Home » Eclipse Projects » GEF » Where ist the ShortestpathConnectionRouter gone ?
Where ist the ShortestpathConnectionRouter gone ? [message #185879] Thu, 30 June 2005 16:06 Go to next message
Originally posted by: dutz.c-ware.de
I am just working on my first Eclipse Plugin and would like to use the
ShortestPathConnectionRouter. Unfortunately I can't find it anywhere.
Which jar-file contains this class?
Chris
Re: Where ist the ShortestpathConnectionRouter gone ? [message #185895 is a reply to message #185879] Thu, 30 June 2005 17:02 Go to previous messageGo to next message
Steve Jones is currently offline Steve JonesFriend
Member
Christofer Dutz wrote:
> Regards
> Chris
org.eclipse.draw2d.graph.ShortestPathRouter
is in:
eclipse/plugins/org.eclipse.draw2d_3.1.0.jar
Cheers, Steve
Re: Where ist the ShortestpathConnectionRouter gone ? [message #185901 is a reply to message #185895] Thu, 30 June 2005 17:36 Go to previous messageGo to next message
Hmmm ... it seems that it has to be used differently than the Manhattan-
and BendpointConnectionRouter. Google didn' find anything to the
ShortestPathRouter and a title-search in this newsgroup didn't either.
Could you please give me a short code-example showing how to use it?
Thanks in advance,
Chris
>>Hi,
>>Regards
>>Chris
> is in:
> Cheers, Steve
Re: Where ist the ShortestpathConnectionRouter gone ? [message #185910 is a reply to message #185901] Thu, 30 June 2005 17:55 Go to previous messageGo to next message
Member
Have a look at:
org.eclipse.draw2d.examples.cg.ObstructionExample
it uses the ShortestPathRouter.
It's on dev.eclipse.org, in /home/tools
Just import it using New->Import->CVS
Steve.
> Thanks in advance,
> Chris
>>>Hi,
>>>Regards
>>>Chris
>> is in:
>> Cheers, Steve
Steve Jones
I.S.Technology Ltd
Re: Where ist the ShortestpathConnectionRouter gone ? [message #186208 is a reply to message #185910] Sun, 03 July 2005 12:49 Go to previous message
Thank you ... I downloaded the example and will try to add it to my
application. As I thought it is not as easy as simply changing the
Ruoter-Object type.
Chris
> Have a look at:
> Steve.
>>Thanks in advance,
>> Chris
>>>>Hi,
>>>>Regards
>>>>Chris
>>>is in:
>>>Cheers, Steve
Previous Topic:GEF 3.1 release
Next Topic:Scrolling Viewer Problem
Current Time: Thu Dec 26 18:19:53 GMT 2024
Powered by FUDForum. Page generated in 0.04130 seconds
