Home » Newcomers » Newcomers » Subject: Issue with Eclipse Not Recognizing JDK Path
Subject: Issue with Eclipse Not Recognizing JDK Path [message #1870500] Fri, 30 August 2024 13:22 Go to next message
John Ehlia is currently offline John EhliaFriend
Hi everyone,
I'm having trouble with Eclipse not recognizing the JDK path on my system. I've installed JDK 17 and set the path in the environment variables, but Eclipse keeps showing an error saying it can't find the JDK.
I've tried restarting Eclipse and my computer, but the problem persists. Can someone guide me on how to properly configure Eclipse to recognize the JDK path? Are there any additional steps I might have missed?
Thanks in advance for your help!
Re: Subject: Issue with Eclipse Not Recognizing JDK Path [message #1870503 is a reply to message #1870500] Fri, 30 August 2024 13:27 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
How was Eclipse installed, and which JDK 17 is it, both including the O.S and architecture?
_
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Subject: Issue with Eclipse Not Recognizing JDK Path [message #1870506 is a reply to message #1870503] Fri, 30 August 2024 14:11 Go to previous message
If you use the installer you won't have this problem because it will either find the JDK automatically or you can locate manually and in either case it will test to confirm that the JDK is one that will work for the product version you are trying to install.
Note that the most recent release requires Java 21 so maybe that's your primary problem:
https://www.eclipse.org/setups/sponsor/
Ed Merks
Previous Topic:Deploying Eclipse with additional software installed
Next Topic:Eclipse ThreadX Safety Related Documents
Current Time: Wed Jan 15 05:24:27 GMT 2025
Powered by FUDForum. Page generated in 0.06664 seconds
