JvmUnknownTypeReference for Support Class [message #1852898] |
Thu, 09 June 2022 22:18 |
Ben Holland Messages: 34 Registered: April 2019 |
Member |
I have a situation nearly identical to this very old article where I want to generated a support class which I need to create a type reference to. The newTypeRef API looks like what I want but seems to have been removed or replaced although with what I cannot tell.
https://xtextcasts.org/episodes/19-xbase-s-new-jvmunknowntypereference
I found that creating the typeRef to the to be generate type works if I run from Eclipse (the JDTTypeProvider seems to pick up on the generated type and eventually resolve the JvmUnknownTypeReference), however outside of Eclipse where I don't have a provider running on incremental changes the safe initialization sometimes ends up producing types like:
Object /* List<? extends frusteratingly.the.correct.type> */
It seems to consistently fail on wildcard extends.
What is the right way to do this?
[Updated on: Thu, 09 June 2022 22:20] Report message to a moderator
FUDForum. Page generated in 0.03352 seconds
