Home » Language IDEs » Java Development Tools (JDT) » Project erroring("The supplied phased action failed with an exception.")
Project erroring [message #1856790] Tue, 03 January 2023 04:40 Go to next message
William Martin is currently offline William MartinFriend
While trying to set up an eclipse environment for minecraft modding, I encountered this error and am unable to find the solution. I am not very savvy with gradle or eclipse and some help would be appreciated.
Error:
Could not open cp_init generic class cache for initialization script 'C:\Users\user\Documents\GitHub\Unifye\Minecraft\selectiveHardcoreWorkspace\.metadata\.plugins\org.eclipse.buildship.core\init.d\eclipsePlugin.gradle' (C:\Users\user\.gradle\caches\7.5.1\scripts\7fciaz2tzo3lxxw75zggl661a).
BUG! exception in phase 'semantic analysis' in source unit '_BuildScript_' Unsupported class file major version 63
I was following a youtube tutorial and couldn't follow along anymore because of the error. I can't seem to build with gradle like he does and have no options when I right click the gradle build.
Re: Project erroring [message #1856795 is a reply to message #1856790] Tue, 03 January 2023 07:25 Go to previous messageGo to next message
This question sounds similar to this one:
https://stackoverflow.com/questions/74779810/how-to-solve-the-unsupported-class-file-major-version-63-error-when-using-eclips
Asking about Gradle/Buildship would be better done here:
https://projects.eclipse.org/projects/tools.buildship/contact
Ed Merks
Re: Project erroring [message #1860454 is a reply to message #1856790] Mon, 07 August 2023 09:56 Go to previous message
Michelle Klimas is currently offline Michelle KlimasFriend
It looks like there was an error related to initializing the Gradle build script in your project. The error message suggests that there is an issue with opening the class cache for the initialization script. Cleaning the Gradle cache might help resolve the issue. You can do this by deleting the contents of the .gradle/caches directory in your user folder (C:\Users\user\.gradle\caches).
Previous Topic:Error when transfering java projects from eclipse under windows to eclipse under linux
Next Topic:Purpose of org.eclipse.jdt.core.compiler.problem.fatalOptionalError option
Current Time: Wed Feb 05 08:37:16 GMT 2025
Powered by FUDForum. Page generated in 0.02825 seconds
