"open the debug view" [message #1859669] |
Wed, 21 June 2023 19:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Anne Ranch![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=anneranch2442%40gmail.com) Messages: 85 Registered: October 2020 |
Member |
As the message says, for the interactive console in debug mode, you need to have a frame selected -- this is the stack frame on the debug view (so, open the debug view and select the frame on which the commands you execute should be evaluated).
Excuse my ignorance - the above calls l for " open the debug view "
When I do "Run->Run" there is no "debug " nowhere.
Are they referring to "Debug" tab as "view " ?
how do I " open the debug view " ?
In 2022-12 ?
PS
I will not ask how did I get into " interactive" (console mode ?) whatever the term is for.
Update
I can get "Debug" view, still not sure how to consistently get into "interactive console ".
[Updated on: Wed, 21 June 2023 20:08] Report message to a moderator
Re: "open the debug view" [message #1860384 is a reply to message #1859775] |
Wed, 02 August 2023 13:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Don't worry, it can be a bit confusing. Yeah, they're talking about the "Debug" tab, and it's kinda like a "view." To open the Debug view, go to "Window" > "Show View" > "Debug."
For the "interactive console," while debugging, you'll find it in the Debug perspective, usually at the bottom. If you can't see it, try dragging the tabs around a bit.
[Updated on: Thu, 03 August 2023 12:41] Report message to a moderator
FUDForum. Page generated in 0.07799 seconds
