Store resultset value in ArrayObject [message #1857170] |
Fri, 20 January 2023 21:05 |
Jagadheeswaran Mohan Messages: 1 Registered: January 2023 |
Iam running a Dataset on a datasource, i need to use one column values out of the data set to another Dataset which is connected with another datasource.
So i need to store the Array of row['column_name'] to a variable.
I tried creating a page variable and on fetch method i tried using,
uoi[i] = row["uoi_id"];
i++;
vars['ids']=uoi;
I was getting no report param called ids, but created one
Then i tried to create globalVariable,
reportContext.setGlobalVariable('uoiids', ["1"]);
while reading this am getting null.
Approach2:
Since this is not working, what i tried is creating a Dynamic param as List, and provided my dataset and column mapping.
And in my 2nd dataset, i used params['ids']
This worked, but the problem is on report param i need to manually select all the values, i need to somehow auto select all the options.
I tried using getDefaultList event, but i dont know how to return the list of array.
And i read in a post getDefaultList will trigger before reading the dataset itself.
I need to atleast know how to select all values by default.
When i tried to Post this in BIRT forum, its saying incorrect password evn thought its right one
FUDForum. Page generated in 0.07971 seconds
