Home » Modeling » TMF (Xtext) » Using Quickfixes and a LanguageServer
Using Quickfixes and a LanguageServer [message #1851462] Wed, 06 April 2022 09:53 Go to next message
Rubén Porras Campo is currently offline Rubén Porras CampoFriend
Member
I am trying to implement quickfixes for a Language Server based on Xtext. I would like to use the API developed in https://github.com/eclipse/xtext-core/pull/1597 but the package org.eclipse.xtext.ide.editor.quickfix is not exported in the MANIFEST.MF, so when I refer to IQuickFixProvider or DiagnosticResolutionAcceptor , tycho produces this errors when compiling
[ERROR] import org.eclipse.xtext.ide.editor.quickfix.QuickFix;
[ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[ERROR] Access restriction: The type 'QuickFix' is not API (restriction on classpath entry '/data/jenkins-slave/workspace/asmd-cf-gerrit-verify-pipeline@2/.repository/p2/osgi/bundle/org.eclipse.xtext.ide/2.26.0.v20220228-0751/org.eclipse.xtext.ide-2.26.0.v20220228-0751.jar')
[ERROR] import org.eclipse.xtext.ide.editor.quickfix.IQuickFixProvider;
[ERROR] ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
[ERROR] Access restriction: The type 'IQuickFixProvider' is not API (restriction on classpath entry '/data/jenkins-slave/workspace/asmd-cf-gerrit-verify-pipeline@2/.repository/p2/osgi/bundle/org.eclipse.xtext.ide/2.26.0.v20220228-0751/org.eclipse.xtext.ide-2.26.0.v20220228-0751.jar')
and I do not know how to suppress the restriction, using @SuppressWarnings("restriction") works in eclipse IDE but not on the maven build with type, and the same for the following part in the .classpath file
<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins">
<accessrules>
<accessrule kind="accessible" pattern="org/eclipse/xtext/ide/editor/quickfix/**"/>
</accessrules>
</classpathentry>
So, can this API be used? If so, how can I circunvent the error in tycho?
Kind Regards
Re: Using Quickfixes and a LanguageServer [message #1851464 is a reply to message #1851462] Wed, 06 April 2022 10:04 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
see https://github.com/eclipse/xtext-core/issues/1857
Twitter : @chrdietrich
Day Job: https://www.everest-systems.com
Re: Using Quickfixes and a LanguageServer [message #1851471 is a reply to message #1851464] Wed, 06 April 2022 11:06 Go to previous messageGo to next message
Member
could we get a 2.26.1 release, that is a minor release based on 2.26.0, with that fix? That is very unlikely to break anything. If needed I can help with the maintenance release.
Waiting for a major release, probably several months is a not viable for us, and using snapshots for productive code is also not a good solution.
Re: Using Quickfixes and a LanguageServer [message #1851472 is a reply to message #1851471] Wed, 06 April 2022 11:13 Go to previous messageGo to next message
is there a reason you need to develop with tycho?
Re: Using Quickfixes and a LanguageServer [message #1851475 is a reply to message #1851472] Wed, 06 April 2022 11:52 Go to previous messageGo to next message
can you also ask
in
tycho discussions on github if they can make use of
<accessrules>
</accessrules>
</classpathentry>
Re: Using Quickfixes and a LanguageServer [message #1851476 is a reply to message #1851472] Wed, 06 April 2022 11:53 Go to previous messageGo to next message
Member
I am not sure I understand your question.
For development (that is, when the developer is working), we just use the JDT compiler , there I can access the package org.eclipse.xtext.ide.editor.quickfix and suppress the warning.
But our verify jobs build the code in the same way as our release jobs, and they is use Maven + Tycho. There I have the problem that the verify jobs are failing.
Are you suggesting we should use something else than Maven + Tycho for our jobs? I have no idea what we would need to do so, but I expect that would be a lot of effort, wouldn't it? Maybe you know something I do not know.
Thansk
Re: Using Quickfixes and a LanguageServer [message #1851477 is a reply to message #1851476] Wed, 06 April 2022 11:59 Go to previous messageGo to next message
do you supprt eclipse and lsp or lsp only?
if you dont use dsl.ui and thus no osgi
you can build with pure maven or pure gradle
and you wont be struk by the issue.
Re: Using Quickfixes and a LanguageServer [message #1851483 is a reply to message #1851477] Wed, 06 April 2022 12:35 Go to previous messageGo to next message
Member
we support eclipse-xtext and eclipse-lsp for a transition period, so we need osgi at least for one product build. We could think about having special build for eclipse-lsp only, but it would be a lot of work to add all dependencies to the pom.xml and it would involve a lot of time waiting for builds to finish, etc. There is no joy in that :(
I think for us a hotfix is the best option by far, and it might solve the problem for other people, which increases the chances that Xtext gets feedback before on this particular API.
If that is not possible I think I would need to explore other possibilities which do not involved stop usage of Tycho, even though I am not sure what would be the preferred option. I am afraid to write publicly the options because they are all very ugly ;)
Re: Using Quickfixes and a LanguageServer [message #1851484 is a reply to message #1851483] Wed, 06 April 2022 12:45 Go to previous messageGo to next message
can you please create a github issue for discussion
please also note that 2022-06 is not too far away
Re: Using Quickfixes and a LanguageServer [message #1851486 is a reply to message #1851484] Wed, 06 April 2022 12:51 Go to previous message
Member
I have created https://github.com/eclipse/xtext-core/issues/1867, we can follow the topic in there.
Previous Topic:Xtext and Log4j/Reload4j
Next Topic:Storing list of eobjects before calling xtext validations
Current Time: Sun Dec 22 06:18:37 GMT 2024
Powered by FUDForum. Page generated in 0.04712 seconds
