Home » Eclipse Projects » Eclipse Platform » Goclipse compilation failure
Goclipse compilation failure [message #1857545] Tue, 14 February 2023 17:30 Go to next message
Aleksandr Zelenin is currently offline Aleksandr ZeleninFriend
I would like to reanimate Goclipse plugin and got failure on compilation with maven. So do anybody knows with what repository should i replace absent http://download.eclipse.org/releases/neon?
[ERROR] Internal error: java.lang.RuntimeException: Failed to load p2 repository with ID 'neon' from location http://download.eclipse.org/releases/neon: Unable to read repository at http://download.eclipse.org/releases/neon/compositeContent.xml. Unable to make public void sun.security.ssl.SSLSocketImpl.setHost(java.lang.String) accessible: module java.base does not "exports sun.security.ssl" to unnamed module @2fbf643b -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: Failed to load p2 repository with ID 'neon' from location http://download.eclipse.org/releases/neon
    at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:108)
    at org.apache.maven.cli.MavenCli.execute (MavenCli.java:821)
    at org.apache.maven.cli.MavenCli.doMain (MavenCli.java:270)
    at org.apache.maven.cli.MavenCli.main (MavenCli.java:192)
    at jdk.internal.reflect.DirectMethodHandleAccessor.invoke (DirectMethodHandleAccessor.java:104)
    at java.lang.reflect.Method.invoke (Method.java:578)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced (Launcher.java:282)
    at org.codehaus.plexus.classworlds.launcher.Launcher.launch (Launcher.java:225)
    at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode (Launcher.java:406)
    at org.codehaus.plexus.classworlds.launcher.Launcher.main (Launcher.java:347)
Caused by: java.lang.RuntimeException: Failed to load p2 repository with ID 'neon' from location http://download.eclipse.org/releases/neon
    at org.eclipse.tycho.p2.target.TargetPlatformFactoryImpl.loadMetadataRepository (TargetPlatformFactoryImpl.java:302)
    at org.eclipse.tycho.p2.target.TargetPlatformFactoryImpl.gatherExternalInstallableUnits (TargetPlatformFactoryImpl.java:270)
    at org.eclipse.tycho.p2.target.TargetPlatformFactoryImpl.createTargetPlatform (TargetPlatformFactoryImpl.java:176)
    at org.eclipse.tycho.p2.target.TargetPlatformFactoryImpl.createTargetPlatform (TargetPlatformFactoryImpl.java:128)
    at org.eclipse.tycho.p2.target.TargetPlatformFactoryImpl.createTargetPlatform (TargetPlatformFactoryImpl.java:1)
    at org.eclipse.tycho.p2.manager.ReactorRepositoryManagerImpl.computePreliminaryTargetPlatform (ReactorRepositoryManagerImpl.java:84)
    at org.eclipse.tycho.p2.resolver.P2DependencyResolver.computePreliminaryTargetPlatform (P2DependencyResolver.java:223)
    at org.eclipse.tycho.core.resolver.DefaultTychoResolver.resolveProject (DefaultTychoResolver.java:109)
    at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead (TychoMavenLifecycleParticipant.java:95)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:222)
    at org.apache.maven.DefaultMaven.doExecute (DefaultMaven.java:172)
    at org.apache.maven.DefaultMaven.execute (DefaultMaven.java:100)
Caused by: org.eclipse.equinox.p2.core.ProvisionException: Unable to read repository at http://download.eclipse.org/releases/neon/compositeContent.xml.
    at org.eclipse.equinox.internal.p2.repository.CacheManager.createCache (CacheManager.java:243)
    at org.eclipse.tycho.p2.remote.RemoteRepositoryCacheManager.createCache (RemoteRepositoryCacheManager.java:67)
    at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.getLocalFile (CompositeMetadataRepositoryFactory.java:73)
    at org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepositoryFactory.load (CompositeMetadataRepositoryFactory.java:98)
    at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.factoryLoad (MetadataRepositoryManager.java:57)
    at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository (AbstractRepositoryManager.java:768)
    at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.loadRepository (AbstractRepositoryManager.java:668)
    at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository (MetadataRepositoryManager.java:96)
    at org.eclipse.tycho.p2.remote.RemoteMetadataRepositoryManager.loadRepository (RemoteMetadataRepositoryManager.java:61)
    at org.eclipse.tycho.p2.remote.RemoteMetadataRepositoryManager.loadRepository (RemoteMetadataRepositoryManager.java:53)
    at org.eclipse.tycho.p2.target.TargetPlatformFactoryImpl.loadMetadataRepository (TargetPlatformFactoryImpl.java:298)
Caused by: java.lang.reflect.InaccessibleObjectException: Unable to make public void sun.security.ssl.SSLSocketImpl.setHost(java.lang.String) accessible: module java.base does not "exports sun.security.ssl" to unnamed module @2fbf643b
    at java.lang.reflect.AccessibleObject.throwInaccessibleObjectException (AccessibleObject.java:387)
    at java.lang.reflect.AccessibleObject.checkCanSetAccessible (AccessibleObject.java:363)
    at java.lang.reflect.AccessibleObject.checkCanSetAccessible (AccessibleObject.java:311)
    at java.lang.reflect.Method.checkCanSetAccessible (Method.java:201)
