How to add a mirror to Oomph? [message #1725969] |
Tue, 08 March 2016 16:50 |
Silvestre Martins Messages: 84 Registered: July 2009 |
Member |
I have a P2 mirror provided by Nexus (in-house) for some update sites such as http://download.eclipse.org/eclipse/releases/mars.
I was able to force Oomph to use this P2 mirror by adding directly the Nexus URLs to the setup file: org.eclipse.products.setup
However this will cause the installation to fail if this mirror is not accessible,
Can I simply add multiple URLs in the same setup file where some URLs are mirror from other ones? And if yes, how does Oomph prioritizes which URL to use?
And doesn't it make the installation slower if I add more URLs since it has more URLs to contact?
I was expecting a different configuration, where I could explicitly add mirror URLs and Oomph would decide if it should use the mirror or the eclipse download site.
[Updated on: Tue, 08 March 2016 16:50] Report message to a moderator
Re: How to add a mirror to Oomph? [message #1725989 is a reply to message #1725969] |
Tue, 08 March 2016 20:55 |
Ed Merks Messages: 33264 Registered: July 2009 |
Silvestre,
Comments below.
On 08.03.2016 17:50, Silvestre Martins wrote:
> I have a P2 mirror provided by Nexus for some update sites such as
You can also use a Redirection Task or use
-Doomph.redirection.foo=http://download.eclipse.org/eclipse/releases/mars->http://foo/bar
> accessible,
Yes, all approaches I can think of are like that. A proper "mirror" is
something specified by the repository itself. In this case the Mars
repository does specify a mirror request to Eclipse.org which returns a
list of mirrors which are then used (and can be broken without causing
an overall failure).
Yes.
Oomph, doesn't. P2 will use them all and I don't know if there is any
intelligence in which it chooses to use in the end.
Yes, that's a problem too.
That would be nice, but it's not how p2 works. In principle we could
augment p2 to add "externally specified" mirrors rather then the
built-in p2 approach where the update site itself must specify its mirrors
Ed Merks
Re: How to add a mirror to Oomph? [message #1726078 is a reply to message #1725991] |
Wed, 09 March 2016 12:52 |
Silvestre,
Comments below.
On 08.03.2016 22:41, Silvestre Martins wrote:
> Thanks Ed.
> Quote:
>> the > Nexus URLs to the setup file: org.eclipse.products.setup
> Sorry, but I don't understand the syntax of:
> -Doomph.redirection.foo=http://download.eclipse.org/eclipse/releases/mars-http://foo/bar
The "pattern" is
-Doomph.redirection.{any-name}={any-uri}->{any-other-uri} to define
what's essentially a rewrite rule to redirect any URI to any other URI.
It uses a EMF's URIMap and so "folder" redirections are possible as
well, e.g.,
-Doomph.redirection.eclipse.download=http://download.eclipse.org/->http://my.com/downloads/
will redirect all p2 sites hosted by Eclipse.org to the my.com domain's
downloads area.
> what does "foo" refer to? can it be any name? how does Oomph uses that
> "foo" token? Does it have any relationship with the "target URL" or
> can I have this actually in the file:
> -Doomph.redirection.foo=http://download.eclipse.org/eclipse/releases/mars-http://intra.my-company.com/nexus/repository/mars
Yes, like that only with -> to separate the two URIs.
> Quote:
>> or > the eclipse download site.
>> mirrors
> Do you think it makes sense to submit a request for this?
Yes, I think so. I think it's very common for companies to host mirrors
inside their firewall, so p2's ability to use mirrors is badly limited
by requiring the original p2 host repository to specify a way to
determine all appropriate mirrors.
Ed Merks
Re: How to add a mirror to Oomph? [message #1852613 is a reply to message #1726078] |
Fri, 27 May 2022 09:28 |
Elie Richa Messages: 72 Registered: February 2016 |
Member |
Hello Ed,
Ed Merks wrote on Wed, 09 March 2016 13:52Silvestre,
The "pattern" is
well, e.g.,
downloads area.
Does the "folder" redirection mentioned above also apply to RedirectionTask?
I'm trying to create a product setup that would only use my company's P2 servers and mirrors and I would like to redirect all http[s]://download.eclipse.org/* URLs to our servers.
I created 2 Redirection Tasks from http://download.eclipse.org/ and https://download.eclipse.org/ but I still find that ultimately the following 2 repos get added by the installer:
- https://download.eclipse.org/oomph/updates/milestone/latest
- https://download.eclipse.org/egit/updates
I can work around it by adding Redirection Tasks from the above exact URLs, but I was hoping for something that would cover all http[s]://download.eclipse.org/*, or even better, a global redirection of all P2 URLs (regardless of origin) to the company mirror.
Is there a way to do that?
Also a side question, do I understand correctly that Oomph automatically adds the above P2 repos even though they are not part of my P2 Director repo list because my setup contains Git and other Oomph tasks?
Many thanks!
Elie Richa, Ph.D
Software Engineer, AdaCore
https://www.adacore.com
FUDForum. Page generated in 0.03666 seconds
