Re: Error "Failed to create injector" [message #1770258 is a reply to message #1066042] |
Wed, 09 August 2017 12:56 |
I have added the xtend-gen in my build.properties file as well but I am still getting a similar error for my language. Please help find me find the issue. Here is the exception I have got.
org.eclipse.core.runtime.CoreException: Failed to create injector for com.amadeus.secomo.siteparameters.SiteParameterLanguage ExtensionFactory: com.amadeus.secomo.siteparameters.ui.SiteParameterLanguageExecutableExtensionFactory
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:59)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:262)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:282)
at org.eclipse.ui.internal.registry.EditorDescriptor.createEditor(EditorDescriptor.java:235)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:329)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPart(CompatibilityPart.java:278)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPart(CompatibilityEditor.java:63)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:316)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
at org.eclipse.ui.wizards.newresource.BasicNewFileResourceWizard.performFinish(BasicNewFileResourceWizard.java:103)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:790)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:423)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:618)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:249)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4418)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1079)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3824)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:818)
at org.eclipse.jface.window.Window.open(Window.java:794)
at org.eclipse.ui.internal.actions.NewWizardShortcutAction.run(NewWizardShortcutAction.java:133)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:473)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:565)
at org.eclipse.jface.action.ActionContributionItem.lambda$4(ActionContributionItem.java:397)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
Caused by: java.lang.RuntimeException: Failed to create injector for com.amadeus.secomo.siteparameters.SiteParameterLanguage
at com.amadeus.secomo.siteparameters.ui.internal.SiteparametersActivator.createInjector(SiteparametersActivator.java:71)
at com.amadeus.secomo.siteparameters.ui.internal.SiteparametersActivator.getInjector(SiteparametersActivator.java:55)
at com.amadeus.secomo.siteparameters.ui.SiteParameterLanguageExecutableExtensionFactory.getInjector(SiteParameterLanguageExecutableExtensionFactory.java:24)
at org.eclipse.xtext.ui.guice.AbstractGuiceAwareExecutableExtensionFactory.create(AbstractGuiceAwareExecutableExtensionFactory.java:51)
... 105 more
Caused by: com.google.inject.CreationException: Guice creation errors:
1) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 4
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.<init>(Unknown Source)
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.class(Unknown Source)
while locating com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess
while locating org.eclipse.xtext.IGrammarAccess
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.grammarAccess(Unknown Source)
at org.eclipse.xtext.service.MethodBasedModule.configure(MethodBasedModule.java:57)
while locating org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar
Caused by: org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 4
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:57)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadGrammarFile(BaseEPackageAccess.java:44)
at org.eclipse.xtext.service.GrammarProvider.getGrammar(GrammarProvider.java:61)
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.internalFindGrammar(SiteParameterLanguageGrammarAccess.java:979)
at com.amadeus.secomo.siteparameters.services.SiteParameterLanguageGrammarAccess.<init>(SiteParameterLanguageGrammarAccess.java:933)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.google.inject.internal.DefaultConstructionProxyFactory$1.newInstance(DefaultConstructionProxyFactory.java:85)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:85)
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:254)
at com.google.inject.internal.ProviderToInternalFactoryAdapter$1.call(ProviderToInternalFactoryAdapter.java:46)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1031)
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
at com.google.inject.Scopes$1$1.get(Scopes.java:65)
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:40)
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:54)
at com.google.inject.internal.SingleFieldInjector.inject(SingleFieldInjector.java:53)
at com.google.inject.internal.MembersInjectorImpl.injectMembers(MembersInjectorImpl.java:110)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:94)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:204)
at com.google.inject.internal.InternalInjectorCreator$1.call(InternalInjectorCreator.java:198)
at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1024)
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:198)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:179)
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109)
at com.google.inject.Guice.createInjector(Guice.java:95)
at com.google.inject.Guice.createInjector(Guice.java:72)
at com.google.inject.Guice.createInjector(Guice.java:62)
at com.amadeus.secomo.siteparameters.ui.internal.SiteparametersActivator.createInjector(SiteparametersActivator.java:67)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 4
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.getEStructuralFeatureData(BinaryResourceImpl.java:2125)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObject(BinaryResourceImpl.java:2521)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadFeatureValue(BinaryResourceImpl.java:2545)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObject(BinaryResourceImpl.java:2522)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadEObjects(BinaryResourceImpl.java:2222)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadFeatureValue(BinaryResourceImpl.java:2555)
at org.eclipse.emf.ecore.resource.impl.BinaryResourceImpl$EObjectInputStream.loadResource(BinaryResourceImpl.java:2205)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:219)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1518)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1297)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.xtext.resource.XtextResourceSet.getResource(XtextResourceSet.java:265)
at org.eclipse.xtext.resource.SynchronizedXtextResourceSet.getResource(SynchronizedXtextResourceSet.java:25)
at org.eclipse.xtext.parser.BaseEPackageAccess.loadResource(BaseEPackageAccess.java:52)
... 144 more
2) Error injecting constructor, org.eclipse.emf.common.util.WrappedException: java.lang.ArrayIndexOutOfBoundsException: 4
for parameter 0 at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.<init>(Unknown Source)
at org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry.class(Unknown Source)
while locating org.eclipse.xtext.ui.editor.templates.XtextTemplateContextTypeRegistry
while locating org.eclipse.jface.text.templates.ContextTypeRegistry
for field at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.contextTypeRegistry(Unknown Source)
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:38)
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:62)
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:84)
... 154 more
3) Error injecting method, java.lang.NullPointerException
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(Unknown Source)
at org.eclipse.xtext.ui.codetemplates.ui.registry.LanguageRegistrar.register(LanguageRegistrar.java:45)
at com.google.inject.internal.SingleMethodInjector$1.invoke(SingleMethodInjector.java:71)
at com.google.inject.internal.SingleMethodInjector.inject(SingleMethodInjector.java:90)
3 errors
at com.google.inject.internal.Errors.throwCreationExceptionIfErrorsExist(Errors.java:435)
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:183)
... 108 more
Re: Error "Failed to create injector" [message #1771031 is a reply to message #1770390] |
Mon, 21 August 2017 11:31 |
[Solved]
I found the error. I had the issue because I failed to include the xtext dependency during the plugin generation. I had to add the dependency while building the plugin or atleast installed the xtext version i used in the new IDE i was using.
FUDForum. Page generated in 0.04402 seconds
