Home » Eclipse Projects » Eclipse Titan » titan.TestPorts.IPL4asp SCTP socket returning wrong sinfo_ppid=0 when receiving data chunk
| titan.TestPorts.IPL4asp SCTP socket returning wrong sinfo_ppid=0 when receiving data chunk [message #1848155] |
Mon, 22 November 2021 12:07  |
I'm in the process of writing a CodecPort [1] + Emulation module [2] in order to emulate a HNBGW Iuh, which basically uses a IPL4asp SCTP socket and (de)multiplexes HNBAP and RUA payloads sent/received on the socket based on the sinfo_ppid (20=HNBAP, 19=RUA).
I have a program connecting to the above mentioned socket [3], and then it sends an HNBAP HnbRegisterRequest message to it (I can see in wireshark it properly sets sinfo_ppid=20 in the sctp data chunk section).
But then, in TTCN3, sino_ppid=0 is wrongly reported instead when the message is received:
09:27:22.173733 4 Iuh_Emulation.ttcn:162 Message enqueued on Iuh from system @IPL4asp_Types.ASP_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 54535, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := 0, sinfo_ppid := 0, remSocks := omit, assocId := omit } }, userData := 0, msg := '000100380000070003000C02404F736D6F484E6F64654200080001000009000300F110000B0004000000100006000200020007000103000A00020004'O } id 3
09:27:22.173878 4 Iuh_Emulation.ttcn:162 Incoming message was mapped to @Iuh_CodecPort.Iuh_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 54535, locName := "172.18.33.203", locPort := 29169, msg := { pdu_type := IUH_MSG_TYPE_OTHER (2), u := { payload := '000100380000070003000C02404F736D6F484E6F64654200080001000009000300F110000B0004000000100006000200020007000103000A00020004'O } } } id 3
I enabled debug on that port (as per titan.TestPorts.IPL4asp/src/IPL4asp_PT.cc), and I see the C++ code is already reporting an incorrect sinfo_ppid:
13:00:14.303074 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 9
13:00:14.303692 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 1 READABLE sock: 9, type: 3, sslState: 0
13:00:14.304114 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: incoming connection requested
13:00:14.304647 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER: ConnAdd enter: type: 4, ssl_tls_type: 0, sock: 10, parentIx: 1
13:00:14.304945 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: connId: 2
13:00:14.306089 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: leave: sockListCnt: 2
13:00:14.306933 4 Iuh_Emulation.ttcn:162 Message enqueued on Iuh from system @Socket_API_Definitions.PortEvent : { connOpened := { connId := 2, remName := "172.18.33.20", remPort := 40624, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, userData := 0 } } id 1
13:00:14.307468 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
13:00:14.308031 4 Iuh_Emulation.ttcn:175 Matching on port Iuh failed: Type of the first message in the queue is not @Iuh_CodecPort.Iuh_RecvFrom.
13:00:14.308645 4 Iuh_Emulation.ttcn:190 Matching on port Iuh { connOpened := { connId := 2, remName := "172.18.33.20", remPort := 40624, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, userData := 0 } } with { sctpEvent := { sctpAssocChange := ? } } unmatched: First message in the queue does not match the template:
13:00:14.309287 4 Iuh_Emulation.ttcn:191 Matching on port Iuh { connOpened := { connId := 2, remName := "172.18.33.20", remPort := 40624, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, userData := 0 } } with { sctpEvent := { sctpPeerAddrChange := ? } } unmatched: First message in the queue does not match the template:
13:00:14.309956 4 Iuh_Emulation.ttcn:194 Matching on port Iuh succeeded: matched
13:00:14.310325 4 Iuh_Emulation.ttcn:194 Receive operation on port Iuh succeeded, message from system(): @Socket_API_Definitions.PortEvent : { connOpened := { connId := 2, remName := "172.18.33.20", remPort := 40624, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, userData := 0 } } id 1
13:00:14.310648 4 Iuh_Emulation.ttcn:194 Message with id 1 was extracted from the queue of Iuh.
13:00:14.310927 4 Iuh_Emulation.ttcn:196 Established a new Iuh connection (conn_id=2)
13:00:14.311863 4 Iuh_Emulation.ttcn:198 Sent on HNBAP to TC_hnb_register_request(3) @Iuh_Emulation.IUHEM_Event : { up_down := IUHEM_EVENT_UP (1) }
13:00:14.312657 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 10
13:00:14.312870 3 Osmocom_Types.ttcn:104 Message enqueued on HNBAP from HNBGW0(4) @Iuh_Emulation.IUHEM_Event : { up_down := IUHEM_EVENT_UP (1) } id 1
13:00:14.313075 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 2 READABLE sock: 10, type: 4, sslState: 0
13:00:14.313360 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp message received
13:00:14.313602 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp peername and sockname obtained
13:00:14.314071 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: Notification received
13:00:14.314315 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::handle_event: incoming SCTP_ASSOC_CHANGE event.
