IntelliJ Plugin in IntelliJ 2021.2.X [message #1844112] |
Wed, 01 September 2021 11:14  |
we are using IntelliJ for the Eclipse Scout development for some time now and I am very glad about the IntelliJ support of eclipse scout. Unfortunately the plugin, even in the lateast version released on 30th august, is not compatible with IntelliJ 2021.2.X.
I constantly get errors in non eclipse scout projects. So I was using the "old" intellij version 2021.1.x. But I thought with the latest update it could work. Are you aware of the problems?
One error I am getting is this:
Derived resource update for scope 'File ....' failed
java.lang.IllegalArgumentException: Argument for @NotNull parameter 'compiledPattern' of com/intellij/structuralsearch/Matcher.<init> must not be null
at com.intellij.structuralsearch.Matcher.$$$reportNull$$$0(Matcher.java)
at com.intellij.structuralsearch.Matcher.<init>(Matcher.java)
at com.intellij.structuralsearch.Matcher.<init>(Matcher.java:67)
at org.eclipse.scout.sdk.s2i.ExtensionsKt.structuralSearch(Extensions.kt:311)
at org.eclipse.scout.sdk.s2i.ExtensionsKt.findAllTypesAnnotatedWith(Extensions.kt:290)
at org.eclipse.scout.sdk.s2i.ExtensionsKt.findAllTypesAnnotatedWith$default(Extensions.kt:278)
at org.eclipse.scout.sdk.s2i.derived.DtoUpdateHandlerFactory$createHandlersFor$2.invoke(DtoUpdateHandlerFactory.kt:31)
at org.eclipse.scout.sdk.s2i.derived.DtoUpdateHandlerFactory$createHandlersFor$2.invoke(DtoUpdateHandlerFactory.kt:26)
at kotlin.sequences.FlatteningSequence$iterator$1.ensureItemIterator(Sequences.kt:315)
at kotlin.sequences.FlatteningSequence$iterator$1.hasNext(Sequences.kt:303)
at kotlin.sequences.FilteringSequence$iterator$1.calcNext(Sequences.kt:169)
at kotlin.sequences.FilteringSequence$iterator$1.hasNext(Sequences.kt:194)
at kotlin.sequences.FlatteningSequence$iterator$1.ensureItemIterator(Sequences.kt:311)
at kotlin.sequences.SequencesKt___SequencesKt.toCollection(_Sequences.kt:752)
at kotlin.sequences.SequencesKt___SequencesKt.toMutableList(_Sequences.kt:782)
at kotlin.sequences.SequencesKt___SequencesKt.toList(_Sequences.kt:773)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor$executeDerivedResourceHandlerFactory$1.invoke(DerivedResourceManagerImplementor.kt:131)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor$executeDerivedResourceHandlerFactory$1.invoke(DerivedResourceManagerImplementor.kt:47)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$sam$java_util_concurrent_Callable$0.call(IdeaEnvironment.kt)
at com.intellij.openapi.application.impl.NonBlockingReadActionImpl$Submission.insideReadAction(NonBlockingReadActionImpl.java:521)
at com.intellij.openapi.application.impl.NonBlockingReadActionImpl$Submission.lambda$attemptComputation$3(NonBlockingReadActionImpl.java:486)
at com.intellij.openapi.application.impl.ApplicationImpl.tryRunReadAction(ApplicationImpl.java:1078)
at com.intellij.openapi.progress.util.ProgressIndicatorUtils.lambda$runInReadActionWithWriteActionPriority$0(ProgressIndicatorUtils.java:78)
at com.intellij.openapi.progress.util.ProgressIndicatorUtils.runActionAndCancelBeforeWrite(ProgressIndicatorUtils.java:161)
at com.intellij.openapi.progress.util.ProgressIndicatorUtils.lambda$runWithWriteActionPriority$1(ProgressIndicatorUtils.java:118)
at com.intellij.openapi.progress.ProgressManager.lambda$runProcess$0(ProgressManager.java:57)
at com.intellij.openapi.progress.impl.CoreProgressManager.lambda$runProcess$2(CoreProgressManager.java:183)
at com.intellij.openapi.progress.impl.CoreProgressManager.registerIndicatorAndRun(CoreProgressManager.java:705)
at com.intellij.openapi.progress.impl.CoreProgressManager.executeProcessUnderProgress(CoreProgressManager.java:647)
at com.intellij.openapi.progress.impl.ProgressManagerImpl.executeProcessUnderProgress(ProgressManagerImpl.java:63)
at com.intellij.openapi.progress.impl.CoreProgressManager.runProcess(CoreProgressManager.java:170)
at com.intellij.openapi.progress.ProgressManager.runProcess(ProgressManager.java:57)
at com.intellij.openapi.progress.util.ProgressIndicatorUtils.runWithWriteActionPriority(ProgressIndicatorUtils.java:115)
at com.intellij.openapi.progress.util.ProgressIndicatorUtils.runInReadActionWithWriteActionPriority(ProgressIndicatorUtils.java:78)
at com.intellij.openapi.application.impl.NonBlockingReadActionImpl$Submission.attemptComputation(NonBlockingReadActionImpl.java:486)
at com.intellij.openapi.application.impl.NonBlockingReadActionImpl$Submission.executeSynchronously(NonBlockingReadActionImpl.java:421)