    at java.lang.reflect.Method.setAccessible (Method.java:195)
    at org.eclipse.ecf.provider.filetransfer.httpclient4.SNIAwareHttpClient$1.connectSocket (SNIAwareHttpClient.java:56)
    at org.apache.http.conn.ssl.SSLSocketFactory.connectSocket (SSLSocketFactory.java:403)
    at org.apache.http.impl.conn.DefaultClientConnectionOperator.openConnection (DefaultClientConnectionOperator.java:177)
    at org.apache.http.impl.conn.ManagedClientConnectionImpl.open (ManagedClientConnectionImpl.java:304)
    at org.apache.http.impl.client.DefaultRequestDirector.tryConnect (DefaultRequestDirector.java:611)
    at org.apache.http.impl.client.DefaultRequestDirector.execute (DefaultRequestDirector.java:446)
    at org.apache.http.impl.client.AbstractHttpClient.doExecute (AbstractHttpClient.java:863)
    at org.apache.http.impl.client.CloseableHttpClient.execute (CloseableHttpClient.java:82)
    at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest (HttpClientFileSystemBrowser.java:263)
    at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run (AbstractFileSystemBrowser.java:69)
    at org.eclipse.core.internal.jobs.Worker.run (Worker.java:55)
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/InternalErrorException
Re: Goclipse compilation failure [message #1857561 is a reply to message #1857545] Wed, 15 February 2023 08:14 Go to previous messageGo to next message
Maybe there was a network problem, because that exists as seen in a browser
https://download.eclipse.org/releases/neon/
https://download.eclipse.org/justj/?file=releases/neon
Maybe the problem is that http redirects to https and something is not handling the redirection properly. Try using https instead.
Ed Merks
Re: Goclipse compilation failure [message #1857589 is a reply to message #1857561] Thu, 16 February 2023 08:24 Go to previous messageGo to next message
You are right, repository exists, but not https://download.eclipse.org/releases/neon/compositeContent.xml
Re: Goclipse compilation failure [message #1857591 is a reply to message #1857589] Thu, 16 February 2023 09:50 Go to previous messageGo to next message
No but https://download.eclipse.org/releases/neon/compositeContent.jar exists and p2 tries this first, then the *.xml version and when both fail, the error message only mentions the *.xml name.
Ed Merks
Re: Goclipse compilation failure [message #1857592 is a reply to message #1857591] Thu, 16 February 2023 10:06 Go to previous messageGo to next message
Thank you for your answers. So how to fix it? Why maven doesn't use compositeContent.jar?
[Updated on: Thu, 16 February 2023 10:06]
Report message to a moderator
Re: Goclipse compilation failure [message #1857606 is a reply to message #1857592] Thu, 16 February 2023 15:52 Go to previous messageGo to next message
I think it's just network problems. I don't see anything broken. I have suggested using https. Have you tried that?
You can use this to explore what's physically present on the server:
You could look in the composite jar to see what's there:
<?xml version='1.0' encoding='UTF-8'?>
<?compositeMetadataRepository version='1.0.0'?>
<repository name='Eclipse Repository'  type='org.eclipse.equinox.internal.p2.metadata.repository.CompositeMetadataRepository' version='1.0.0'>
  <properties size='3'>
    <property name='p2.timestamp' value='1313779613118'/>
    <property name='p2.compressed' value='true'/>
    <property name='p2.atomic.composite.loading' value='true'/>
  </properties>
  <children size='7'>
    <child location='../../technology/epp/packages/neon/'/>
    <child location='201606221000' />
    <child location='201609281000' />
    <child location='201610111000' />
    <child location='201612211000' />
    <child location='201703231000' />
    <child location='201705151400' />
  </children>
</repository>
And you can see then that this repository is also available:
https://download.eclipse.org/releases/neon/201705151400/
As long as your reference things that are present, best using https, there should be no problem...
Ed Merks
Re: Goclipse compilation failure [message #1857669 is a reply to message #1857545] Mon, 20 February 2023 18:21 Go to previous message
Looks like problem was with Java version. I finally build app with Java 1.8 but not with Java 19.
$ mvn -v
Apache Maven 3.9.0 (9b58d2bad23a66be161c4664ef21ce219c2c8584)
Maven home: /usr/local/Cellar/maven/3.9.0/libexec
Java version: 19.0.2, vendor: Homebrew, runtime: /usr/local/Cellar/openjdk/19.0.2/libexec/openjdk.jdk/Contents/Home
Default locale: en_US, platform encoding: UTF-8
OS name: "mac os x", version: "12.6.3", arch: "x86_64", family: "mac"
$  JAVA_HOME=/Library/Java/JavaVirtualMachines/jdk1.8.0_92.jdk/Contents/Home mvn -v
Java version: 1.8.0_92, vendor: Oracle Corporation, runtime: /Library/Java/JavaVirtualMachines/jdk1.8.0_92.jdk/Contents/Home/jre
OS name: "mac os x", version: "10.16", arch: "x86_64", family: "mac"
Previous Topic:Error installing Xtext 2.7.3 for Eclipse RCP Indigo SR2
Next Topic:Browsing project files
Current Time: Sat Dec 21 12:55:23 GMT 2024
Powered by FUDForum. Page generated in 0.03819 seconds