13:00:14.314608 4 Iuh_Emulation.ttcn:162 Message enqueued on Iuh from system @Socket_API_Definitions.PortEvent : { sctpEvent := { sctpAssocChange := { clientId := 2, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, sac_state := SCTP_COMM_UP (0) } } } id 2
13:00:14.314901 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
13:00:14.315193 4 Iuh_Emulation.ttcn:175 Matching on port Iuh failed: Type of the first message in the queue is not @Iuh_CodecPort.Iuh_RecvFrom.
13:00:14.315472 4 Iuh_Emulation.ttcn:190 Matching on port Iuh succeeded: matched
13:00:14.315771 4 Iuh_Emulation.ttcn:190 Receive operation on port Iuh succeeded, message from system(): @Socket_API_Definitions.PortEvent : { sctpEvent := { sctpAssocChange := { clientId := 2, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, sac_state := SCTP_COMM_UP (0) } } } id 2
13:00:14.316036 4 Iuh_Emulation.ttcn:190 Message with id 2 was extracted from the queue of Iuh.
13:00:14.316483 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 10
13:00:14.316755 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 2 READABLE sock: 10, type: 4, sslState: 0
13:00:14.317028 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp message received
13:00:14.317278 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp peername and sockname obtained
13:00:14.317905 4 Iuh_Emulation.ttcn:162 Iuh: PL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: Incoming data (60 bytes): stream = 0, ssn = 0, flags = 0, ppid = 0
13:00:14.318550 4 Iuh_Emulation.ttcn:162 Message enqueued on Iuh from system @IPL4asp_Types.ASP_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 40624, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := 0, sinfo_ppid := 0, remSocks := omit, assocId := omit } }, userData := 0, msg := '000100380000070003000C02404F736D6F484E6F64654200080001000009000300F110000B0004000000100006000200020007000103000A00020004'O } id 3
13:00:14.319285 4 Iuh_Emulation.ttcn:162 Incoming message was mapped to @Iuh_CodecPort.Iuh_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 40624, locName := "172.18.33.203", locPort := 29169, msg := { pdu_type := IUH_MSG_TYPE_OTHER (2), u := { payload := '000100380000070003000C02404F736D6F484E6F64654200080001000009000300F110000B0004000000100006000200020007000103000A00020004'O } } } id 3
13:00:14.319863 4 Iuh_Emulation.ttcn:162 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
I also run it through strace, the msg_controllen=0 looks really suspicious:
logs/hnodeb-tester/strace.log.31:13:00:09.604842 recvmsg(4, {msg_name={sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("127.0.0.1")}, msg_namelen=128->16, msg_iov=[{iov_base="E\0\0T\311\217\0\0@\1\263\27\177\0\0\1\177\0\0\1\0\0n\335\0\37\0\1Y\224\233a"..., iov_len=192}], msg_iovlen=1, msg_control=[{cmsg_len=32, cmsg_level=SOL_SOCKET, cmsg_type=0x1d /* SCM_??? */}], msg_controllen=32, msg_flags=0}, 0) = 84
logs/hnodeb-tester/strace.log.31:13:00:09.605112 recvmsg(4, {msg_namelen=128}, 0) = -1 EAGAIN (Resource temporarily unavailable)
