Home » Eclipse Projects » Remote Application Platform (RAP) » Modified style
Modified style [message #1854049] Fri, 29 July 2022 12:11 Go to next message
Dmitry Dukhov is currently offline Dmitry DukhovFriend
Hi everyone
Can i change widget style after initialization constructor?
Dmitry
Re: Modified style [message #1854065 is a reply to message #1854049] Sat, 30 July 2022 10:49 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
Hi Dmitry
yes.. you can. Define different styling as "custom variants" and switch them at runtime by setting RWT.CUSTOM_VARIANT data on the widget.
Ivan
Re: Modified style [message #1854204 is a reply to message #1854065] Sat, 06 August 2022 12:50 Go to previous messageGo to next message
mmmmm.... Does it help for widget behaviour like SET.READ_ONLY?
Re: Modified style [message #1854348 is a reply to message #1854204] Mon, 15 August 2022 17:08 Go to previous messageGo to next message
depends on the widget and the property you want to style.
Ivan
Re: Modified style [message #1854359 is a reply to message #1854348] Mon, 15 August 2022 23:18 Go to previous messageGo to next message
Combo
Re: Modified style [message #1854372 is a reply to message #1854359] Tue, 16 August 2022 13:00 Go to previous messageGo to next message
Yes... just set RWT.CUSTOM_VARIANT with widget.setData(...). The styling with this variant will be applied from CSS like:
Button.my_custom_variant {
See also our online Controls demo here:
https://rap.eclipsesource.com/demo/release/controls/#Variants
Ivan
Re: Modified style [message #1854660 is a reply to message #1854049] Thu, 01 September 2022 12:52 Go to previous message
Benjamin Wolff is currently offline Benjamin WolffFriend
Just as a general remark, I frequently use the theming reference to check what widgets can be styled via custom variants and what states and styles are supported: https://download.eclipse.org/rt/rap/doc/3.21/guide/reference/theming/index.html
You may need to substitute the version in the url to the one used in your project.
HTH,
Ben
Previous Topic:[ANN] RAP 3.21 Released!
Next Topic:Server push
Current Time: Sat Dec 21 12:19:04 GMT 2024
Powered by FUDForum. Page generated in 0.04235 seconds
