Home » Eclipse Projects » Equinox » Accessing a P2 repository with SSO authentication
Accessing a P2 repository with SSO authentication [message #1852223] Thu, 05 May 2022 09:31 Go to next message
Elie Richa is currently offline Elie RichaFriend
Member
Hello folks,
At my organization we'd like to create a P2 repository with authentication. The clients to that repository would be Eclipse installations (e.g. P2 Director, target platform resolution, ...) and Maven Tycho.
In my experience both Eclipse and Maven Tycho support basic authentication, however that has an added burden of maintaining credentials dedicated for the P2 repository.
Instead it would be desirable to use Single Sign-On (e.g. Google) which is already setup company-wide.
Does anyone know if Eclipse and Maven Tycho support SSO as an authentication mechanism and how that would work roughly? I couldn't find any documentation concerning that.
Elie Richa, Ph.D
Software Engineer, AdaCore
https://www.adacore.com
Re: Accessing a P2 repository with SSO authentication [message #1852234 is a reply to message #1852223] Thu, 05 May 2022 14:11 Go to previous messageGo to next message
I'm quite sure that Eclipse does not support this. I'm not sure about Tycho, but I doubt it very much.
Ed Merks
Re: Accessing a P2 repository with SSO authentication [message #1852259 is a reply to message #1852234] Fri, 06 May 2022 11:15 Go to previous message
Member
Ok, thanks for confirming, Ed!
Elie Richa, Ph.D
Previous Topic:Debugging dependency resolution
Next Topic:RCP: Registering Jetty websocket servlets via HttpServiceImpl is broken after Jetty upgrade 9.4->
Current Time: Sat Dec 21 17:17:35 GMT 2024
Powered by FUDForum. Page generated in 0.04126 seconds