logs/hnodeb-tester/strace.log.31:13:00:10.609540 recvmsg(4, {msg_name={sa_family=AF_INET, sin_port=htons(0), sin_addr=inet_addr("127.0.0.1")}, msg_namelen=128->16, msg_iov=[{iov_base="E\0\0T\312\34\0\0@\1\262\212\177\0\0\1\177\0\0\1\0\0\326\312\0\37\0\2Z\224\233a"..., iov_len=192}], msg_iovlen=1, msg_control=[{cmsg_len=32, cmsg_level=SOL_SOCKET, cmsg_type=0x1d /* SCM_??? */}], msg_controllen=32, msg_flags=0}, 0) = 84
logs/hnodeb-tester/strace.log.31:13:00:10.610020 recvmsg(4, {msg_namelen=128}, 0) = -1 EINTR (Interrupted system call)
logs/hnodeb-tester/strace.log.35:13:00:14.313885 recvmsg(10, {msg_name={sa_family=AF_INET, sin_port=htons(40624), sin_addr=inet_addr("172.18.33.20")}, msg_namelen=128->16, msg_iov=[{iov_base="\1\200\0\0\24\0\0\0\0\0\0\0@\0\n\0\256\0\0\0", iov_len=65535}], msg_iovlen=1, msg_controllen=0, msg_flags=MSG_EOR|MSG_MORE}, 0) = 20
logs/hnodeb-tester/strace.log.35:13:00:14.317653 recvmsg(10, {msg_name={sa_family=AF_INET, sin_port=htons(40624), sin_addr=inet_addr("172.18.33.20")}, msg_namelen=128->16, msg_iov=[{iov_base="\0\1\0008\0\0\7\0\3\0\f\2@OsmoHNodeB\0\10\0\1\0\0\t\0\3"..., iov_len=65535}], msg_iovlen=1, msg_controllen=0, msg_flags=MSG_EOR}, 0) = 60
I see that IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable() (around line 1507) is not using libsctp's sctp_recvmsg, but directly calling getmsg()->recvmsg(). I checked how lksctp-tools [4] implements sctp_recvmsg, and I see that they seem to be doing a better job regarding buffer alignments, etc. and this may be the culprit of derreferring struct sctp_sndrcvinfo pointer incorrectly, which may lead to wrong use of the fields and that may explain sinfo_ppid=0. Other explanation could be that simply there's a kernel bug in old/new recent linux kernels?
titan.core version: 8.0.0
titan.TestPorts.IPL4asp: R.30.E
kernel version: 5.15.3-arch1-1 (x86_64)
userspace: Debian Stretch guest (docker)
[1] git.osmocom.org/osmo-ttcn3-hacks/tree/library/Iuh_CodecPort.ttcn?h=pespin/hnodeb
[2] git.osmocom.org/osmo-ttcn3-hacks/tree/library/Iuh_Emulation.ttcn?h=pespin/hnodeb
[3] git.osmocom.org/osmo-hnodeb/
[4] git://github.com/sctp/lksctp-tools.git
| Re: titan.TestPorts.IPL4asp SCTP socket returning wrong sinfo_ppid=0 when receiving data chunk [message #1848284 is a reply to message #1848260] |
Fri, 26 November 2021 07:49   |
Hi Gábor,
I tested with the new file and I still get the same behavior when running it in my env, sinfo_ppid=0:
12:44:23.282470 4 Iuh_Emulation.ttcn:159 Message enqueued on Iuh from system @Socket_API_Definitions.PortEvent : { sctpEvent := { sctpAssocChange := { clientId := 2, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, sac_state := SCTP_COMM_UP (0) } } } id 2
12:44:23.282707 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
12:44:23.282814 4 Iuh_Emulation.ttcn:172 Matching on port Iuh failed: Type of the first message in the queue is not @Iuh_CodecPort.Iuh_RecvFrom.
12:44:23.282908 4 Iuh_Emulation.ttcn:186 Matching on port Iuh succeeded: matched
12:44:23.282969 4 Iuh_Emulation.ttcn:186 Receive operation on port Iuh succeeded, message from system(): @Socket_API_Definitions.PortEvent : { sctpEvent := { sctpAssocChange := { clientId := 2, proto := { sctp := { sinfo_stream := omit, sinfo_ppid := omit, remSocks := omit, assocId := omit } }, sac_state := SCTP_COMM_UP (0) } } } id 2
12:44:23.283018 4 Iuh_Emulation.ttcn:186 Message with id 2 was extracted from the queue of Iuh.
