Home » Modeling » TMF (Xtext) » Xtext & Xtend Release 2.27.0 is available now
Xtext & Xtend Release 2.27.0 is available now [message #1852655] Mon, 30 May 2022 05:07 Go to next message
Dear Xtexters,
Xtext & Xtend Release 2.27.0 is available now at
- https://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.27.0/
- http://www.eclipse.org/modeling/download.php?file=/modeling/tmf/xtext/downloads/drops/2.27.0/R202205300508/tmf-xtext-Update-2.27.0.zip
- and (soon) on maven central
- Eclipse Marketplace
You can find the matching MWE release 2.13.0 at
- https://download.eclipse.org/modeling/emft/mwe/updates/releases/2.13.0/
- http://www.eclipse.org/modeling/download.php?file=/modeling/emft/mwe/downloads/drops/2.13.0/R202205191115/emft-mwe-2-lang-Update-2.13.0.zip
- and on maven central
Both will be part of Eclipse 2022-06
Release notes can be found at
- https://www.eclipse.org/Xtext/releasenotes.html#/releasenotes/2022/05/30/version-2-27-0
- https://www.eclipse.org/xtend/releasenotes.html#/releasenotes/2022/05/30/version-2-27-0
Happy Xtexting
Christian
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852705 is a reply to message #1852655] Wed, 01 June 2022 10:57 Go to previous messageGo to next message
thanks a lot!
I rebuilt my DSLs with Xtext 2.27.0, and I encounter problems with one of it.
The primary DSL works fine, but a secondary DSL which referenced the primary one fails to generate in a maven run:
Execution default of goal org.eclipse.xtext:xtext-maven-plugin:2.27.0:generate failed: Plugin org.eclipse.xtext:xtext-maven-plugin:2.27.0 or one of its dependencies could not be resolved: Could not find artifact de.jpaw.bonaparte-dsl:de.jpaw.bonaparte.dsl:eclipse-plugin:5.0.4
I see an artifact which corresponds to de.jpaw.bonaparte-dsl:de.jpaw.bonaparte.dsl:eclipse-plugin:5.0.4 in my .m2/repository.
Could this be related to some not-yet-complete Eclipse download at 2022-06, or to the removed old generator (because it worked with 2.26.0)?
I checked the generator, and in the MWE file, xtext.xtext.generator is used, but the Java classes reference classes from xtext.generator (which are not marked as deprecated).
Any help is welcome.
Michael
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852711 is a reply to message #1852705] Thu, 02 June 2022 00:07 Go to previous messageGo to next message
I am not aware of any changes in that area. But yes I assume it can be due to incomplete 2022-06 repo.
Does it work if you. Switch back to 2022-03
Which Tycho version do you use?
can you provide a reproducer
[Updated on: Thu, 02 June 2022 04:34] by Moderator
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852713 is a reply to message #1852711] Thu, 02 June 2022 02:28 Go to previous messageGo to next message
do you get a message like
[ERROR] Failed to execute goal org.eclipse.xtext:xtext-maven-plugin:2.27.0:generate (default) on project example-project: Execution default of goal org.eclipse.xtext:xtext-maven-plugin:2.27.0:generate failed: Plugin org.eclipse.xtext:xtext-maven-plugin:2.27.0 or one of its dependencies could not be resolved: Could not transfer artifact org.osgi:org.osgi.service.prefs:eclipse-plugin:1.1.2 from/to eclipse (https://download.eclipse.org/releases/2022-06/202205271000/): Cannot access https://download.eclipse.org/releases/2022-06/202205271000/ with type p2 using the available connector factories: BasicRepositoryConnectorFactory: Cannot access https://download.eclipse.org/releases/2022-06/202205271000/ with type p2 using the available layout factories: Maven2RepositoryLayoutFactory: Unsupported repository layout p2 -> [Help 1]
if yes does it work if you add tycho to the plugin you build with?
e.g
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>tycho-maven-plugin</artifactId>
<version>2.7.3</version>
<extensions>true</extensions>
</plugin>
if yes can you open a bug at xtext-maven in github
to me this looks like a regression in how xtext and tycho play together, but i am not aware of changes in xtext
[Updated on: Thu, 02 June 2022 02:31] by Moderator
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852718 is a reply to message #1852713] Thu, 02 June 2022 04:10 Go to previous messageGo to next message
you might also want to participate in https://github.com/eclipse/tycho/discussions/989
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852788 is a reply to message #1852718] Fri, 03 June 2022 13:19 Go to previous messageGo to next message
thank you very much! Adding
<plugin>
</plugin>
to the project's build section worked for me. I added the plugin just before the xtext-maven-plugin. It is only required in case I specify 2 languages, for a single one it works without.
I used tycho 2.7.3 to build the DSL (as suggested by the release notes).
I now also tried to switch back to tycho 2.6.0, but in that case I already see errors building the DSL itself (something like javax.inject not found or icu4j not found).
I remember having seen something like missing org.osgi:org.osgi.service.prefs:eclipse-plugin:1.1.2 some days ago, but I cannot reproduce that now.
Michael
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852789 is a reply to message #1852788] Fri, 03 June 2022 13:42 Go to previous messageGo to next message
quick update: I can reproduce the missing org.osgi:org.osgi.service.prefs:eclipse-plugin:1.1.2 now.
This occurs when the repository in the target file is set to 2022-06.
Summarizing, the configuration which works for me is:
- xtext 2.27.0
- tycho 2.7.3
- repositories in target files as follows:
<repository location="https://download.eclipse.org/releases/2022-03/"/>
<repository location="https://download.eclipse.org/modeling/emft/mwe/updates/releases/2.13.0/"/>
<repository location="https://download.eclipse.org/modeling/tmf/xtext/updates/releases/2.27.0/"/>
and the additional tycho plugin in the build section for all projects which use the xtext.maven.plugin with more than one language.
Michael
Re: Xtext & Xtend Release 2.27.0 is available now [message #1852792 is a reply to message #1852789] Fri, 03 June 2022 14:34 Go to previous messageGo to next message
Can you try the workaround stated in the discussion at Tycho
Re: Xtext & Xtend Release 2.27.0 is available now [message #1853902 is a reply to message #1852792] Thu, 21 July 2022 12:22 Go to previous message
finally I found the relevant portion of code:
Adding
            <!-- without this the downstream projects would also need to use tycho -->
            <plugin>
                <artifactId>tycho-packaging-plugin</artifactId>
                <version>${tycho-version}</version>
                <configuration>
                    <skipPomGeneration>true</skipPomGeneration>
                </configuration>
            </plugin>
in the DSL's parent pom, the projects using the languages no longer need the tycho plugin, as it was the case with 2.26.0 and prior.
So yes, that workaround works for me.
Michael
Previous Topic:Unability to serialize an Xtext grammar created with EMF
Next Topic:How to get parent scope for nested block?
Current Time: Wed Apr 16 10:53:31 EDT 2025
Powered by FUDForum. Page generated in 0.04972 seconds
