Home » Eclipse Projects » Oomph » Exception when trying to run the installer or setup tasks
Exception when trying to run the installer or setup tasks [message #1855172] Fri, 30 September 2022 09:34 Go to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
when I try to run the setup tasks in an installation that worked perfectly fine until yesterday afternoon, I now get:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.io.IOException: Eclipse Git access blocked: http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$ResourceLocator.demandLoadHelper(ResourceSetImpl.java:804)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$MappedResourceLocator.getResource(ResourceSetImpl.java:1204)
	at org.eclipse.oomph.setup.internal.core.util.SetupCoreUtil$3.getResource(SetupCoreUtil.java:461)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:352)
	at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getEObject(ResourceSetImpl.java:220)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:209)
	at org.eclipse.emf.ecore.util.EcoreUtil.resolve(EcoreUtil.java:269)
I also get the same message when I launch the Eclipse installer, which I used since June 2022. What would be the best approach to fix my Eclipse installation?
Re: Exception when trying to run the installer or setup tasks [message #1855174 is a reply to message #1855172] Fri, 30 September 2022 09:44 Go to previous messageGo to next message
FWIW: A fresh download of the installer causes the same trouble for me, but the logs contain this hint:
!ENTRY org.eclipse.oomph.setup.core 2 0 2022-09-30 11:38:32.738
!MESSAGE The Eclipse Git-hosted URI 'http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup' is blocked for direct access.
Please open a Bugzilla to add it to an official Oomph catalog.
For initial testing, use the file system local version of the resource.
Alternatively, run the setup archiver application as follows:
  /Applications/Eclipse Installer.app/Contents/MacOS/eclipse-inst -application org.eclipse.oomph.setup.core.SetupArchiver -consoleLog -noSplash -uris http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
!ENTRY org.eclipse.oomph.setup.ui 4 0 2022-09-30 11:38:32.762
!MESSAGE java.io.IOException: Eclipse Git access blocked: http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
!STACK 0
	at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob$1.handleDemandLoadException(ResourceMirror.java:253)
	at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob.perform(ResourceMirror.java:260)
	at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:437)
	at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Caused by: java.io.IOException: Eclipse Git access blocked: http://git.eclipse.org/c/oomph/org.eclipse.oomph.git/plain/setups/org.eclipse.setup
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$InputStreamConnectionHandler.handleEclipseGit(ECFURIHandlerImpl.java:1847)
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$InputStreamConnectionHandler.handleEclipseGit(ECFURIHandlerImpl.java:1)
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl$ConnectionHandler.process(ECFURIHandlerImpl.java:1499)
	at org.eclipse.oomph.setup.internal.core.util.ECFURIHandlerImpl.createInputStream(ECFURIHandlerImpl.java:323)
	at org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterImpl.createInputStream(ExtensibleURIConverterImpl.java:358)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1314)
	at org.eclipse.oomph.setup.internal.core.util.ResourceMirror$LoadJob.perform(ResourceMirror.java:242)
	... 2 more
Running the suggested command fixed the problem for me. I'm still curious though why I had to run it.
Re: Exception when trying to run the installer or setup tasks [message #1855178 is a reply to message #1855174] Fri, 30 September 2022 10:20 Go to previous message
Yes there is a complete breakdown accessing https://www.eclipse.org/setups/setup.zip right now:
https://gitlab.eclipse.org/eclipsefdn/helpdesk/-/issues/2016
Hopefully it's fixed soon!
Ed Merks
Previous Topic:Validate Java runtime and product version on bootstrap and start
Next Topic:Setup Tasks preference page missing
Current Time: Mon Jan 13 15:35:26 GMT 2025
Powered by FUDForum. Page generated in 0.03333 seconds