12:44:23.283133 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 10
12:44:23.283222 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 2 READABLE sock: 10, type: 4, sslState: 0
12:44:23.283274 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp message received
12:44:23.283307 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp peername and sockname obtained
12:44:23.283368 4 Iuh_Emulation.ttcn:159 Iuh: PL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: Incoming data (60 bytes): stream = 0, ssn = 0, flags = 0, ppid = 0
12:44:23.283913 4 Iuh_Emulation.ttcn:159 Message enqueued on Iuh from system @IPL4asp_Types.ASP_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 52712, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := 0, sinfo_ppid := 0, remSocks := omit, assocId := omit } }, userData := 0, msg := '000100380000070003000C02404F736D6F484E6F64654200080001000009000300F110000B0004000000100006000200020007000103000A00020004'O } id 3
12:44:23.289618 4 Iuh_Emulation.ttcn:159 Incoming message was mapped to @Iuh_CodecPort.Iuh_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 52712, locName := "172.18.33.203", locPort := 29169, msg := { hnbap := { initiatingMessage := { procedureCode := 1, criticality := reject (0), value_ := { hNBRegisterRequest := { protocolIEs := { { id := 3, criticality := reject (0), value_ := { hNB_Identity := { hNB_Identity_Info := '4F736D6F484E6F646542'O ("OsmoHNodeB"), iE_Extensions := omit } } }, { id := 8, criticality := reject (0), value_ := { hNB_Location_Information := { macroCoverageInfo := omit, geographicalCoordinates := omit, iE_Extensions := omit } } }, { id := 9, criticality := reject (0), value_ := { pLMNidentity := '00F110'O } }, { id := 11, criticality := reject (0), value_ := { cellIdentity := '0000000000000000000000000001'B } }, { id := 6, criticality := reject (0), value_ := { lAC := '0002'O } }, { id := 7, criticality := reject (0), value_ := { rAC := '03'O } }, { id := 10, criticality := reject (0), value_ := { sAC := '0004'O } } }, protocolExtensions := omit } } } } } } id 3
12:44:23.289708 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
The CoecPort actually decodes it as HNBAP because I temporarily patched it to decode HNBAP on sinfo_ppid=0 so I can keep on implementing the HNBAP part while this is being fixed.
[Updated on: Fri, 26 November 2021 07:50] by Moderator
| Re: titan.TestPorts.IPL4asp SCTP socket returning wrong sinfo_ppid=0 when receiving data chunk [message #1848681 is a reply to message #1848408] |
Mon, 13 December 2021 13:49   |
Hi Gabor,
sorry, I forgot to mark the "notify me" option and I didn't get last updates here.
I did a test run again, now with the new version of the file you provided with further debug.
I still get ppid=0.
$ cat logs/hnodeb-tester/HNB_Tests.TC_hnb_register_request_accept.merged | grep IPL4asp__PT_PROVIDER:
18:31:42.958738 4 - Iuh: IPL4asp__PT_PROVIDER::set_parameter: enter (name: debug, value: YES)
18:31:42.958803 4 - Iuh: IPL4asp__PT_PROVIDER::user_start: enter
18:31:42.960195 4 Iuh_Emulation.ttcn:136 Iuh: IPL4asp__PT_PROVIDER::user_map(Iuh_CODEC_PT): enter
18:31:42.960970 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::setOptions: enter, number of options: 0
18:31:42.960985 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::setOptions: sock: 9
18:31:42.961016 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::setOptions: Socket option REUSEADDR on socket 9 is set to: 1
18:31:42.961029 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::setOptions: Setting sctp options sinit_num_ostreams:64,sinit_max_instreams:64, sinit_max_attempts:0, sinit_max_init_timeo:0
18:31:42.961043 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::setOptions: Setting sctp event options
18:31:42.961063 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::setOptions: leave
18:31:42.961154 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER: ConnAdd enter: type: 3, ssl_tls_type: 0, sock: 9, parentIx: -1
18:31:42.961185 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: new sockListSize: 16
18:31:42.961201 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: connId: 1
18:31:42.961235 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: connId: set ssl options for connId : 1
18:31:42.961256 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::set_ssl_supp_option: set SSL options
18:31:42.961816 4 Iuh_Emulation.ttcn:138 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: leave: sockListCnt: 1
18:31:46.820147 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 9
18:31:46.820743 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 1 READABLE sock: 9, type: 3, sslState: 0
18:31:46.821227 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: incoming connection requested
18:31:46.821518 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER: ConnAdd enter: type: 4, ssl_tls_type: 0, sock: 10, parentIx: 1
18:31:46.821610 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: connId: 2
18:31:46.822099 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::ConnAdd: leave: sockListCnt: 2
18:31:46.822321 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::setOptions: enter, number of options: 0
18:31:46.822393 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::setOptions: sock: 10
18:31:46.822498 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::setOptions: Setting sctp options sinit_num_ostreams:64,sinit_max_instreams:64, sinit_max_attempts:0, sinit_max_init_timeo:0
18:31:46.822579 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::setOptions: Setting sctp event options
18:31:46.822646 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::setOptions: leave
18:31:46.823993 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
18:31:46.827254 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 10
18:31:46.827389 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 2 READABLE sock: 10, type: 4, sslState: 0
18:31:46.827475 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp message received
18:31:46.827544 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp peername and sockname obtained
18:31:46.827614 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: msg->msg_controllen 96
18:31:46.827878 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::getmsg: msg->msg_controllen 0
18:31:46.828154 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: Notification received
18:31:46.828290 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::handle_event: incoming SCTP_ASSOC_CHANGE event.
