Home » Eclipse Projects » GEF » one kind of children in one editpart - limitation of gef???
one kind of children in one editpart - limitation of gef??? [message #192577] Fri, 19 August 2005 23:18 Go to next message
Yong cheng is currently offline Yong chengFriend
Member
I have now one problem in my editpart. For example A has B and C as
children. The method getModelChildren in editpart of A can only return one
kind of children (B or C, but not together). The only solution seems to be
let B and C inherit one parent(e.g. D). But that means that B and C should
share one editpart. Is that correct? What I need is the totally different
editparts for B and C. How can I do this?
If I have understood gef correctly, there are a lot of limitations for
building models for gef. How can I hide some model elements in graphics?
For example A has B as children, and B has C as children. But I just want
to show A and C in my graphics. B is only important in model. And how can
I show children figures seprated from the parent figures?
Has anyone solutions for the problems mentioned above?
Thanks a lot
nice weekend
lucia
Re: one kind of children in one editpart - limitation of gef??? [message #192592 is a reply to message #192577] Sat, 20 August 2005 09:27 Go to previous messageGo to next message
Andreas Holtz is currently offline Andreas HoltzFriend
Member
lucia schrieb am 20.08.2005 01:18:
> one kind of children (B or C, but not together).
getModelChildren returns a *List* with B and C in it. Based on this list, your EditpartFactory creates the corresponding editparts
(editPartB and editPartC).
> to be let B and C inherit one parent(e.g. D). But that means that B and
> C should share one editpart. Is that correct? What I need is the totally
> different editparts for B and C. How can I do this?
your editpartfactory tests on the instances of the model and returns the correct editpart:
<-- snip --->
public class ActivityDiagramEditPartFactory implements EditPartFactory {
private EditPart itsEditPart;
public EditPart createEditPart(EditPart context, Object model) {
if (model instanceof A) {
itsEditPart = new A_EditPart();
itsEditPart.setModel(model);
} else if (model instanceof B) {
itsEditPart = new B_EditPart();
} else if (model instanceof C) {
itsEditPart = new C_EditPart();
<--- snip -->
really? i think the only limitation is, that your model must support the observer pattern.
> want to show A and C in my graphics. B is only important in model.
you can hide figures by using a layer (but i think they can't contain children with this solution).
protected IFigure createFigure() {
return new Layer();
or if it should contain children (like in your example B contains C):
Figure figure = new Figure();
figure.setLayoutManager(new ADraw2DLayout());
return figure;
> And
> how can I show children figures seprated from the parent figures?
> Thanks a lot
> nice weekend
> lucia
Andreas
PS: you _should_ really inspect (or even recode) the given examples linked on the GEF page.
Re: one kind of children in one editpart - limitation of gef??? [message #192600 is a reply to message #192577] Sat, 20 August 2005 09:40 Go to previous messageGo to next message
> want to show A and C in my graphics. B is only important in model. And
in the getModelChildren() method of the A edit part, return the result
of summing up all C's from all B children, like
List result = ...
for all b children
for all b.c children
result.add(c)
return result;
Thus, the graphics will only show A's with C children.
dont understand. What do you mean by "separated"?
christian
??: one kind of children in one editpart - limitation of gef??? [message #192608 is a reply to message #192592] Sat, 20 August 2005 10:37 Go to previous messageGo to next message
Member
Hi, Andreas,
Thank you for your answer. But...
I've tried this exactly as you said. My model is as following:
public interface A extends EObject{
* @model
EList getBs();
* @model
EList getCs();
And the editpart of A has the following method:
protected List getModelChildren() {
List list = getA().getBs();
list.addAll(getA().getCs());
return list;
And I got the error message:
java.lang.ArrayStoreException
at org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:187)
at
org.eclipse.emf.common.util.BasicEList.addAllUnique(BasicELi st.java:772)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:428)
at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:367)
at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:686)
at
wzl.cosmos.engr.ganttcharteditor.parts.A_EditPart.getModelCh ildren(A_EditPart.java:75)
It will be ok if I just return getA().getBs() or getA().getCs().
Can you explain this?
thanks in advance
Lucia
Re: ??: one kind of children in one editpart - limitation of gef??? [message #192617 is a reply to message #192608] Sat, 20 August 2005 10:53 Go to previous messageGo to next message
Originally posted by: Sebastian.Zarnekow.gmx.de
Hi Lucia,
A.getBs() returns the list by reference. If you try to add Cs to the list
of Bs, the underlying implementation of EList throws the exception.
Try the following:
List list = new ArrayList( getA().getBs() );
return list;
Sebastian
L> Hi, Andreas,
L>
L> Thank you for your answer. But...
L>
L> I've tried this exactly as you said. My model is as following:
L> ##############################################
L> public interface A extends EObject{
L> /**
L> * @model
L> */
L> EList getBs();
L> /**
L> * @model
L> */
L> EList getCs();
L> }
L> ###############################################
L>
L> And the editpart of A has the following method:
L> protected List getModelChildren() {
L> List list = getA().getBs();
L> list.addAll(getA().getCs());
L> return list;
L> }
L> And I got the error message:
L> ############################################################ #########
L> ######
L> java.lang.ArrayStoreException
L> at
L> org.eclipse.emf.common.util.BasicEList.assign(BasicEList.jav a:187)
L> at
L> org.eclipse.emf.common.util.BasicEList.addAllUnique(BasicELi st.java:7
L> 72)
L> at
L> org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(Not
L> ifyingListImpl.java:428)
L> at
L> ifyingListImpl.java:367)
L> at
L> org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:686)
L> at
L> wzl.cosmos.engr.ganttcharteditor.parts.A_EditPart.getModelCh ildren(A_
L> EditPart.java:75)
L> #######
L>
L> It will be ok if I just return getA().getBs() or getA().getCs().
L>
L> Can you explain this?
L>
L> thanks in advance
L>
L> Lucia
L>
Re: ??: one kind of children in one editpart - limitation of gef??? [message #192625 is a reply to message #192617] Sat, 20 August 2005 12:56 Go to previous messageGo to next message
Member
Hi, Sebastian,
that's it. Thanks.
Lucia
Thank you very much for all your help! [message #192945 is a reply to message #192577] Tue, 23 August 2005 19:48 Go to previous message
Member
Andreas, Christian, Sebastian,
Previous Topic:GuideLineFigure not visible
Next Topic:Curriculum Vitae
Current Time: Wed Feb 05 17:05:36 GMT 2025
Powered by FUDForum. Page generated in 0.04313 seconds
