visible.
> //The figure
> Thank you,
> Harsh
FUDForum. Page generated in 0.03450 seconds
