Home » Eclipse Projects » Rich Client Platform (RCP) » Occasional Exit hang/crash
Occasional Exit hang/crash [message #785180] Sat, 28 January 2012 16:14 Go to next message
Missing name Mising name is currently offline Missing name Mising nameFriend
Every now and then, when I click on the App Close button (Big Red X in upper right corner - Win7), the app doesn't close.
Nothing happens.
App is still functioning, and I can still use it.
So I goto the File menu, and select "Exit".
App closes - with an exception:
	at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1708)
	at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:730)
	at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:715)
	at org.eclipse.ui.internal.WorkbenchWindow$5.run(WorkbenchWindow.java:860)
	at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:858)
	at org.eclipse.jface.window.Window.handleShellCloseEvent(Window.java:741)
        etc...
Eclipse shows me that the offending LOC is the call to .deactivateHandlers().
Apparently handlerService is null.
    final IHandlerService handlerService = (IHandlerService) workbench.getService(IHandlerService.class);
    handlerService.deactivateHandlers(handlerActivations);
Is there something I'm doing that could cause this?
Re: Occasional Exit hang/crash [message #1860530 is a reply to message #785180] Sun, 13 August 2023 14:18 Go to previous message
Marco Lopes is currently offline Marco LopesFriend
Member
Same here , with eclipse 3.8!
It happens when the user tries to close the workbench more than one time (in the window X) and the workbench is busy...
This is clearly a BUG.
Previous Topic:Disabling the Inspection of Web Content in Apps
Next Topic:How to listen theme change event ??
Current Time: Sat Dec 21 12:43:28 GMT 2024
Powered by FUDForum. Page generated in 0.03535 seconds
