Re: How get http request header fields? [message #1855351 is a reply to message #1855349] |
Mon, 10 October 2022 08:27 |
Miloslav Frajdl Messages: 49 Registered: June 2018 |
Member |
Hi Mat,
thank you. I don't really like the idea of linking server libraries to the client. I did some more research and found a way that I like better.
For your interest as example (based on this post https://www.eclipse.org/forums/index.php/t/1105001/):
1.
In "ui.html" module I created class "MyUiSession" with @Replace attribute package cz.a4b.tracetickets.ui.html;
@Replace
public class MyUiSession extends UiSession {
protected IClientSession createAndStartClientSession(Locale locale, UserAgent userAgent,
Map<String, String> sessionStartupParams) {
HttpServletRequest req = currentHttpRequest();
StringBuilder sb = new StringBuilder();
sb.append("--- Header ---").append("\r\n");
Enumeration<String> headernames = req.getHeaderNames();
while (headernames.hasMoreElements()) {
String param = headernames.nextElement();
sb.append(param + "=" + req.getHeader(param)).append("\r\n");
sb.append("--- Attributes ---").append("\r\n");
Enumeration<String> attributenames = req.getAttributeNames();
while (attributenames.hasMoreElements()) {
String param = attributenames.nextElement();
sb.append(param + "=" + req.getAttribute(param)).append("\r\n");
sb.append("--- Parameters ---").append("\r\n");
Map<String, String[]> parametermap = req.getParameterMap();
for(String key : parametermap.keySet()) {
String[] val = parametermap.get(key);
sb.append(key + "=[" + String.join(",", val) + "]").append("\r\n");
sb.append("--- Cookies ---").append("\r\n");
Cookie[] cookies = req.getCookies();
for(Cookie c : cookies) {
sb.append(c.getName() + "=" + c.getValue()).append("\r\n");
sb.append("--- Others ---").append("\r\n");
sb.append("remoteAddr=" + req.getRemoteAddr()).append("\r\n");
sb.append("remoteHost=" + req.getRemoteHost()).append("\r\n");
sb.append("remoteUser=" + req.getRemoteUser()).append("\r\n");
sb.append("authType=" + req.getAuthType()).append("\r\n");
sb.append("localName=" + req.getLocalName()).append("\r\n");
Principal userprincipal = req.getUserPrincipal();
sb.append("userPrincipal.Name=" + userprincipal.getName()).append("\r\n");
Map<String, String> modifableMap = new HashMap<>(sessionStartupParams);
modifableMap.put("header", sb.toString());
return super.createAndStartClientSession(locale, userAgent, modifableMap);
2.
This is usable only in initializing ClientSession. So I in "client" module modified "execLoadSession" in "ClientSession" and copied property "header" to session data:package cz.a4b.tracetickets.client;
public class ClientSession extends AbstractClientSession {
protected void execLoadSession() {
LOG.info("ClientSession execLoadSession");
// pre-load all known code types
CODES.getAllCodeTypes("cz.a4b.tracetickets.shared");
PropertyMap pm = PropertyMap.CURRENT.get();
setData("header", pm.get("header"));
initializeSharedVariables();
setDesktop(new Desktop());
3.
Now I can read the value anywhere in the client:String res = (String) ClientSession.get().getData("header");
MessageBoxes.createOk().withHeader(res).show();
Thanks again for your help in guiding me to a workable solution.
[Updated on: Mon, 10 October 2022 08:29] Report message to a moderator
Re: How get http request header fields? [message #1856095 is a reply to message #1856094] |
Mon, 21 November 2022 10:46 |
Mr Robot Messages: 71 Registered: March 2020 |
Member |
Hi, from UIServletFilter for FormBasedAccessController I have DataSourceCredentialsVerifier class like this:
public class UiServletFilter implements Filter {
private TrivialAccessController m_trivialAccessController;
private FormBasedAccessController m_formBasedAccessController;
private DevelopmentAccessController m_developmentAccessController;
public void init(FilterConfig filterConfig) throws ServletException {
m_trivialAccessController = BEANS.get(TrivialAccessController.class).init(new TrivialAuthConfig().withExclusionFilter(filterConfig.getInitParameter("filter-exclude")).withLoginPageInstalled(true));
m_formBasedAccessController = BEANS.get(FormBasedAccessController.class).init(new FormBasedAuthConfig().withCredentialVerifier(BEANS.get(DataSourceCredentialVerifier.class)));
m_developmentAccessController = BEANS.get(DevelopmentAccessController.class).init();
public void doFilter(ServletRequest request, ServletResponse response, FilterChain chain) throws IOException, ServletException {
final HttpServletRequest req = (HttpServletRequest) request;
final HttpServletResponse resp = (HttpServletResponse) response;
if (m_trivialAccessController.handle(req, resp, chain)) {
return;
if (m_formBasedAccessController.handle(req, resp, chain)) {
return;
/*if (m_developmentAccessController.handle(req, resp, chain)) {
return;
if (req.getPathInfo() != null && req.getPathInfo().startsWith("/unload/")) {
resp.sendError(HttpServletResponse.SC_FORBIDDEN);
return;
BEANS.get(ServletFilterHelper.class).forwardToLoginForm(req, resp);
public void destroy() {
m_developmentAccessController.destroy();
m_formBasedAccessController.destroy();
m_trivialAccessController.destroy();
FUDForum. Page generated in 0.04609 seconds
