Home » Eclipse Projects » Eclipse Scout » Registration page
Registration page [message #1840539] Sun, 18 April 2021 07:56 Go to next message
Good day,
I would like to have a registration page that is accessible with the /register URL.
I have tried to create RegisterRequestHandler which reads the Pac4J session data to prepopulate the form with userName, firstName, lastName and so forth.
The problem I am faced with, is that I do not know how to activate the PersonForm on the Desktop.
I have tried the following with and without a RunContext.
PersonForm form = new PersonForm();
 Desktop.CURRENT.get().activateForm(form);
Is there other mechanism to get this to work?
Kind regards,
Mark Ashworth
Re: Registration page [message #1840549 is a reply to message #1840539] Mon, 19 April 2021 01:40 Go to previous messageGo to next message
Hi Mark
You could work with deep-link handlers. Check the interface IDeepLinkHandler and the OutlineDeepLinkHandler as an example. These handlers are built to do something in the Scout model when a certain URL-pattern is called. The handler for the outlines activates the correct outline in the Scout model for instance when this URL is called:
/contacts/?dl=outline-22561&i=search
You could do something like that for your registration page, implement a RegistrationDeepLinkHandler and call it like this:
/contacts/?dl=registration
The typical code to open a form, depends on whether you want to open a modal dialog or a view, but usually you simply use the start() method of the form, which handles all the details with the desktop:
form.setHandler(form.new RegistrationHandler());
form.start();
André
Re: Registration page [message #1840552 is a reply to message #1840549] Mon, 19 April 2021 05:28 Go to previous message
Thank you Andre, will give that a try :-)
Mark Ashworth
Previous Topic:Errors while using CodeType
Next Topic:AbstractChartControl - how to show chart
Current Time: Fri Oct 31 00:06:36 EDT 2025
Powered by FUDForum. Page generated in 0.03839 seconds
