sticky tool selected on the palette [message #186410] |
Tue, 05 July 2005 14:32 |
Originally posted by: user1981.gmail.com
Hi to all. Here's my simple question. I've noticed that my creation tools
on my editor's palette don't remain selected. I mean, when i use the
marquee or the selection tool they stay selected no mather the times a use
them. The problem is that my "other" tools get unselected when i use them.
I took a look at the logic example and it seems the same, only the
selection tools seem to stick selected.
Any idea why?
thanks in advance
Re: sticky tool selected on the palette [message #198542 is a reply to message #186839] |
Wed, 12 October 2005 13:25 |
Originally posted by: andi.nospam.netbruns.de
Hi at all,
I see how tools can be made sticky.
I need other tools to stay draggeable at the same time.
example:
tool 1 is selected and placed several times in the editor.
after that a drag'n'drop action is performed on tool 2 which unfortunaly
does not execute since tool 1 stays selected (which is ok so placing tool 1
can be continued after the d'n'd).
While I like the behaviour of tool 1 to stay selected, the impossibility to
perform drag'n'drop actions with other tools at the same time breaks my app :-(
any idea?
thanks andreas
Pratik Shah schrieb:
> paletteToolEntry.setToolProperty(AbstractTool.PROPERTY_UNLOA D_WHEN_FINISHED,
> Boolean.FALSE);
> "josé" <user1981@gmail.com> wrote in message
> news:72b826dc3be3f9d5a60692d84e4c17f2$1@www.eclipse.org...
>>Any idea why?
>>thanks in advance
Re: sticky tool selected on the palette [message #198837 is a reply to message #198542] |
Thu, 13 October 2005 00:17 |
Originally posted by: none.unknown.com
setUnloadWhenFinished(false) only prevents the tool from getting deactivated
after it has been used once. The other tools should still be working.
Dragging another tool should work fine, and the default tool should get
activated after that. You might be doing something wrong if that is not
what you're experiencing. Start another thread and provide more details.
"Andreas Bruns" <andi@nospam.netbruns.de> wrote in message
news:dij2sg$n9j$1@news.eclipse.org...
> Hi at all,
> example:
1
to
app :-(
> any idea?
> thanks andreas
> > Boolean.FALSE);
> > "jos
Re: sticky tool selected on the palette [message #198884 is a reply to message #198837] |
Thu, 13 October 2005 09:35 |
Solved.
Class did not extend CombinedTemplateCreationEntry and so was not
noticed by the d'n'd-listener.
>>Hi at all,
>>example:
> 1
> to
> app :-(
>>any idea?
>>thanks andreas
>>>Boolean.FALSE);
> tools
> use
> them.
>>>>Any idea why?
>>>>thanks in advance
Re: sticky tool selected on the palette [message #198892 is a reply to message #198837] |
Thu, 13 October 2005 10:09 |
Originally posted by: james.willans.xactium.com
Pratik,
On a related issue, I've noticed that with some Eclipse based tools you
can hold down CTRL to key to retain the current tool mode. Is this
something that can be enabled, or must it be implemented by adding
appropriate key binding etc?
James
>> Hi at all,
>> example:
> 1
> to
> app :-(
>> any idea?
>> thanks andreas
>> > Boolean.FALSE);
> tools
> use
> them.
>> >>Any idea why?
>> >>thanks in advance
Re: sticky tool selected on the palette [message #199029 is a reply to message #198892] |
Thu, 13 October 2005 17:14 |
Open a feature request and mention where you see similar behaviour
(Eclipse-based tools or other software, if any). You should be able to
implement this on your own as well without too much trouble.
For 3.2, we have a feature request for palette keybindings, where pressing a
key combination would select a tool. You might find that to be a
satisfactory alternative.
"James Willans" <james.willans@xactium.com> wrote in message
news:15826ff6c6f8ea1efb12f394d6681cc0$1@www.eclipse.org...
> Pratik,
> James
deactivated
details.
> >> Hi at all,
> >> example:
unfortunaly
tool
> > 1
impossibility
> > to
> > app :-(
> >> any idea?
> >> thanks andreas
> >> > Boolean.FALSE);
> >> > "jos
FUDForum. Page generated in 0.26006 seconds
