String Substitution feature in JSP with tomcat doesnt work?! [message #187691] |
Wed, 07 February 2007 09:54  |
Hi folks,
I'm wondering if it is possible to dynamically change token for ant that
are present in my jsp with the dynamic string substitution in jsp inside
tomcat. Right now, I'm loading the bootstrap with my runner and pointing
to my application. Tomcat work great. In preference, I've put some token
like @STATIC_URL@ that should replace by something else. Those token are
found essentially in JSP files.
But It seem that Tomcat goes directly to the source of the jsp and
does'nt really care about the string substition of eclipse. Is there a way
to do that?
Re: String Substitution feature in JSP with tomcat doesnt work?! [message #187708 is a reply to message #187691] |
Wed, 07 February 2007 11:05  |
When your project is published to a server to be run, the WebContent
resources are simply copied. There is no special processing done.
Given that JSPs can generate dynamic output, I would think there would
be ways to accomplish what you want using the features of JSP.
Larry
Ben.Liard wrote:
> Hi folks,
> are found essentially in JSP files.
> way to do that?
FUDForum. Page generated in 0.03355 seconds
