'Bundle Activator invalid' exceptions in I20040127 builds and later on OS X [message #188004] |
Sun, 01 February 2004 17:23  |
On OS X, I am getting the following exception when 3rd party plugins are
loaded in I20040127 (3.0 stream) builds and later:
!MESSAGE Plug-in com.teaminabox.eclipse.wiki was unable to load class
com.teaminabox.eclipse.wiki.editors.WikiEditor.
!STACK 0
org.osgi.framework.BundleException: The BundleActivator
com.teaminabox.eclipse.wiki.WikiPlugin is invalid
at
org.eclipse.osgi.framework.internal.core.Bundle.loadBundleAc tivator(Bundle.java:176)
at
org.eclipse.osgi.framework.internal.core.BundleContext.start (BundleContext.java:987)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:403)
(I used the wiki editor as an example - lots of others plugins have the
same problem.)
Before raising a bug I wanted to check if its simply a case of the
plugins needing updating.
The example plugins load properly so I suspect this is the case.
Has anyone else found this problem?
regards,
Channing
FUDForum. Page generated in 0.11746 seconds
