Home » Eclipse Projects » EclipseLink » ConcurrentModification Exception in JPA 3.0 Followup(Migration issues from EclipseLink 2.2.0 to EclipseLink 3.0)
ConcurrentModification Exception in JPA 3.0 Followup [message #1840573] |
Mon, 19 April 2021 15:31 |
WARREN WEIS Messages: 8 Registered: April 2021 |
Hello Eclipselink Forum:
I posted a related topic on this a few weeks ago, and thought I had the issue behind my post fixed, but now I think I do not. This may be an EclipseLink issue, or it may be something to do with the way our application interacts with Eclipselink. Again, I am not sure.
Background:
I work on a very large, very old Swing application that uses Eclipselink as its JPA provider and H2 as its database. The application currently runs on JDK 1.7. It uses EclipseLink version 2.2.0 and H2 1.3.164. Our problem: we must upgrade the application to be JDK 11 compatible. And to do this we must update the Eclipselink version. We've tried updating to Ecipselink 2.7.7 and Eclipselink 3.0. The results are the same:
the application won't start up. It throws a ConcurrentModification exception while loading the entity classes. I have pasted an excerpt of the logs below.
The H2 driver we are using is very old, but upgrading it to the latest version of H2 did not affect the behavior I am seeing, so I do not believe the driver is the issue here.
Analysis:
Our entity classes all extend an abstract class that implements the retrieve and retrieveAll methods for selecting from the database. Both retrieve() and retrieveAll() use Eclipselink's QueryByExample to retrieve. Here is the relevant code for the retrieve() method:
log.info( "retrieve() retrieving entity of type " + getClass() );
Query query = ((JpaEntityManager) entityManager).createQueryByExample( this );
query.setHint( QueryHints.REFRESH, HintValues.TRUE );
query.setHint( QueryHints.REFRESH_CASCADE, CascadePolicy.CascadeAllParts );
result = (T) query.getSingleResult();
log.info( "retrieve() finished retrieving entity of type " + getClass() );
I have put log entries at the beginning and end of each retrieval. As you can see from the log excerpt below all seems to go well, until several retrievals of the InterfaceConfiguration entity class pile up, followed by one of the TouchScreenType class. Then we get the ConcurrentModification exception and nothing goes well after that. This ConcurrentModification exception appears to occur in EclipseLink's caching methods.
I noticed that both InterfaceConfiguration and TouchScreenType had the same annoted relation to another entity class. This leads me to believe the ConcurrentModification exception might occur because the same cache copy of the entity referenced by both TouchScreenType and InterfaceConfigurationType are being updated at the same time. Or, perhaps, TouchScreenType is attempting to get a copy of the cache while the InterfaceConfiguration retrieval is updating it.
Another thing that I tried was changing the query hint for the CASCADE_REFRESH policy. The current code implementation adds this hint to the query prior to execution:
Commenting this line out, does allow the application to get through the startup process. It then fails elsewhere, but not with a ConcurrentModification exception, and probably because of the way the application was written, not because of Eclipselink. So the application does really need this cascade policy query hint.
Conclusion:
The ConcurrentModification exception can be triggered by adding the above hint, or removing it. The current application implementation will not behave properly without this hint, however.
I am faced with a massive rewrite of our application so that we can run our application with EclipseLink 2.77 or above. Or perhaps there is a simple fix that can be made to our configuration of Eclipselink that fixes this.
I sincerely hope that it is the latter and there is someone on the Eclipselink team who can help me with this.
2021-04-18 07:06:50,153 | INFO [LicenseMonitorThread.InterfaceConfigMonitor]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() finished retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:50,185 | INFO [ApplicationInitializationThread]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:50,237 | INFO [ApplicationInitializationThread]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() finished retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,994 | INFO [ASOS Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,994 | INFO [RBDT-0 Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,994 | INFO [RVR Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,995 | INFO [FDIO Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,995 | INFO [SAWS Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,996 | INFO [AWOS Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,996 | INFO [DASI Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:52,996 | INFO [WME Interface]-> com.awi.flexids.flexdb.datamodel.InterfaceConfiguration | retrieveAll() retrieving entity of type class com.awi.flexids.flexdb.datamodel.InterfaceConfiguration
2021-04-18 07:06:53,013 | INFO [NetworkMonitorThread]-> com.awi.flexids.flexdb.datamodel.TouchscreenType | retrieve() retrieving entity of type class com.awi.flexids.flexdb.datamodel.TouchscreenType
2021-04-18 07:06:53,270 | WARN [RBDT-0 Interface]-> com.awi.flexids.flexdb.FlexDBLogger |
java.util.ConcurrentModificationException: null
at java.util.HashMap$HashIterator.nextNode(HashMap.java:1493) ~[?:?]
at java.util.HashMap$KeyIterator.next(HashMap.java:1516) ~[?:?]
at org.eclipse.persistence.indirection.IndirectSet$1.next(IndirectSet.java:524) ~[eclipselink-3.0.0.jar:3.0.0]
at org.eclipse.persistence.internal.queries.InterfaceContainerPolicy.next(InterfaceContainerPolicy.java:346) ~[eclipselink-3.0.0.jar:3.0.0]
at org.eclipse.persistence.internal.queries.ContainerPolicy.next(ContainerPolicy.java:1207) ~[eclipselink-3.0.0.jar:3.0.0]
at org.eclipse.persistence.mappings.CollectionMapping.buildExpression(CollectionMapping.java:371) ~[eclipselink-3.0.0.jar:3.0.0]
at org.eclipse.persistence.internal.descriptors.ObjectBuilder.buildExpressionFromExample(ObjectBuilder.java:713) ~[eclipselink-3.0.0.jar:3.0.0]
at org.eclipse.persistence.mappings.CollectionMapping.buildExpression(CollectionMapping.java:373) ~[eclipselink-3.0.0.jar:3.0.0]
Re: ConcurrentModification Exception in JPA 3.0 Followup [message #1841376 is a reply to message #1840909] |
Thu, 13 May 2021 13:44 |
Chris Delahunt Messages: 1389 Registered: July 2009 |
that 'this' is a variable for an instance of SomeTable/Entity was understood - though it helps to show specifics about the entity. My questions though were on where you obtained and built it - how you read it in from the database, as it is that specific instance of the object that is involved in the concurrent modification example. As it suggests, you have more than one process using that ('this') instance and need to figure out what and where they are and stop it. I don't see how EclipseLink should be expected to query using this object as an example if parts of it is changing while it is building the query - it you are going to use these objects concurrently, it is up to the application to manage locking.
As for EAGER vs LAZY - no, that is wrong. single reference relationships (OneToOne, ManyToOne) default to EAGER if a fetchType is unspecified, while collection mappings (OneToMany, ManyToMany etc) default to LAZY. The stack trace in the exception shows you certainly have a lazy collection mapping involved in this concurrency issue.
Assuming you can't reproduce this on demand in a single threaded environment, the main issue isn't with the refresh, the lazy/eager fetching, but with the concurrency. You have an object you are passing to a findbyexample query, which requires EclipseLink to iterate though it to build a query, but you are also using that example object elsewhere in your application. How you find/lookup/build 'this' instance will help you determine how this might be happening
Current Time: Tue Jan 28 14:49:53 GMT 2025
Powered by FUDForum. Page generated in 0.03747 seconds
