Home » Eclipse Projects » EclipseLink » Eclipselink4.0.2 jar compatibility queries
Eclipselink4.0.2 jar compatibility queries [message #1865106] Fri, 26 April 2024 12:34 Go to next message
Kalai S is currently offline Kalai SFriend
Is Eclipselink4.0.2 compatible with Java17, Eclipse 2023-03 and with javax.persistence-2.2.1 jar?
Re: Eclipselink4.0.2 jar compatibility queries [message #1865115 is a reply to message #1865106] Fri, 26 April 2024 14:09 Go to previous messageGo to next message
Lukas JungmannFriend
Member
For javax, use EclipseLink 2.7.x, the latest one (2.7.14) supports SE 21 as well
Re: Eclipselink4.0.2 jar compatibility queries [message #1865226 is a reply to message #1865106] Mon, 29 April 2024 10:56 Go to previous messageGo to next message
Radek Felcman is currently offline Radek FelcmanFriend
See
https://eclipse.dev/eclipselink/releases/4.0.php
JDK 17 - yes
javax.persistence-2.2.1 jar - no (move to the Jakarta from 3.0 and higher)
Jakarta Persistence 3.1 - yes
Re: Eclipselink4.0.2 jar compatibility queries [message #1865430 is a reply to message #1865106] Fri, 03 May 2024 09:33 Go to previous message
For now, am facing the below issue in my workspace [Pls Refer to attached Screenshot]
So, for this error, am trying to upgrade to Eclipselink.jar from 2.7 to 4.0.1 and for doing this, am also upgrading to jakarta-api.jar 3.1 version from javax.persistence.jar
Kindly suggest am I going in the correct direction. Also please help me understand why do I face the below error
[Updated on: Fri, 03 May 2024 09:34]
Report message to a moderator
Previous Topic:Eclipselink Cache objects filling the memory
Next Topic:PersistenceUnitLoadingException
Current Time: Wed Feb 05 17:51:42 GMT 2025
Powered by FUDForum. Page generated in 0.02644 seconds