at com.intellij.openapi.application.impl.NonBlockingReadActionImpl.executeSynchronously(NonBlockingReadActionImpl.java:186)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory.computeInReadAction(IdeaEnvironment.kt:91)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory.computeInReadAction$default(IdeaEnvironment.kt:85)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor.executeDerivedResourceHandlerFactory(DerivedResourceManagerImplementor.kt:130)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor.access$executeDerivedResourceHandlerFactory(DerivedResourceManagerImplementor.kt:47)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor$performUpdateAsync$$inlined$synchronized$lambda$1.apply(DerivedResourceManagerImplementor.kt:122)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor$performUpdateAsync$$inlined$synchronized$lambda$1.apply(DerivedResourceManagerImplementor.kt:47)
at java.base/java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:271)
at java.base/java.util.HashMap$ValueSpliterator.forEachRemaining(HashMap.java:1675)
at java.base/java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:484)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:474)
at java.base/java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:952)
at java.base/java.util.stream.ReduceOps$ReduceTask.doLeaf(ReduceOps.java:926)
at java.base/java.util.stream.AbstractTask.compute(AbstractTask.java:327)
at java.base/java.util.concurrent.CountedCompleter.exec(CountedCompleter.java:746)
at java.base/java.util.concurrent.ForkJoinTask.doExec(ForkJoinTask.java:290)
at java.base/java.util.concurrent.ForkJoinTask.doInvoke(ForkJoinTask.java:408)
at java.base/java.util.concurrent.ForkJoinTask.invoke(ForkJoinTask.java:736)
at java.base/java.util.stream.ReduceOps$ReduceOp.evaluateParallel(ReduceOps.java:919)
at java.base/java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:233)
at java.base/java.util.stream.ReferencePipeline.collect(ReferencePipeline.java:578)
at kotlin.streams.jdk8.StreamsKt.toList(Streams.kt:72)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor.performUpdateAsync(DerivedResourceManagerImplementor.kt:123)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor.access$performUpdateAsync(DerivedResourceManagerImplementor.kt:47)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor$scheduleUpdate$1.invoke(DerivedResourceManagerImplementor.kt:111)
at org.eclipse.scout.sdk.s2i.derived.DerivedResourceManagerImplementor$scheduleUpdate$1.invoke(DerivedResourceManagerImplementor.kt:47)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory$callInIdeaEnvironment$job$1$1.invoke(IdeaEnvironment.kt:76)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory$callInIdeaEnvironment$job$1$1.invoke(IdeaEnvironment.kt:57)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory.callInIdeaEnvironmentSync(IdeaEnvironment.kt:64)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory$callInIdeaEnvironment$job$1.invoke(IdeaEnvironment.kt:75)
at org.eclipse.scout.sdk.s2i.environment.IdeaEnvironment$Factory$callInIdeaEnvironment$job$1.invoke(IdeaEnvironment.kt:57)
at org.eclipse.scout.sdk.s2i.environment.OperationTask$run$2.invoke(OperationTask.kt:45)
at org.eclipse.scout.sdk.s2i.environment.OperationTask$run$2.invoke(OperationTask.kt:28)
at org.eclipse.scout.sdk.s2i.environment.TransactionManager$sam$java_util_function_Supplier$0.get(TransactionManager.kt)
at org.eclipse.scout.sdk.core.util.CoreUtils.callInContext(CoreUtils.java:309)
at org.eclipse.scout.sdk.s2i.environment.TransactionManager$Companion.callInExistingTransaction(TransactionManager.kt:89)
at org.eclipse.scout.sdk.s2i.environment.TransactionManager$Companion.callInNewTransaction(TransactionManager.kt:73)
at org.eclipse.scout.sdk.s2i.environment.OperationTask.run(OperationTask.kt:44)
at com.intellij.openapi.progress.impl.CoreProgressManager.startTask(CoreProgressManager.java:450)
at com.intellij.openapi.progress.impl.ProgressManagerImpl.startTask(ProgressManagerImpl.java:117)
at com.intellij.openapi.progress.impl.CoreProgressManager.lambda$runProcessWithProgressAsync$5(CoreProgressManager.java:510)
at com.intellij.openapi.progress.impl.ProgressRunner.lambda$submit$3(ProgressRunner.java:243)
at com.intellij.openapi.progress.impl.ProgressRunner.lambda$submit$4(ProgressRunner.java:243)
at java.base/java.util.concurrent.CompletableFuture$AsyncSupply.run(CompletableFuture.java:1700)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
at java.base/java.util.concurrent.Executors$PrivilegedThreadFactory$1$1.run(Executors.java:668)
at java.base/java.util.concurrent.Executors$PrivilegedThreadFactory$1$1.run(Executors.java:665)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/java.util.concurrent.Executors$PrivilegedThreadFactory$1.run(Executors.java:665)
at java.base/java.lang.Thread.run(Thread.java:829)
Best
Nils
FUDForum. Page generated in 0.03690 seconds
