Home » Language IDEs » Java Development Tools (JDT) » ClassFormatException in Java11 while compiling JSP pages
ClassFormatException in Java11 while compiling JSP pages [message #1871373] Mon, 23 September 2024 14:13 Go to next message
Prudviraj D is currently offline Prudviraj DFriend
Stacktrace:
MESSAGE:Compilation error
org.eclipse.jdt.internal.compiler.classfmt.ClassFormatException
at org.eclipse.jdt.internal.compiler.classfmt.ClassFileReader.<init>(ClassFileReader.java:298)[44:org.apache.jasper:5.5.17.v200706111724]
at org.apache.jasper.compiler.JDTCompiler$1.findType(JDTCompiler.java:197)[44:org.apache.jasper:5.5.17.v200706111724]
at org.apache.jasper.compiler.JDTCompiler$1.findType(JDTCompiler.java:169)[44:org.apache.jasper:5.5.17.v200706111724]
at org.eclipse.jdt.internal.compiler.lookup.LookupEnvironment.askForType(LookupEnvironment.java:119)[44:org.apache.jasper:5.5.17.v200706111724]
at org.eclipse.jdt.internal.compiler.lookup.PackageBinding.getTypeOrPackage(PackageBinding.java:178)[44:org.apache.jasper:5.5.17.v200706111724]
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.findImport(CompilationUnitScope.java:415)[44:org.apache.jasper:5.5.17.v200706111724]
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.findSingleImport(CompilationUnitScope.java:469)[44:org.apache.jasper:5.5.17.v200706111724]
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.faultInImports(CompilationUnitScope.java:333)[44:org.apache.jasper:5.5.17.v200706111724]
at org.eclipse.jdt.internal.compiler.lookup.CompilationUnitScope.faultInTypes(CompilationUnitScope.java:402)[44:org.apache.jasper:5.5.17.v200706111724]
Java: Java 11.0.24
Tomcat 9.0.89
We are getting the issue when compiling JSP java files
Re: ClassFormatException in Java11 while compiling JSP pages [message #1871376 is a reply to message #1871373] Mon, 23 September 2024 15:04 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Tomcat seems to have released a 9.0.95 in just the past few months; it may do a better job of indicating which .class file it's not happy reading. Regardless, one of the classes required to compile your JSP
is represented by an invalid .class file somewhere in your application.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: ClassFormatException in Java11 while compiling JSP pages [message #1871394 is a reply to message #1871376] Mon, 23 September 2024 16:12 Go to previous messageGo to next message
There is prey weird behaviour that we are observing. When we import a class in JSP that does not have any string + operations, it is working fine. But when the imported class contains these operations, it is failing. For example:
Working class files:
public class App {
public string getName(){
String name = "test**";
return name;
public class App {
return "test".concat(name);
Non-working class file:
public class App {
return name + "fail";
Unable to figure out what's causing this behaviour.
Re: ClassFormatException in Java11 while compiling JSP pages [message #1871403 is a reply to message #1871394] Mon, 23 September 2024 16:55 Go to previous messageGo to next message
Erik BrangsFriend
Member
I'm not sure what's wrong but here's some very general information that may or may not be helpful:
- If you're using Eclipse 2024-09, please note that JDT dropped support for compiling for Java versions earlier than 8: https://eclipse.dev/eclipse/news/4.33/jdt.php#removed-support-for-java7-and-below
- The lines in your stack trace suggest that you're using a very old version of Jasper ("5.5.17.v200706111724").
Re: ClassFormatException in Java11 while compiling JSP pages [message #1871439 is a reply to message #1871376] Tue, 24 September 2024 18:04 Go to previous message
We could not find any newer version of Jasper ("5.5.17.v200706111724") hence had to use it. Also I missed to mention that our application is OSGI based.
Previous Topic:"Java 23 Support for Eclipse 2024-09 (4.33)" install fail
Next Topic:Multi-Release Jar problems
Current Time: Wed Feb 05 06:53:12 GMT 2025
Powered by FUDForum. Page generated in 0.02407 seconds
