Re: How to deploy sirius editor? [message #1861892 is a reply to message #1861803] |
Fri, 10 November 2023 16:12 |
Ad Mal Messages: 7 Registered: October 2023 |
Hello community,
I found out that the Activator class cannot be loaded:
"Plug-in obeo.example.design was unable to load class obeo.example.design.Activator.
java.lang.ClassNotFoundException: obeo.example.design.Activator cannot be found by obeo.example.design_1.0.0.202311041605"
See attachment. The same problem also occurs with other plug-ins that I created with Sirius. Any help?
UPDATE: I installed the "Obeo Designer Community Edition - Extensions" and it seems to work. Apparently some packages were missing. Stupid mistake :-(
Thank you
Attachment: errorlog.txt
(Size: 14.95KB, Downloaded 25 times)
[Updated on: Fri, 10 November 2023 17:10] Report message to a moderator
FUDForum. Page generated in 0.03360 seconds
