Home » Eclipse Projects » GEF » F2 key problem!!!
F2 key problem!!! [message #188971] Mon, 25 July 2005 09:40 Go to next message
Originally posted by: gautamn.iitk.ac.in
my direct edit is working fine when I double click a figure but when I
press F2 key CellEditLocator doesn't appears. I have put all the necessary
code.What do to??
Nitin.
Re: F2 key problem!!! [message #189008 is a reply to message #188971] Mon, 25 July 2005 15:12 Go to previous messageGo to next message
Originally posted by: none.unknown.com
I suppose you have a GraphicalViewerKeyHandler that handles that keystroke.
Set a breakpoint in its keyPressed() method to see why it's not being
handled properly.
"Nitin Gautam" <gautamn@iitk.ac.in> wrote in message
news:5a91bd9ba269a17e43f715b81dc1dc9d$1@www.eclipse.org...
> code.What do to??
> Regards,
> Nitin.
Re: F2 key problem!!! [message #190312 is a reply to message #189008] Wed, 03 August 2005 10:44 Go to previous messageGo to next message
While I debugged my code using Sys.out.println I found that no event is
generated when I pressed F2 key..What to do???
Nitin.
Re: F2 key problem!!! [message #190391 is a reply to message #190312] Wed, 03 August 2005 18:00 Go to previous messageGo to next message
That's not possible; you're most likely doing something wrong. Are you
using the GraphicalViewerKeyHandler and adding a KeyStroke to it for
handling F2?
news:c2648f50057846bbee223543e7437a73$1@www.eclipse.org...
> Regards,
> Nitin.
Re: F2 key problem!!! [message #190481 is a reply to message #190391] Thu, 04 August 2005 05:11 Go to previous messageGo to next message
Yes I am ....In configure viewer method .... I worte the following code
ScrollingGraphicalViewer
viewer=(ScrollingGraphicalViewer)getGraphicalViewer();
viewer.setKeyHandler(new
GraphicalViewerKeyHandler(viewer).setParent(getCommonKeyHand ler()));
and the following method for enabling F2 key...
protected KeyHandler getCommonKeyHandler() {
if (sharedKeyHandler == null){
System.out.println("In shared ky hander");
sharedKeyHandler = new KeyHandler();
sharedKeyHandler.put(
KeyStroke.getPressed(SWT.F2, 0),
getActionRegistry().getAction (GEFActionConstants.DIRECT_EDIT));
return sharedKeyHandler;
I want to catch events fired when I press some key.I do not know what to
do in this situation. Kindly, suggest something...
Nitin Gautam.
Re: F2 key problem!!! [message #190699 is a reply to message #190481] Fri, 05 August 2005 16:09 Go to previous messageGo to next message
You're saying keyPressed() is never called in the key handler? Set a
breakpoint in that method. If it's not getting called set a breakpoint in
DomainEventDispatcher#dispatchMousePressed() and step into the code to see
why it doesn't get to the key handler. Compare it to the execution in the
logic example to see how it's supposed to work.
news:ef0549dfc05a91a417af8c45a782829c$1@www.eclipse.org...
> Regards,
> Nitin Gautam.
Re: F2 key problem!!! [message #190978 is a reply to message #190699] Mon, 08 August 2005 09:03 Go to previous message
Now its working fine ....i not entered directedit it in create actions
method...
thanx
Nitin.
Previous Topic:Grid without ScalableFreeformRootEditPart
Next Topic:How to expend the tree in GEF TreeViewer
Current Time: Thu Dec 26 16:20:56 GMT 2024
Powered by FUDForum. Page generated in 0.04252 seconds