18:31:46.828847 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
18:31:46.829402 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: enter, fd: 10
18:31:46.829474 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: connId: 2 READABLE sock: 10, type: 4, sslState: 0
18:31:46.829541 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp message received
18:31:46.829596 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: sctp peername and sockname obtained
18:31:46.829646 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: msg->msg_controllen 96
18:31:46.829744 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::getmsg: msg->msg_controllen 0
18:31:46.835857 4 Iuh_Emulation.ttcn:159 Iuh: IPL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: leave
18:31:46.843260 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::outgoing_send: ASP Send: enter
18:31:46.843290 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::outgoing_send_core: ASP Send: enter
18:31:46.843330 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::getAndCheckSockType: sock type is: 4
18:31:46.843345 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::outgoing_send_core: ASP Send: calling sendNonBlocking with proto
18:31:46.843370 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::sendNonBlocking: enter: connId: 2
18:31:46.843384 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::sendNonBlocking: fd: 10
18:31:46.843461 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::sendNonBlocking: sctp sinfo: 0, ppid: 335544320
18:31:46.843594 4 Iuh_Emulation.ttcn:163 Iuh: IPL4asp__PT_PROVIDER::sendNonBlocking: leave
18:31:47.850774 4 - Iuh: IPL4asp__PT_PROVIDER::user_unmap(Iuh_CODEC_PT): enter
18:31:47.850807 4 - Iuh: IPL4asp__PT_PROVIDER::user_unmap: There are 2 open connections
18:31:47.850867 4 - Iuh: IPL4asp__PT_PROVIDER::ConnDel: enter: connId: 1
18:31:47.850900 4 - Iuh: IPL4asp__PT_PROVIDER::ConnDel: fd: 9
18:31:47.852359 4 - Iuh: IPL4asp__PT_PROVIDER::ConnFree: enter: connId: 1
18:31:47.852495 4 - Iuh: IPL4asp__PT_PROVIDER::ConnDel: enter: connId: 2
18:31:47.853162 4 - Iuh: IPL4asp__PT_PROVIDER::ConnDel: fd: 10
18:31:47.853561 4 - Iuh: IPL4asp__PT_PROVIDER::ConnFree: enter: connId: 2
18:31:47.853904 4 - Iuh: IPL4asp__PT_PROVIDER::user_stop: enter
It looks like the kernel is returning msg_controllen=0:
The relevant snippet again:
18:31:46.829823 4 Iuh_Emulation.ttcn:159 Iuh: PL4asp__PT_PROVIDER::Handle_Fd_Event_Readable: Incoming data (60 bytes): stream = 0, ssn = 0, flags = 0, ppid = 0
18:31:46.830410 4 Iuh_Emulation.ttcn:159 Message enqueued on Iuh from system @IPL4asp_Types.ASP_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 36164, locName := "172.18.33.203", locPort := 29169, proto := { sctp := { sinfo_stream := 0, sinfo_ppid := 0, remSocks := omit, assocId := omit } }, userData := 0, msg := '000100380000070003000C02404F736D6F484E6F64654200080001000009000300F110000B0004000000100006000200020007000103000A00020004'O } id 3
18:31:46.835762 4 Iuh_Emulation.ttcn:159 Incoming message was mapped to @Iuh_CodecPort.Iuh_RecvFrom : { connId := 2, remName := "172.18.33.20", remPort := 36164, locName := "172.18.33.203", locPort := 29169, msg := { hnbap := { initiatingMessage := { procedureCode := 1, criticality := reject (0), value_ := { hNBRegisterRequest := { protocolIEs := { { id := 3, criticality := reject (0), value_ := { hNB_Identity := { hNB_Identity_Info := '4F736D6F484E6F646542'O ("OsmoHNodeB"), iE_Extensions := omit } } }, { id := 8, criticality := reject (0), value_ := { hNB_Location_Information := { macroCoverageInfo := omit, geographicalCoordinates := omit, iE_Extensions := omit } } }, { id := 9, criticality := reject (0), value_ := { pLMNidentity := '00F110'O } }, { id := 11, criticality := reject (0), value_ := { cellIdentity := '0000000000000000000000000001'B } }, { id := 6, criticality := reject (0), value_ := { lAC := '0002'O } }, { id := 7, criticality := reject (0), value_ := { rAC := '03'O } }, { id := 10, criticality := reject (0), value_ := { sAC := '0004'O } } }, protocolExtensions := omit } } } } } } id 3
Current Time: Sun Oct 26 14:10:23 EDT 2025
Powered by FUDForum. Page generated in 0.07196 seconds
