Home » Archived » BIRT » Eclipse Chart Engine, PNG, and ImageMap
Eclipse Chart Engine, PNG, and ImageMap [message #186425] |
Mon, 21 August 2006 17:02 |
Originally posted by: molson.airinc.com
Hi, I am having a problem creating an imagemap for a chart I have
created. I am able to create a PNG image just fine and have it display
in a browser, however the imagemap I get is always null.
When I create my chart, I add triggers to my bar series like so:
bsY11.getTriggers( ).add(
TriggerImpl.create(
TriggerCondition.ONMOUSEOVER_LITERAL,
ActionImpl.create(
ActionType.SHOW_TOOLTIP_LITERAL,
TooltipValueImpl.create( 500, "my label" )
I then have a servlet to create the png image. That works fine, but my
image map is being returned as null.
here is the interesting part of my get ( cm is the chart ):
IDeviceRenderer idr = null;
final PluginSettings ps = PluginSettings.instance( );
try
idr = ps.getDevice( "dv.PNG" );
catch ( ChartException ex )
ex.printStackTrace( );
// Create a buffered image
BufferedImage image = new BufferedImage( width,
height,
BufferedImage.TYPE_INT_ARGB );
// Draw the chart in the buffered image
Graphics2D g2d = (Graphics2D) image.getGraphics( );
idr.setProperty( IDeviceRenderer.GRAPHICS_CONTEXT, g2d );
Bounds bo = BoundsImpl.create( 0, 0, width, height );
bo.scale( 72d / idr.getDisplayServer( ).getDpiResolution( ) );
Generator gr = Generator.instance( );
try
idr.setProperty( IDeviceRenderer.CACHED_IMAGE, image );
gr.render( idr, gr.build( idr.getDisplayServer( ),
cm,
bo,
null,
null,
null ) );
g2d.dispose( );
IImageMapEmitter test = (IImageMapEmitter)idr;
String vals = test.getImageMap();
vals is null, despite the fact that I know there are triggers set up for
the bar series in the chart. Any idea why?
Cheer,
Mike
Re: Eclipse Chart Engine, PNG, and ImageMap [message #186433 is a reply to message #186425] |
Mon, 21 August 2006 17:20 |
> TriggerImpl.create(
> ActionImpl.create(
> try
> height,
> try
> cm,
> bo,
> null,
> null,
> null ) );
> g2d.dispose( );
> Cheer,
> Mike
Create/Alter/Delete reports at JBoss/WebSphere/WebLogic runtime [message #186441 is a reply to message #186425] |
How can one create, alter, and delete reports at
runtime with any of the following
application servers web servers:
JBoss, WebSphere and WebLogic?
I'm not talking about the content of a report but
rather the reports themselves. Client developers will be
managing the reports (creating, altering and deleting),
the application is responsible for the deployment
of the reports while client users will access the
reports via the appserver web servers.
So, for JBoss one generally has enough information in ones
ear to hot-deploy new reports (I assume), but for
WebSphere and WebLogic does anyone have any
(positive) experience?
Thanks.
Richard
Re: Eclipse Chart Engine, PNG, and ImageMap [message #186516 is a reply to message #186425] |
Tue, 22 August 2006 08:25 |
Zhiqiang Qian Messages: 76 Registered: July 2009 |
Member |
try add this before you call gr.render(),
idr.setProperty( IDeviceRenderer.UPDATE_NOTIFIER,
new EmptyUpdateNotifier( cm, gcs.getChartModel( ) ) );
gcs is the return value of gr.build().
> TriggerImpl.create(
> ActionImpl.create(
> try
> height,
> try
> cm,
> bo,
> null,
> null,
> null ) );
> g2d.dispose( );
> Cheer,
> Mike
Re: Eclipse Chart Engine, PNG, and ImageMap [message #186796 is a reply to message #186516] |
Thu, 24 August 2006 14:55 |
This works great foir ONMOUSEOVER_LITERAL triggers, however, when I use
ONMOUSEDOWN_LITERAL, my imagemap is an empty string. Shouldn't imagemap
support mousedown?
Here is my trigger code
TriggerImpl.create(
TriggerCondition.ONMOUSEDOWN_LITERAL,
ActionImpl.create(
ActionType.URL_REDIRECT_LITERAL,
URLValueImpl.create( "http://www.actuate.com", null, null, null, null )
Any ideas?
>> display in a browser, however the imagemap I get is always null.
>> TriggerImpl.create(
>> ActionImpl.create(
>> my image map is being returned as null.
>> try
>> height,
>> try
>> cm,
>> bo,
>> null,
>> null,
>> null ) );
>> g2d.dispose( );
>> for the bar series in the chart. Any idea why?
>> Cheer,
>> Mike
Current Time: Fri Oct 18 03:21:12 GMT 2024
Powered by FUDForum. Page generated in 0.07007 seconds
