Home » Eclipse Projects » Sirius » add a listener to a diagram element
add a listener to a diagram element [message #1726631] Tue, 15 March 2016 09:26 Go to next message
Alx Hvx is currently offline Alx HvxFriend
Member
Hi everybody,
For my project I have to listen to an element of a diagram an do some actions when the user clic or modify something on it.
For exemple when a field of an element is changed I want to automaticly change the value of another field. Do you know how to do that ?
Another thing I need to do (more complicated I think) is to get the layout position of an element (x and y) on the diagram and store those values on a field of it. For exemple if I drag the element on the diagram from position x=50, y=50 to x=100, y=100 I need that field of this element to automaticly change to x=100 and y=100.
I tried to modify the .aird file but it makes the diagram crash.
Is this something possible to do with Sirius ?
Thank you !
Alex
[Updated on: Wed, 16 March 2016 08:58]
Report message to a moderator
Re: add a listener to a diagram element [message #1726781 is a reply to message #1726631] Wed, 16 March 2016 13:24 Go to previous messageGo to next message
Member
After some research It seems like it is possible to do what I need with the GMF Runtime plugin, the problem is that I have absolutely no idea on how to access that plugin with a Sirius diagram. Maybe I need to create and open the diagrams programmaticly ?
Re: add a listener to a diagram element [message #1726790 is a reply to message #1726781] Wed, 16 March 2016 14:00 Go to previous messageGo to next message
Esteban Dugueperoux is currently offline Esteban DugueperouxFriend
Sirius is based on GMF, and GMF based on GEF, then you can API of these
frameworks also.
For your need you can use a precommit, i.e. a ResourceSetListener, to
update some model elements according to some changes. See [1]
[1]
http://www.linuxtopia.org/online_books/eclipse_documentation/eclipse_emf_model_transaction_developer_guide/topic/org.eclipse.emf.transaction.doc/references/overview/eclipse_emf_model_transaction_listeners.html
Best Regards.
Esteban Dugueperoux - Obeo
Re: add a listener to a diagram element [message #1726812 is a reply to message #1726790] Wed, 16 March 2016 16:16 Go to previous messageGo to next message
Member
Thanks for your reply,
I also found this post with approximately the same question as mine : https://www.eclipse.org/forums/index.php/t/1068712/
The answer says that it's possible to use the org.eclipse.sirius.diagram.ui.business.api.view.SiriusGMFHelper.getGMFNode(DDiagramElement) method to do it.
As I am not really familiar with Siruis I don't know witch solution is the best (between the pre-commit and the helper) and I don't kwow how to get the DDiagramElement programmaticly. Do you have an idea ?
Alex.
Re: add a listener to a diagram element [message #1726813 is a reply to message #1726790] Wed, 16 March 2016 16:17 Go to previous messageGo to next message
Member
MULTIPLE POST BUG : TO DELETE
[Updated on: Wed, 16 March 2016 16:27]
Re: add a listener to a diagram element [message #1726814 is a reply to message #1726790] Wed, 16 March 2016 16:18 Go to previous messageGo to next message
Member
[Updated on: Wed, 16 March 2016 16:28]
Re: add a listener to a diagram element [message #1726815 is a reply to message #1726790] Wed, 16 March 2016 16:18 Go to previous messageGo to next message
Member
Re: add a listener to a diagram element [message #1726816 is a reply to message #1726790] Wed, 16 March 2016 16:18 Go to previous messageGo to next message
Member
No Message Body
Re: add a listener to a diagram element [message #1726818 is a reply to message #1726790] Wed, 16 March 2016 16:19 Go to previous messageGo to next message
Member
No Message Body
Re: add a listener to a diagram element [message #1726819 is a reply to message #1726790] Wed, 16 March 2016 16:19 Go to previous messageGo to next message
Member
No Message Body
Re: add a listener to a diagram element [message #1726820 is a reply to message #1726790] Wed, 16 March 2016 16:19 Go to previous messageGo to next message
Member
No Message Body
[Updated on: Wed, 16 March 2016 16:29]
Re: add a listener to a diagram element [message #1727748 is a reply to message #1726790] Sat, 26 March 2016 16:47 Go to previous messageGo to next message
Parsa Pourali is currently offline Parsa PouraliFriend
Hi Esteban,
Could you please elaborate more on registering the listeners as an extension?
- Should we add the extension in the EMF project plugin or to the Sirius (design) project plug-in ?
- What is the Editing Domain ? is it our EMF project ?
<extension point="org.eclipse.emf.transaction.listeners">
    <listener class="org.eclipse.example.MyListener">
       <editingDomain id="org.eclipse.example.MyEditingDomain"/>
    </listener>
</extension>
Parsa
[Updated on: Sat, 26 March 2016 16:52]
Re: add a listener to a diagram element [message #1853165 is a reply to message #1727748] Tue, 21 June 2022 13:39 Go to previous message
AMir Taghizadegan is currently offline AMir TaghizadeganFriend
Member
Hi parsa,
do you have a solution?
Previous Topic:Validation of the odesign file fails
Next Topic:Add a listener to a diagram element on sirius web
Current Time: Mon Dec 30 16:46:56 GMT 2024
Powered by FUDForum. Page generated in 0.05951 seconds
